I think this is equation to plot
plot3d((x/(13.2))^2+(y/(24.3))^2+((1/22)*z)^2 = 1, x = 10 .. 12, y = 10 .. 20, z = 10 .. 20)
but why its not plotting
pl help
Hello All
I looking to write Maple code procedure to solve this equation
with(PDEtools):
pde := diff(psi(t,x),t,t) - diff(psi(t,x),x,x) + V(x)*psi(t,x);
where V(x)->x^2;
I have to use this stencil
u[i+1,j]=-u[i-1,j1]+(1-1/8*h^2*v[i-1])*u[i,j-1]+(1-1/8*h^2*v[i+1])*u[i,j+1]; where i is spatial step and j is time step
I have a question concerning the change of the results of Maximization procedure and it will be much appreciated if you could help me.
The case is: I need to find the maximum of a function (call if f(t)) given a range of values of another function (call it g(t)).Both sets of parameters are the same. I use "Maximize" command, but I need to plot the the results on (f,g) plane afterwards. How could I change the Maximization output in order to have only objective function...
int(y^2/2 - lambda*(u*diff(y,t)-diff(u,t)-a), t);
with(Physics):
diff(y(t)^2/2 - lambda(t)*(u(t)*diff(y(t),t)-diff(u(t),t)-a), u(t)); # u -> something
diff(lambda(t),t) disappear
should be
diff(lambda(t),t)+Physics[`*`](lambda(t), diff(y(t), t))
diff(y(t)^2/2 - lambda(t)*(u(t)*diff(y(t),t)-diff(u(t),t)-a), y(t)); # y -> something
u*diff(lambda(t...
I would like to take the sin of a procedure, but it keeps giving me an error. Is it possible at all, or should I rewrite it into a matrix?
like this: sin(proc(x)...end proc)
following expression doesn't simplify to 1
conjugate(1/sqrt(I*t*lambda+m))*sqrt(lambda^2*(t^2)+m^2)*(1/sqrt(I*t*lambda+m))
Now I did use assumptions on any variable
specifically: assume(lambda>0,t>0,m>0)
Then I tried radnormal, simplify, evalc, combine(expr,radical)
But none of these work.
Hey (again) everyone. I'm back with a question similar to (but never answered on) this post: http://www.mapleprimes.com/questions/152116-Maple-Doesnt-Recognize-Function-Definition
The problem here is almost identical, except now it won't let me define a procedure. It's very bizarre. Here is my sheet:
The following equation represents the magnification (A) of an object given its distance (s1) from a closed optical system.
How can I determine the range of s1 that will provide a magnification (A) range of 2.5 to 5?
Dear maple team.
I would like to suggest something about the treatment that Maple makes of arithmetic modulo 2.
If you write the command:"x+x mod 2", the Maple output is "0", because "x+x" is always even. Perfect.
The problem I have is:
When  you write "x^2 + x mod 2", the Maple output is "x^2 + x"  instead of "0". Maple doesn't takes into account when simplifying that all the variables are idempotent modulo 2 (i.e, x*x = x)
If I write
Can maple use a Differential Operator somehow in the following sense?
Instead of expanding (D-p)^n where p is a constant and D the differential operator and n an integer and then in each term writing D^n(f) for some function can I just leave the expression as it is like
(D-p)^n and acting on everything on the right?
I have this sequence:
 D[n] = (Sum((n-k)/(k+1),k = 0 .. n-1)-ln(n!))/n;
How can I put  this in maple, assess if it converges or not and if it is possible, calculate the limit to infinity.
is the warning I get every time I try to solve for solve(ode1 = ode2, theta/T)
Is there any way I can solve for an expression (i.eg theta/T)?
Furthermore I would like to have an answer on how I get to laplace transforms (ODE) with only "s" in the output, if I type like this:
laplace(J*(diff(theta(t), t, t...
  Can I dowload the Iterator package and use it with Maple 12? Thanks.
Hi, I cannot solve the 2 implicit functions with 2 unknown (m,n) simultaneously (please see attached maple file). Note: m and n are real numbers.
May I get some advice please? Many thanks.
Is there a way to swap the names of two Arrays without creating unnecessary copies?
The scenario is as follows. I want to repeatedly apply a function to a large Array. The new value in each cell depends on seveal cells of the old Array.  So on each iteration I need to keep track of two Arrays: A_old and A_new. At the end of the iteration I would like to swap A_old and A_new efficiently. This way I will only need the memory for two Arrays and will...
First 1575 1576 1577 1578 1579 1580 1581 Last Page 1577 of 2471
