Hi, I have 2 columns A and B of random numbers each of length N drawn from the same distribution ( I am using a normal distribution but even an uniform distribution will do ). How do I check using Maple that the 2 dimensional random numbers generated as the 2-tuple {A[i],B[i]} (i=1 to sample size N ) are good quality random numbers.
Hello! I have a quasilinear first-order PDE system and Maple gives me only the trivial zero-solution after some seconds of computations. I know from theory that there are nontrivial solutions to the PDE, too. Can I get them somehow (from for example Maple)? This is the PDE: PDE := {diff(alpha[1](u, v), u) = -I*exp(I*u)*beta[1](u, v), diff(alpha[1](u, v), v) = -I*exp(-I*v)*beta[2](u, v), diff(alpha[2](u, v), u) = I*exp(-I*u)*beta[2](u, v), diff(beta[2](u, v), v) = 1/4*I*exp(I*u)*alpha[2](u, v)+1/2*I*exp(I*(v+u))*beta[1](u, v)+1/2*I*(beta[2])(u, v), diff(alpha[2](u, v), v) = -I*exp(I*v)*beta[1](u, v),
I'm having trouble performing what I had supposed was a simple calculation. I'm trying to calculate pairs of values that lie on the binodal (liquid-gas coexistence) curve of the van der Waals phase diagram. I have an equation, that I need to solve for the two variables vg, and vl, based on two constraints. Unfortunately, while the code I have written returns answers, they are wrong, and do not even satisfy the constraints. My code is below - I'd be exceptionally greatful if someone could point out what I am doing wrong, or suggest a better way. > kbd := 1: > bd := 0.5: > ad:=2:
How do I programmatically save the output of "C" code generation to a "cpp" file? I am doing all of these in Matlab via the Maple engine, which is version 10, I guess. I cannot seem to do "writeto" redirection here, because Matlab doesn't allow that I guess. And I like to use "fprintf" because it gives me more control of the code that is generated... If it works, I no longer need copy and paste.. But it didn't work at all. There was no error message, but the file was empty... Can anybody tell me why? Thanks! -------------------- fd:=fopen("trygenC.cpp", WRITE, TEXT)
Hi, It appears that maple has some sort of internal memory restriction, which sometimes causes it to stop during a computation with the following error message: Maple was unable to allocate enough memory to complete this computation, see ?alloc ..." Browsing through ?alloc, it appears that there's a way to increase this "software limit" , using something they call a "-T cl argument" but I was not able to find just how to go about it. Any idea how this could be done? thanks
bb:=proc(aa, n) add(add(aa[j][k], j=0 .. 5), k=0 .. n) end proc cc:=prep2trans(bb) dd:=C(cc, optimized) ??? Error using ==> maple at 129 Error, (in codegen/C) Unable to translate this subscript into C aa[i2][i1] -------------- I don't understand...
Hello everybody. I'm a newbies here. I would be glad if anyone of you here could please help me to create a maple code to perform a full pivoting where it permits both row and column exchange.The code is to be used to any kinds of nxn square matrix..Thank you..:)
I recently upgraded to Microsoft Excel 2007 and have tried unsuccessfully to tie in to Maple through the ADD-IN function within Excel. A note at the bottom of the spreadsheet says "Initializing Maple..." but nothing happens and the sheet locks up. Any suggestions?
looking for the fastest complex number arithmetics... Hi all, I am looking for the fastest complex number arithmetics. There is one part of my program which needs complex number arithmetics. The final result is a real number. So I had two choices: (1) Using the C++ class, and do all the operations in complex domain, and finally extract out the real part of the result. (2) Calculate the real part of result in closed-form by hand, and program everything in C/C++ in real domain. I used to do (2). And I used Maple to help me obtain the real part of the complex-valued expressions in closed form and generate the C code. The speed is about 10x faster than (1).
f := piecewise( is(floor(x)::odd), 1, 0 ): seq( f(n), n=-5..5 ); plot( f, -5..5 ); produces (Maple 11) the expected output (sequence alternates 1 and 0 - plot is a square wave). Replace the definition of f by f := piecewise( floor(x)::odd, 1, 0 ): and the seq command still operates as expected but the plot shows f=1 between 1 and 2 but otherwise 0. Does anybody know what is going on here? It's probably not important but I am confused. Toby
Hi folks! Does anybody know if Matlab and Maple and Mathematica works well and stable on Vista? How about speed on Vista? Thanks!
Suppose I have two lists of equal length, namely List1 and List2, whose elements are numbers from the list M=[0,.1,.2,.3,.4,.5,.6,.7,.8,.9,1]: Both the lists have to satisfy following condition: List1[x]+List2[x]
I have been attempting to use Maple 8 to compute the limit of a function defined by a procedure (rather than as a piecewise function). For example, consider the following procedure. f := proc(x) if is(x,numeric) then if x > 1 then 1; elif x <> returns undefined. limit( f(x),x=1,right) --> returns undefined. When I use a piecewise definition, all is well: f := x->piecewise( x>1, 1, x
Sorry, but I don't understand why Maple produces two different answers. (I make many analysis calculations, some expressions [math functions] come directly, e.g. 5x-3, some by Maple e.g. by series command.)
s:=x-1/2*x^2+1/3*x^3+O(x^4);
                               1  2   1  3    / 4\
                           x - - x  + - x  + O\x /
                               2      3
t:=series(ln(1+x),x,4);
                               1  2   1  3    / 4\
                               2      3
nops(s);
My laptop is broken and I am seriously considering purchasing a new laptop. I mainly use the laptop to do all kinds of programming, including Matlab, C/C++, Fortran, Maple, Mathematica, etc. I am wondering if anybody can tell some experiences about speed performance of Maple on Core Duo Dual Core processors? Are the computations on these computers really faster? I recall a few months ago I had tested a Monte Carlo program in Matlab on my friend's new Intel Quad Core (4 cpus). He paid $6000 for a desktop like that. The speed was not improved at all.
First 2312 2313 2314 2315 2316 2317 2318 Last Page 2314 of 2431
