Question: help to find minimum
i have a problem to find the minimum point for implictfunction ,
I have a implictfunction that is ( f(x,y,z)=0 ), i want to find the minimum point for x.
I try to solved this problem using optimastion package and lagrangeMulteplied. the poth packages do not solved the problem.
Also if i have a implicitfunction as g(x,y,z,k)=0.
can you help me to solved this problem using maple?
