Question: Could you please explain the following:1
This question is related to the Question Task/Threads simultaneous download
1) str1 and str2 should be global variables right? I mean so we can call them
after the Create statements....
2) When I execute the below code and then call str1 and str2 I dont get any html output.
The " " are empty.....why?
with(Sockets):
with(Threads):
X1 := proc () local str, sid, b;  global str1;
str1 := "";
sid := Open("google.com", 80);
Write(sid, cat("GET /finance/historical?q=INDEXSP:.INX&histperiod=daily HTTP/1.0 \n\n"));
b := Read(sid); while b <> false do str := cat(str, b); b := Read(sid) end do;
Close(sid);
str1 ;
X2 := proc () local str, sid, b; global str2;
str2 := "";
Write(sid, cat("GET /finance/historical?q=INDEXEURO:.FCHI&histperiod=daily HTTP/1.0 \n\n"));
Close(sid);
str2;
Create(X1(), str1);
Create(X2(), str2);
str1;
str2;
3) what is the differens between task and thread ?  When should I use each of them ?
4) Why isnt there much different in speed in the below example. X1 counts the number of 7:s is
both columns. X2 counts the number of 7:s in the first column and X3 counts the number of 7:s
in the second column in parallel.
Now X1 and X2+X3 should produce the same result (which is does) and X2+X3 should be
much faster than X1. However this is not true. In this case X2+X3 actually takes longer.. why??
with(LinearAlgebra):
randomize():
dat := RandomMatrix(1000000, 2, generator = 1 .. 10):
X1 := proc () local c, i, j;
c := 0;
for i to 1000000 do
for j to 2 do
if dat[i, j] = 7 then c := c+1 end if
end do
end do;
c
X2 := proc () local c, i;
c := 0;
for i to 1000000 do
if dat[i, 1] = 7 then c := c+1 end if
end do;
c
X3 := proc () local c, i;
c := 0;
for i to 1000000 do if
dat[i, 2] = 7 then c := c+1 end if
end do;
c
st := time():
X1();
"X1 time" = time()-st;
st := time():
data1 := Threads:-Task:-Start(X2):
data2 := Threads:-Task:-Start(X3):
data1+data2;
"X2+X3 time" = time()-st;
                                   199837
                              "X1 time" = 2.106
                                   199837
                            "X2+X3 time" = 2.184
