Question: Sketch questions in maple TA
Hi. I'd like to write a maple TA question involving a sketch. There are standard tests used to evaluate whether the sketch designed by the student is correct, such as : \check{linear} \check{goes_through(0,1)} etc... There is a certain tolerance in these tests. If the sketch aproximately goes through point (0,1) in the previous example, it will be considered correct. My questions are : What is this tolerance ? Is it possible to set this tolerance ? if not, Is it possible to artificially create a tolerance factor (with something which would look like : (value(0)-1)
