Question: Generating sequence from -listtorec
Thanks for the reply; It was very close to what it is needed, but I have another question.
In that post, first a recursion is found using "listtorec" and then that recursion is solved using "rsolve"
Isn't there any way to generate the sequence from the recursive formula without solving? because solving is not necessary, as long as you have recursive formula and the base cases, sequence can be generated ....
//Mehrdad
