Hi there! I have a system of four non-linear equation that I can solve with fsolve after having provided the parameter values. I wrote a procedure which passes the parameters values, define all the equations and call for fsolve which provides the solution value for all the four unknowns. Now, I would like to plot each solution against the input parameters passed to the procedure. In other words, I want to make some comparative statics which shows as the solution changes as the parameters change. Of course, I'll make only two parameters varying simultaneously. I tried plot3d, but it doesn't work, because the procedure is not really a function I guess.
Hello, I just attempted to upload a .gif file of less than 10 kilobytes, and got an error message indicating that the file was too large to upload. Can I assume that this is a temporary problem that will be fixed ?
Hi, I have a 11x12 Matrix, that I would like to see all the elements of in "2D output" Is this possible? Rolf
I want to find inverses of polynomials in the ring Z/nZ with the convolution multiplication rule X^n - 1 = 0. That is I want to find inverses, do multiplication in the polynomial ring Z[X]/(X^r - 1) mod n. Can maple do this?
I am using the Maplet Builder. I created the first example in the Advanced examples. I forgot to set the 'pause' to 'value'='true'. I had to leave Maple. I came back later expecting that I could open the maplet in the Builder and continue, but the Builder responds 'discard current content? yes no'. If I say yes, I get a blank maplet pallet; if I say no I get nothing. So I opened the text of the maplet and added 'value'='true' and then ran the maplet. It ran fine. But when I tried to open the maplet in the Builder, it said that an exception had ocurred. What am I to do?
The attached file solves a system of equations in a couple of seconds in maple 9.5 But in classic worksheet maple 10.04 after many minutes it gobbles up gigabytes of memory and then ends with an error. The file belows shows the details but it has the form sys:={eq1,...eq22}: solution:=solve(sys,{var1,...var22}): Any comments very much appreciated. Download 2129_No Solve.mws
i have a equation such as : f(qa)= 75-0.4*qa^1.5 i would like to know how to know the maximum of qa when qb is 0 and vise versa. also how to plot a slope a a given point for example qa = 0 or 20.
Hi, My name is Jennifer.Iam new to Matlab programming.Iam working on reducing the noise content in audio communication. Iam using Hamning codes for the same.I have a sample code with me,which iam unable to upload because it says that maximum file size exceeded.Iam unable to understand how it works.Can someone please explain me how the code is written,what it means and what the different plots mean and how to read them? I have trouble especially with the plots trying to understand them. Being a beginner,Iam having a lot of trouble trying to understand.Iam trying to read Matlab tutorials at the same time but I have to finish up this work soon before the deadline.So can anyone be kind enough to help me through this please? My email id is jennifer22cute-single at yahoo.com
hi! i need your help, i am a student of economics and i have to solvean exercise in maple but i can't do the last point;i have stopped just at the end of the exercise! please if anyone can do it orgive a help how to solve it i will very grateful.the exercise is how to calculate the days between two dates.i can't attach the file because the total file exceeded thank you
How do i make a curved arrow in maple 9.5 to show a rotaton arround an axis in a plot?
I have a maple worksheet (attached) that calculates a 2-D convolution. Should be easy, I would guess. The convolution of a gaussian and a gaussian is very fast-- this has a simple analytical result anyway. A gaussian and a sinc function can take a couple of minutes... and a gaussian and a bessel function takes longer than I can allow! I think I must be missing something here. I've tried various things, interchanging "int" and "Int" for the integration, and also seting digits to something low, by using evalf[4]. Sometimes it just maxes out all available memory before grinding to a halt, in other trials it will allocate about 300 MB and churn for hours. The worksheet is attached. I'd appreciate the advice.
Do any of you have any graphics software suggestions for adding lines, text, etc. in EPS plots generated by Maple? I have have mainly only used Photoshop for editing plots while working with LaTex, but I have increasely become dissatisfied with the results. Any suggestions? Thanks, Phil
> procA :=
proc ()
print ("Hello");
2;
> procB :=
proc ()
local i;
i := procA();
> procA ();
"Hello"
> procB();
"Hello"
The main that I want to get is:
if it was executed procA, it should show "Hello" text and the 2 number, but if it was executed procB, it should show only the 2 number, it shouldn`t show "Hello" text.
What can I do to get this special result in procB?
I am trying to ease my c coding work with the "CodeGeneration" tool in maple. The Idea to generate ready to use functions is quite thrilling.
In my attempts to generate code I entontert two problems.
First it seems to be impossible to assign local vectors to vectors passed in the argument list:
> MapX := proc (X\_out::Vector(2), X\_in::Vector(2), PRO2RO::Vector(2))
> local X\_t :: Vector(2,0), i;
> X\_t[1] := PRO2RO[1];
> X\_t[2] := PRO2RO[2]*10;
> X\_out := X\_in + X\_t;
> return;
> end proc;
here the assignment X\_out := X\_in + X\_t; is not recognized.
Hi, is it possible to define a variable for example "x" upon which it depends whether an execution group in a worksheet will be excecuted when clicking on !!! (Execute whole worksheet) or not? Illustration of the idea: x:=1; if x=1 then execute execution group else do nothing end if; I am thankful about any ideas!
First 2382 2383 2384 2385 2386 2387 2388 Last Page 2384 of 2430
