Solve the following system of equations
  Hello, I am a student from university of waterloo, and I have purchased maple code from school, but I dont know where to download a student version, so that i can activate it.
The solution to the following differential equations results in empty brackets [] and I want to know their content
> Restart; ode := B*(x-1)^2*(diff(y(x), x, x))+C*(x-1)*(diff(y(x), x))+(A-x/(x-1))*y(x) = 0;
> dsolve(ode);
y(x) = _C1*(x-1)^((1/2)*(-C+B-I*sqrt(-B^2+(2*C+4*A-4)*B-C^2))/B)*hypergeom([], [(B+I*sqrt(-B^2+(2*C+4*A-4)*B-C^2))/B], 1/(B*(x-1)))+_C2*(x-1)^((1/2)*(-C+B+I*sqrt(-B^2+(2*C+4*A-4)*B-C^2))/B)*hypergeom([], [(B-I*sqrt(-B^2+(2*C+4*A-4)*B-C^2))/B], 1/(B*(x-1)))
HERE IS A FUNCTION THAT I WANT TO DIFFERENTIATE
I've been wondering if this is possible and i'd be very happy if it is. Is there a way i can format the output of and fsolve(). in such a way that it does not come in curly braces, preferably, it comes out in a colomn-vector form and without the names of the variables solved for. Just the values.
Secondly, I've been trying to apply the newtons method for my friend here in school but i've been getting an error message...
Let X be the random variable uniformly distributed in the disk centered at the origin O(0,0) with radius 1 and let Y be the random variable uniformly distributed in the square having its vertices A(6,-1), B(9,-2), C(8,-5), and E(5,-4). What is the PDF of the distance between X and Y? Is it possible to find that with Maple? The similar question in three dimensions, replacing a square by a cube and a disk by a solid sphere.
solve Differential Equation : y"+4y=sin2x.
Recently I saw this question (http://www.mapleprimes.com/posts/141668-Partitions-Of-A-Natural-Number-Into-Factors). I want to find the divisors of a number, say 120, :
2,4,6,8,10,12,15,20,24,30,40,60,120
for the students but couldn't find a simple way for that expect the solutions in above link. Isn't an easier way to do this job in Maple?
Thanks so for the time
proc.mwf := proc (a) if a <= 0 then 0 elif a <= evalf(e*sin((1/2)*B)) then (-1)*2.005689708*a elif a <= evalf(2*e*sin((1/2)*B)) then (-1)*2.005689708*a+5.369606170 else 0 end if end proc; f(1)
why doesn't this evaluate to a numerical value when u supply an a value for 'a'.
can someone modify it......
I've plotted the solution to a GLM using the plot3d function, but a portion of the plot is irrelevant to the presentation of the results. I can define the portion of the plot I want to discard based on the x and y coordinates, but I've gotten errors for every if-then statement I've tried to include. Any suggestions on how to properly integrate an if-then statement into the syntax?
Aslam-u-Alikum... How are you? Hope you will be fine. I want to determine the eigenvalues of differential equation in Maple kindly help me... Problem.docx
g := proc (i)
if i = 1 then a else 0 fi
h := sum(g(i), i = 1 .. f);
The result is h:=0 instead of h:=a. What's wrong?
A number n is called a double if its base-7 digits form the base-10 number 2n. For example, 51 is 102 in base 7. What is the largest double?
Hi, I want to print     t[n] / (-1)^n * sum   as following, but I don't know where the error is. Please help me.
Thank you very much.
First 1584 1585 1586 1587 1588 1589 1590 Last Page 1586 of 2471
