Question: Custom lib can't call other libs
Hi there,
i've wirtten a library for maple12, say "MyLib", which is given by the files "MyLib.ind" and "MyLib.lib".
I've done this via
> restart;
>  march('create', "<path>/MyLib.lib", 1);
> read "functions.txt";
> savelibname:="<path>";
> savelib( `MyLib` );
where "functions.txt" is given as
MyLib:= module()
 export f1, f2;
 local g1, g2;
 option package;
end module;
with given functions and a certain <path>.
The problem is as follows:
if f1 calls a procedure, say "AnotherPackage[h]()", it seems to interpret that as a symbol instead of a call.
For instance: If I try to use it via
> with(AnotherPackage);
> with(MyLib);
> f1();
leads to "h()" instead of the call to h. What is wrong and how do I get rid of this?
Thanks in advance!
