Hello, I have a simple problem of the type; x = L(x)*x Where x is a column vector (2) and L(x) is a 2 by 2 matrix (function of x). I want maple to solve this equation for x. I just don't know what is the function to do this ("solve" doesn't work).
how can i import data from an excel spreadsheet into maple10? (please don't tell me i can only to it with maple11). cheers, jake
Hi, I am using the networks package to try to find out the total number of paths between two vertices of a graph. The graph I am interested in is basically a square grid with a diagonal from the lower left to the upper right. I want to find the total number of paths from the lower left vertex to the upper right vertex according to the following rules. 1. Can only move right 2. Can only move up 3. Can only move up the diagonal. So I wrote a procedure that would produce such a directed graph for any n. For any n the graph has n^2 vertices but only edges that meet the criterion given above.
I have a sheet in Maple 10 which I want to re-run in Maple 11. It contains a very lengthy (piecewise defined) function f(m) to be integrated over the Reals (numerical) and dito for exp(m)*f(m). The results are certainly ~ 1. In M10 this caused problems which can be overcome using method= _NCRule (I got the advice here ...) in both the cases, the result came up fast. In M11 I killed the execution, it needs to long. While integrating f(m) can be done by the NAG routines, that does not work for exp(m)*f(m). Certainly I could split up at the breaks for piecewise - but can somebody explain *why* it 'fails' now? And: no, I do not want to split up manually.
Set up a double loop in maple with the parameter "a" runing from 0 to 2 in steps of 0.02 and b running from -1 to 1 in steps of 0.02. Within de double loop set, set X0=a+b*I and compute 10 Newtons iterates. If X10 is close to 0, say absolute value of X10<0.1 then the iterates converge to 0. Color the pixel at (a,b) black if the iterates converge to 0 and white if not.
"Note": The equation to be set is X^3-3*X^2+2*X
Please help me in here, is due to tomorrow, and I've been trying all this week but I don't have any clue.
Best Regards,
Franklin...
Hello, I am new to Maple (I am used to Mathematica 5.2). I have a differential equation which can be solved numerically (evolution of the scale factor of the Universe containing matter, radiation and dark energy). I've figured out how to use the interactive dsolve() to produce two dimesional plots of R vs. t, yet I'd like to make a nice 3D plot (in cylindrical coordinates) with [R ,R ,t] axes. Having a symbolic solution I would use Mathematica with something like: ParametricPlot3D[{R[t] Cos[x], R[t] Sin[x], t}, {t, -1, 3}, {x, 0, 2Pi}]; In the interactive dsolve() mode Maple offers 3-D plot but it is not what I want...
Could someone help me please to incorporate the command for unique common solutions into a programme. I have a list of values a and b where x ==a(mod e) x==b(mod d) I have the following list of [a,b] pairs: [[0, 0], [1, 1], [0, 2], [1, 3], [0, 4], [1, 5], [0, 6], [1, 0], [0, 1], [1, 2], [0, 3], [1, 4], [0, 5], [1, 6], [0, 0]] I now need to write a procedure where I apply the following command: chrem([a,b],[e,d]) to find the unique common solutions for the listed pairs of a and b. for example chrem([1, 4], [2, 11]) = 15, where e (e=2) and d (d=11) are coprimes. Any hints on how I use each pair of a and b from the above list to generate a list for unique solutions using the chrem command would be most welcome.
Hello everybody, In the following code I wish to print a 6*N table. When I let the array run from 1..5 everything works fine. However I wish to run it from 0..5 as shown below. Once I do so the output looks completely messed up. Whats the matter with starting the array from 0? > mu := 'mu': > mu := array(0 .. 5, 1 .. N): > for n to N do > for S from 0 to 5 do > mu[S, n] := lambda[n]*baseleadtime[S] > end do; > end do; > print(mu); THX in advance.. Fred
It would be great if someone could give me a lead on this: I have 3 sets: A={1,3,4,8}, B={5,6,9}, C={2,0,7}. Is there a command in Maple that can produce all possible combinations of all numbers involved in 3 sets so that I could get the following result: [A1,B1,C1], [A2,B1,C1], [A3,B1,C1], [A4,B1,C1], [A1,B2,C1] etc I have tried the following but the result is: > comb(({1, 3, 4, 8}, {5, 6, 9}, {0, 2, 7}), 3); print(comb({1, 3, 4, 8}, {5, 6, 9}, {0, 2, 7}, 3)); comb({1, 3, 4, 8}, {5, 6, 9}, {0, 2, 7}, 3) thanks...
Hello I am trying to plot the same function over several different values for comparison. My problem is that whenever a plot is drawn, the axis is rescaled to fit the contents, for example in the following code > restart; > ReZ:=sin(omega); ReZ := sin(omega) > ImZ:=cos(omega); ImZ := cos(omega) > plot([ReZ,ImZ,omega=0..0.5]); > plot([ReZ,ImZ,omega=0..1]); The axis values differ, but the plots look exactly the same, which makes it very hard to compare them. I haven't been able to find a way to define the axis ranges i need so any suggestions would be appreciated
is there a reason this doesn't solve? (1/m)(int(b*t*(t[o]-t), t = 0 .. T)) it just spits out (int(b*t*(t[o]-t), t = 0 .. T))/m which isn't helpful...
I hope someone can help me. I am using Maple 10 to make a model of some of my research on fruitfly dorsal-ventral formation. I am far from a math and maple expert, so i hope someone in here can help me. I have plottet my data with pointplot3d and need a function i can fit to to my data. Have tried with one time-frame at a time, using fit[leastsquares], but don't get a good result. Have a lot of "noise" on my measurements, that probably wont give a good result, I therefore need a full 3d fit. The data seen from (y,z)-axis is increasing "shark-fin" pattern: .............................................xxxxxxxxx
I hope someone can help me. I am using Maple 10 to make a model of some of my research on fruitfly dorsal-ventral formation. I am far from a math and maple expert, so i hope someone in here can help me. I have plottet my data with pointplot3d and need a function i can fit to to my data. Have tried with one time-frame at a time, using fit[leastsquares], but don't get a good result. Have a lot of "noise" on my measurements, that probably wont give a good result, I therefore need a full 3d fit. The data seen from (y,z)-axis is increasing "shark-fin" pattern: ....................................xxxxxxxxx
hi all, i have an equation like this: a = Lambda[d]/(Lambda[d] + Lambda[in]); P(0, 0) = 1/(k + (Lambda[in] / Mu[in]) * (k - 1) + (Lambda[in] / Mu[m]) * (k - 1) + a* ((1 - a^(n - k)) / (1 - a)) + (Lambda[in] / Mu[in])* a * ((1 - a^(n - k)) / (1 - a)) + (Lambda[in] / Mu[M]) * a * (( 1 - a^(n - k)) / (1 - a)) + (Lambda[d] / Mu[D]) * a^(n - k)) Availability (A) = P(0,0)*(k + (a * (1-a^(n-k)))) i want to find the optimal Lambda[in] which max the A.. is there any non-numeric solution way and plot A-Lambda[in] graph?
I have benn assigned to do this: Set up a Double Loop in Maple with the parameter "A" running from 0 to 2 in steps of 0.02 and "B" running from -1 to 1 in steps of 0.02. Within the double loop, set Xo=A+BI and compute 10 Newton's Method Iterates. Now I don't have a clue how to solve it but I have been trying, It seems to me that I always head to a dead end solution.... By recommendation I have done this but I get stuck; I don't know how to do the double loop from this domains. I'm gonna write it down or if you want you can see it with the link below. > restart
First 2337 2338 2339 2340 2341 2342 2343 Last Page 2339 of 2431
