how i tackle an bvp ode,derivative involve in bcs.i want to solve by dsolve comand or by using Rk meethod.i am attaching the maple sheet,ode wrrten in attached maple sheet
thank you
 few boundary conditions: expected 7, got 2
Download kummer_sol.mwkummer_sol.mw
Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 7, got 2
Hello awesome maple people
I have the following Matrix
R := Matrix([[1, -2, 2, 6, -6], [2, -3, 4, 9, -8]])
then i do
ReducedRowEchelonForm(R);
and i get an output, but is there any way to get it to give me the output in Parametric form?
Like this https://snag.gy/BQniuR.jpg
Thanks in advance :)
i have 2 PDE equations with some boundary conditions,maple get me errors, what should i do ? please help
how can i make correction in my system or boundary to have a solution ?
Download pde2.mw
tnx in advance
Hello Dr/Prof?sir?madam
i have problem on running the ode bcs
there is cos n sine in ther ode
any idea to solve this ?
i have attched it
thnks
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Sc.mw .
Download Sc.mw
I am trying to do a numerical approximate method 'method of multiple scales'. And in doing so I am getting following equation.
junk := -n*v_SDD*x[1](T[0], T[1], T[2])+x[1](T[0], T[1], T[2])+(D[1, 1](x[1]))(T[0], T[1], T[2])+2*kappa*(D[1](x[1]))(T[0], T[1], T[2])+n*v_SDD*x[1](T[0]-tau_1, T[1], T[2])-psi*n*x[1](T[0]-tau_1, T[1], T[2])+psi*n*x[1](T[0], T[1], T[2])
evalf(subs(x[1](T[0], T[1], T[2]) = R(T[1], T[2])*sin(omega*T[0]+phi(T[1], T[2])), %))
-1.*n*v_SDD*R(T[1], T[2])*sin(omega*T[0]+phi(T[1], T[2]))+R(T[1], T[2])*sin(omega*T[0]+phi(T[1], T[2]))+(D[1, 1](x[1]))(T[0], T[1], T[2])+2.*kappa*(D[1](x[1]))(T[0], T[1], T[2])+n*v_SDD*x[1](T[0]-tau_1, T[1], T[2])-1.*psi*n*x[1](T[0]-tau_1, T[1], T[2])+psi*n*R(T[1], T[2])*sin(omega*T[0]+phi(T[1], T[2]))
Download question3.mw
Now I need to substitute x_1(T0,T1,T2)=R(T1,T2)sin(omega*T0+phi(T1,T2)) in the expression and evaluate it.  But on substituting, it is not solving for the 'D' operator. In a similar line if I will have a differential term like
D1(x1)(T0-tau_1,T1,T2) and I have to substitute x1(T0-tau_1,T1,T2) then how can i do it?
Please help me regarding it.
Thanks and regards
Sunit
I created a new Document with a single command:
A=1
Then I right-clicked on the command and chose Explore from the context menu and then clicked on the Explore button in the dialog box. A rectangle with a slider appeared. So far so good.  However, I cannot delete the rectangle from my Document. I tried to select the rectangle and press Delete, Ctrl+Delete, and to right-click on it and choose Cut from the menu. Nothing works.
If I select both the rectangle and the command A=1 all the three actions described above also fail to delete anything.
Help will be appreciated.
Using Maple 2016, I created a new Document with one line:
A=(1,2,3)
Right-clicking on this expression I thought I could choose Assign to a Name, as is done in Clickable Calculus Series - Part 3: Multivariate Calculus, found here:
https://www.youtube.com/watch?v=GYN-GetHRFA
However, Assign to a Name does not appear in the context menu.
On the other hand, if I write
B=1,2,3
(with no parentheses) and right-click on this expression then Assign to a Name does appear in the context menu.
Any insights on this?
When doing numerical calculations or evaluations it is very useful to have float results shown in numeric notation, where the exponent is 3 * n.
Below are some simple calculations:
Is there a way to make Maple show the resultin (1) .. (3) as:
  • 333.3 106
  • 333.3 103
  • 333.3 100 or just 333.3
sorry what is what dispatch and implementing what? i get these every week for a number of cases sometimes it specifies that it is an "unhandled psi case" still waiting on that built in proc u guys where gonna dispatch like u know the reasons ppl always have a whinge about evalf not working in some cases  anyway a few people have run into these error id say.
yes its just one inbuilt function i really need to study in particular, if someone can help me to do this pls.
I have to store real-number matrixes into .mla files. Usually, I do it by using “save”, namely:
save Hi, “Hi.mla”
where i denotes is the i-th matrix I want to save. The problem is, I have to write manually :
save H1, “H1.mla” :
save H2, “H2.mla” :
and so on. This is not convenient as the number of matrixes to save is huge. Also, it does not work writing:
for i from 1 to n do
save H[i], “H[i].mla”
od
Any idea of what could be done? Thank you in advance.
Hi everyone,
For my first question, I am looking for some help about the following. I have the opportunity to run a worksheet in parallel on a cluster of sixteen workstations, each one endowed with twelve CPUs, through the GRID Computing Toolbox. However, I have troubles concerning how to do that.
I join the worksheet at issue: abmm_ma_1.mw The aim is to run large-scale numerical simulations of a dynamic system, depending on the values given to the initial conditions and to the parameters. The worksheet is organized in four execution groups:
  1. The required packages (combinat and LinearAlgebra).
  2. Calibration of the parameters and initial conditions.
  3. The system, which is embedded into a procedure called SIM.
  4. The activation of SIM, whose outputs are nine .mla files, each one being made of a real-number matrix.
The truth is, I do not clearly see how to modify the worksheet with some elements of the GRID package. Besides, the cluster operates under HTCondor so that running the worksheet requires beforehand the creation of a .sub file. This should be done in consistency with the aforesaid modification.
Any help is welcome, thanks a lot.
The following problem works if i = j.   I need help to fix this problem for i ≠ j.  Thanks
A := [1, 2, 3, 4, 5];
B := [a, b, c, d];
seq([A[i], B[j]], i = 1 .. 5, j = 1 .. 4);
Error, invalid input: seq expects its 3rd argument, step, to be of type numeric, but received j = 1 .. 4
Hi guys. I am new to the Maple environment.
Was trying to do some GR calculations when the following problem arose.
restart; with(Physics);
Setup(coordinates = (X = [t, r, theta, phi]), metric = -A(r)^2*(dt^2)+B(r)^2*(dr^2)+r^2*(dtheta^2)+r^2*(sin(theta)^2)*(dphi^2));
Setup(math = true);
g_[line_element]; g_[];
Christoffel[nonzero]; Christoffel[`~mu`, alpha, beta, nonzero];
D_[mu](g_[`~alpha`, `~beta`]);
expand(D_[2](g_[`~2`, `~beta`]));
D_[2](g_[`~2`, `~2`]);
The output for the last 3 lines are:
1. 0
2. Expansion in terms of Christoffel symbols (which does equal zero on substituting various values)
3. Non-zero value.
Obviously the answer must be zero for all cases (covariant derivative of metric). So what have I missed/misunderstood here?
BuddT
First 1129 1130 1131 1132 1133 1134 1135 Last Page 1131 of 2470
