Question: how to change comma´s in dots (as a decimal seperator) in the data base???
Is there a 'search and replace' method to replace all comma´s by dots (as a decimal seperator). For example 0,78 into 0.78. At this moment several students responses were graded as incorrect while the only error they made was to provide a response using a comma instead of a dot. I can export the data file and use another program to score the responses, but there may be a much more efficient method to modify the responses. Harry Garst
