Question: procedure error
i'm trying to run the following procedure:
> restart; with(LinearAlgebra);
> test:=proc(alpha, beta);
print(`output redirected...`); # input placeholder
Error, unterminated procedure
         testAssignTypesetting:-mambiguous(
           procApplyFunction(αcomma β),
           Typesetting:-merror(unterminated procedure))
> local  itype::integer, lambda1, lambda2 Delta;
Error, unable to parse
Typesetting:-mambiguous(local,
  Typesetting:-merror(unable to parse)) itypeColonintegercomma
  λ1comma λ2 Δsemi
> Delta := alpha^2-beta;
> lambda12 := sqrt(sqrt(beta)-alpha);
> lambda22 := sqrt(sqrt(beta)+alpha);
> lambda13 := sqrt(-alpha+sqrt(alpha^2-beta));
> lambda23 := sqrt(alpha+sqrt(alpha^2-beta));
> lambda14 := sqrt(-alpha);
> lambda24 := sqrt(-alpha);
> lambda15 := sqrt(alpha);
> lambda25 := sqrt(alpha);
> lambda16 := sqrt(alpha-sqrt(alpha^2-beta));
> lambda26 := sqrt(alpha+sqrt(alpha^2-beta));
> lambda17 := sqrt(-alpha+sqrt(alpha^2-beta));
> lambda27 := sqrt(-alpha-sqrt(alpha^2-beta));
> lambda18 := 0.;
> lambda28 := sqrt(-2.0*alpha);
> lambda19 := 0.;
> lambda29 := sqrt(2.0*alpha);
> lambda1 := piecewise(alpha = 0. and beta = 0., 0., `and`(beta > 0., Delta < 0.), lambda12, beta < 0., lambda13, `and`(alpha < 0., Delta = 0.), lambda14, `and`(alpha > 0., Delta = 0.), lambda15, `and`(`and`(beta > 0., alpha > 0.), Delta > 0.), lambda16, `and`(`and`(beta > 0., alpha < 0.), Delta > 0.), lambda17, alpha < 0., lambda18, lambda19);
> lambda2 := piecewise(alpha = 0. and beta = 0., 0., `and`(beta > 0., Delta < 0.), lambda22, beta < 0., lambda23, `and`(alpha < 0., Delta = 0.), lambda24, `and`(alpha > 0., Delta = 0.), lambda25, `and`(`and`(beta > 0., alpha > 0.), Delta > 0.), lambda26, `and`(`and`(beta > 0., alpha < 0.), Delta > 0.), lambda27, alpha < 0., lambda28, lambda29);
> itype := piecewise(alpha = 0. and beta = 0., 1, `and`(beta > 0., Delta < 0.), 2, beta < 0., 3, `and`(alpha < 0., Delta = 0.), 4, `and`(alpha > 0., Delta = 0.), 5, `and`(`and`(beta > 0., alpha > 0.), Delta > 0.), 6, `and`(`and`(beta > 0., alpha < 0.), Delta > 0.), 7, alpha < 0., 8, 9);
> return lambda1, lambda2, itype;
> end proc;
But i keep getting errors like unterminated proc, and unable to parse error with local and end proc...
any suggestions????thnx in advance..
