This is perhaps a stupid question. It is quite easy to add a vector with minutes to 60 minutes. However, when I try to do this stating 1 hour instead of 60 minutes it does no longer do the calculation. Why is this? Thank you for any explanation.
QuestionMP.mw
In the example below, the second call to simplify is ineffective
eq := (a*x + b)/(c*x + d) = 1;
`simplify/nodenom`:= x -> (numer@(lhs - rhs) = 0)(x);
`simplify/nodenom`(eq);
simplify(eq, nodenom);
Why is that?
Convert, for example, works
`convert/nodenom`:= x -> (numer@(lhs - rhs) = 0)(x);
`convert/nodenom`(eq);
convert(eq, nodenom);
Let M a matrix of zeros and ones for instance.
N := 10^5:  # This is the order of magnitude I have to consider (10^4 may be enough if L is "small")
L := 5:     # L is between 3 and 8 in practice (see context at the end of this post)
M := LinearAlgebra:-RandomMatrix(N, L, generator=0..1):
Let C a set of colums of M and |C| the number of elements of C.
Let P a list of length |C| of  zeros and ones.
I want to count al the rows in M such that
`and`( seq( M[n, C[k]] = P[k], k = 1.. |C| ) )
For instance
pattern := n -> `if`(evalb(`and`(seq(S[n, C[k]]=P[k], k=1..3))), 1, 0):
t0 := time():
add(pattern(n), n=1..N);
time()-t0
                             12351
                             0.431  # seconds
This code appears to be quite slow when one consider that I have to run it for all the possible choices of C and P (the contect is detailed below).
Do you have any some ideas to improve the efficiency (in terms of computational time) of this counting operation?
The context:
Let A = {1, 2, .., L} and P(A) the power set of A.
I set Q(A) = P(A) \ ( { } union A}.
Let C and C'  two disjoint subsets of Q(A).
Example
# With L=3
Q(A) = { {1},  {2},  {3},  {1, 2},  {1, 3},  {2, 3} }
# if A chose C =
C = {2}
# Then C' is member of
C' in { {1}, {3}, {1, 3}
For any couple (C, C')  I want to do this
  1. Let |C| (|C'|) cardinal of C (resp C').
  2. Let us consider that members of C (resp C') "point to" the corresponding columns of M.
    for instance C = {2, 3} refers to columns 2 and 3 of M.
    As C and C' are ordered iI will write them indistinctely as lists (for instance C = [2, 3] in example above) when necessary.
  3. To a given |C| (|C'|) one may associate 2|C| (resp 2|C'|) sequences of 0 and 1.
    For instance,  to C = {2, 3} are associated sequences [0, 0], [0, 1], [1, 0], [1, 1].
    Let s(C) (s(C')) the list, or set, of 0-1 sequences associated to C (resp C')..
  4. For any couple (C, C') and any of the 2|C|+|C'| combinations (p, p') where p belongs to s(C) and p' belongs to s(C') I want to count the number of occurrences defined by:
    seq( M[n, C[k]] = p[k], k=1..|C|) and seq( M[n, C'[k]] = p'[k], k=1..|C'|)
    For instance, if C={2} and C={1, 3} I want to count the number M rows M such that
    p = [0], p'=[1, 0]
    M[n, 2]=0 and M[n, 1]=1 and M[n, 3]=0;
    p = [1], p'=[1, 1]
    M[n, 2]=1 and M[n, 1]=1 and M[n, 3]=1
    ... and so on
The computational time may ne quite large because of the number of possible couples (C, C') when L is large ( there exists  Stirling2(L+1, 3) such couples: already 90 couples for L=5  ... and 28501 for L=10).
I hope everyone is fine here. I want to write the following nested loop in my code
restart; TOL := 10^(-3); v[i] := 10^(-4); u[i] := 10^(-4);
if abs(v[i]-1)<=TOL then    if abs(u[i])<=TOL then break    else t[i+1]:=t[i]+alpha; else; fi; fi;
it is not working. If the first condition (v[i]-1)<=TOL is fulfilled, then we have to check the second condition, u[i]<=TOL. That’s why I don’t use “and” here. If both conditions are fulfilled, then stop the loop and if second the condition not fulfilled (but first fulfill) then t[j+1]=t[j]+alpha.
I shall be waiting for your positive response.
How to solve a ODE system using Newton's finite difference method?
How to plot f', theta and phi functions for various alpha values.
Difference.mw
I want all calculations in Maple code to be done with double precision. Using Digits:=18 and evalf greatly affects the calculation speed. But using the evalhf performs calculations much faster. The problem is that the evalhf cannot work with expressions that contain symbolic terms. For example, the evalhf(1/3*x+1/5*exp(-x^2)) generates an error. How can I perform calculations on expression with double-precision floating point without significantly slowing down the calculation speed? Is there a method that can be used at the beginning of the code to use double precision (preferably hardware) in all computation steps without slowing down the computations, unlike software floating-point computations?
Best wishes
Digits:=18;
evalf(1/3.);
evalhf(1/3.);
str:=time[real]();
for i from 1 to 100000 do
evalf(sqrt(3)*i):
time[real]()-str;
str:=time[real]();
evalhf(sqrt(3)*i):
time[real]()-str;
I have the following algebraic function. In vibrations, it is common to write the functions exp(alpha[i]*I*t) as separate terms of cos(alpha[i]*t) and sin(alpha[i]*t). While exp(-beta[i]*t) remains without converting to sinh and cosh. How can I find the solution given for T(t) as the sum of terms C1[i]*sin(alpha[i]*t)*exp(-beta[i]*t) and C2[i]*cos(alpha[i]*t)*exp(-beta[i]*t) with non-complex (real) coefficients C1[i] and C2[i].
Can anyone help me to achieve my goal in the following expression?
T(t):=(1.450761945*10^(-11) + (3.836655196*10^(-14))*I)*exp((-0.5000000000 + 222.6866468*I)*t) + (-3.770333746*10^(-9) + (2.179000257*10^(-6))*I)*exp((-0.5000000000 - 924.5904413*I)*t) + (-2.584086158*10^(-12) + (4.273321932*10^(-13))*I)*exp((-0.5000000000 + 326.7549627*I)*t) + (1.986287340*10^(-9) + (1.330623218*10^(-11))*I)*exp((-0.5000000000 - 74.63720909*I)*t) + (-5.980910367*10^(-12) + (5.816480027*10^(-11))*I)*exp((-0.5000000000 - 453.7574402*I)*t) + (1.450761945*10^(-11) - (3.836655196*10^(-14))*I)*exp((-0.5000000000 - 222.6866468*I)*t) + (8.923968224*10^(-10) - (8.844466162*10^(-9))*I)*exp((-0.5000000000 + 637.9999953*I)*t) - (1.217986141*10^(-10) + (4.431771836*10^(-13))*I)*exp((-0.5000000000 - 138.7904660*I)*t) + (-1.217986141*10^(-10) + (4.431771836*10^(-13))*I)*exp((-0.5000000000 + 138.7904660*I)*t) + (0.0002537882980 + 0.00002277791755*I)*exp((-0.5000000000 - 5.570928456*I)*t) - (3.770333746*10^(-9) + (2.179000257*10^(-6))*I)*exp((-0.5000000000 + 924.5904413*I)*t) + (-0.0001618723219 + 0.01288449595*I)*exp((-0.5000000000 - 1638.001654*I)*t) + (8.923968224*10^(-10) + (8.844466162*10^(-9))*I)*exp((-0.5000000000 - 637.9999953*I)*t) + (-1.153529195*10^(-7) + (1.908444485*10^(-9))*I)*exp((-0.5000000000 + 30.22171212*I)*t) - (1.153529195*10^(-7) + (1.908444485*10^(-9))*I)*exp((-0.5000000000 - 30.22171212*I)*t) - (0.0001618723219 + 0.01288449595*I)*exp((-0.5000000000 + 1638.001654*I)*t) + (1.986287340*10^(-9) - (1.330623218*10^(-11))*I)*exp((-0.5000000000 + 74.63720909*I)*t) + (0.0002537882980 - 0.00002277791755*I)*exp((-0.5000000000 + 5.570928456*I)*t) - (5.980910367*10^(-12) + (5.816480027*10^(-11))*I)*exp((-0.5000000000 + 453.7574402*I)*t) - (2.584086158*10^(-12) + (4.273321932*10^(-13))*I)*exp((-0.5000000000 - 326.7549627*I)*t);
I have the given expression f as follows. I want to extract terms with sin, sinh, and exp in this expression. For example, for sin, cos, sinh and exp, I want the outputs to be -4*sin(x), -5*cos(x^3)*sin(y^2), 5*sinh(x^2) and 2*exp(y^2), respectively. Also, if I want to get terms having sin(x) and sin(y^2), I like to receive -4*sin(x) and -5*cos(x^3)*sin(y^2), respectively. And also, for terms including sinh(x^3), I want to get Void output. The above goals cannot be achieved with the following commands. Can anyone help me?
f := -4*sin(x) + 2*exp(y^2) + 5 - 5*cos(x^3)*sin(y^2) + 5*sinh(x^2);
indets(f, trig);
selectfun(f, exp);
selectremove(has, f, trig);
Multiplaction "dot" in Maple 2022 is way too small - causes errors.
e.g. two variables multiplied s*m ends up being sm a new variable as I cannot really see that there is a missing multiplication operator between the variables. This causes huge unnecessary errors.
Maple 9.x e.g had nice clear and big operators and this kind of error was avoided.
How can I undo this unfortunate regression in Maple 2022 to increase the size of multiplication operator and other operators, so that they actually becom visible and not just a little dot almost a pixel in size.
If I was a falcon (20x20)^infinity then this would have been ok, but I am not, I am human.
So how do I change this unfortunate regression so that these errors can be avoided.?
It was found on the social networks of the WM group. Written in Python. Perhaps someone would like to adopt it.
Deal All,
I have a system of linear differential equations with unknown functions T[1](t) to T[n](t). In the attached example, I considered the value of n equal to 10, but depending on the problem, the value of n may be higher. Maple is not able to solve this problem analytically with the ‘dsolve’.
Does anyone have an idea to analytically solve for such a set of linear differential equations?
Best wishes
Set_of_Linear_DEs.mw
See attached worksheet in Maple 2023.
This example is taken from the Maple help page. I want to 'zoom in' on a plot3d object. The only way I have found was from responses [1] on the maple primes forum. It uses InlinePlot and the scale option to perform the 'zoom in'. Since InlinePlot generates the plot in terms of XML there is no graphic out, only a text based output. In order to reconstitute the InlinePlot as a plot object I can view visually I need to use some additional commands from the DocumentTool package. This is all great but the output, which in our case is P3, is not a plot object and therefore cannot be exported as a png. Is there a way to convert the InlinePlot with the scaling applied back to a typical plot object so I can export it as a .png, using Export("output_plot.png",P3,base=worksheetdir)?
can_I_convert_InlinePlot(P3)_back_to_a_regular_plot_object_so_I_can_export_it_as_a_png.mw
When I try to contract the tensor with connection, maple encounters such promble:
Error, (in DifferentialGeometry:-Tensor:-ContractIndices) expected 2nd argument to be a tensor. Received: _DG([["connection", O, [["con_bas", "cov_bas", "cov_bas"], []]], [`...`]])
The expression is Cacd Hab
I try to solve triple integraton in Maple with this code.
r := a + (b - a)*z/h;
x1 := sqrt(r^2 - y^2);
V := int(int(int(1, x = -x1 .. x1), y = -r .. r), z = 0 .. h);
but it leaves the last integral dz in the answer and warns: unable to determine if a*h/(-b+a) is between 0 and h; try to use assumptions or use the AllSolutions option
What is the problem?
and i need to get V = Pi*h(a^2 + ab +b^2)/3
Why does Maple 2022 still have only a history of ten files in the Recents ?
It makes it very difficult to search for files you opened but only realised later you need, but then it is long out of the silly 10 history list.
Isnt there a way to make a perpetual list so that all files opened are saved chronologiacally against date, or... at least be able to increase the silly 10 recent files to something like 30
First 109 110 111 112 113 114 115 Last Page 111 of 2430
