Consider an easy example of a table.
myTable:=table(["a"=1,"b"=-1,"c"=1]);
We can give an index to it and get its corresponding entry if exists.
myTable["b"];
We can also get the set of all indices, or the set of all entries. But what about receiving the index or set of indices with a specific entry. for example asking what indices have the entry `1`?
Of course I can define a search procedure myself, but I thought there might be an efficient way which is already implemented as a function/method on tables.
Good afternoon. How do I disable the numbering of _Z constants? Because
of this, you can't use the procedure in a loop
Is it possible to disable numbering or do something else?
restart; with(linalg); t := 3
S := proc (a, b, z) local L, y, s1, s2, sist, chl, lambda1; L := diff(y(x), x, x) = lambda*y(x); assume(lambda < 0); dsolve(L, y(x)); y := unapply(rhs(%), x); s1 := y(a) = 0; s2 := y(b) = 0; sist := {s1, s2}; genmatrix(sist, {_C1, _C2}); det(%); chl := combine(%); _EnvAllSolutions := true; solve(chl); sort(%); lambda1 := subs(_Z1 = k, %); print(lambda1); lambda1 := unapply(%, k); lambda1(z) end proc:
S(0, Pi, 3);
Warning, solve may be ignoring assumptions on the input variables.
-k^2
-9
for i to t do S(0, Pi, i) end do:
-_Z2^2
-_Z3^2
-_Z4^2
Download help.mw
This is new exception generated by Maple pdsolve in 2021. Different from the last post I gave on pdsolve. So I thought it will be better to keep them separate since the causes are different.
interface(version)
pde :=  diff(w(x,y,z),x)+(a1*x^n1*y+b1*x^m1)*diff(w(x,y,z),y)+(a2*x^n2*y+b2*x^m1)*diff(w(x,y,z),z)= 0;
pdsolve(pde,w(x,y,z));
#another example
local gamma:
pde := diff(w(x,y,z),x)+(a1*x^n1*y+ b1*x^m1)*diff(w(x,y,z),y)+(a2*x^n2*y+b2*x^m2)*diff(w(x,y,z),z)=c2*x^k2*y+c1*x^k1*z;
Error, (in GAMMA) numeric exception: division by zero
The same PDE works in 2020.2. The answer it gives is large so will not show it all below.
Screen shots
Maple 2021
Maple 2020.2
All on windows 10.
Do other see the same error? What causes it?
4 %+ 3 %* 2;
                        %*(%+(4, 3), 2)
= (4+3)*2
It makes using % very difficult in complex expressions because one has to constantly use a ton of paranethesis just to get things to work out.
1 + 4%^3  %* 2 %- 6 %/ 4;
1 + ((((4 %^ 3) %* 2) %- 6) %/ 4)
= 1 + (4^3*2 - 6)/4
I noticed number of pde's now fail in Maple 2021 with the error
          int/gbinthm/structure INVALID subscript selector
but they do not fail in Maple 2020.2.
Here are few   examples
pde :=a*x^n*diff(w(x,y),x) + n*x^m*y*diff(w(x,y),y) =s*x^p*y^q+d;
pdsolve(pde,w(x,y));
pde :=a*x^n*diff(w(x,y),x) + n*x^m*y*diff(w(x,y),y)=c*x^k*y^s+d;
pdsolve(pde,w(x,y))
pde :=a*x^n*diff(w(x,y),x)+b*x^m*y*diff(w(x,y),y) =  (c*x^k*y^s + d)*w(x,y);
pdsolve(pde,w(x,y))
pde :=  a*diff(w(x,y),x)+ y*diff(w(x,y),y) = b*w(x,y)+ c*x^n*y^m;
pdsolve(pde,w(x,y))
#etc..
Error, (in int/gbinthm/structure) invalid subscript selector
While in Maple 2020.2 they all work. Screen shot
Maple 2021
Maple 2020.2
Any idea why this happens? Do others see the same error?
How to define n-dimensional metric for arbitrary n in Physics package?
I would like to compute the euler-lagrange equations using the index notation in quantum field theory. So for example given the Lagrangian here:
Is there a way to derive the Euler-Lagrange equation in maple?
I've experienced problems a couple of times when trying to save a workbook in Maple 2021.
At first I thought it was due to a unstable VPN connection, but this also happens on a local drive.
Consider the following example:
>> Maple express the second derivative of Legendre polynomial as
This form cannot, for instance, be integrated if we set n, for example, to 2.
i was wondering whether there is a trick to force Maple to express those derivatives in term of P_n using the relevent recurrence relations. This will help for further manipulations.
Thanks a lot!
Heinrich,
I have a 2688x1 matrix of ground acceleration data that I converted to a forcing function F (also a 2688x1 matrix) that I need to evaluate using duhamels integral. Since the forcing function can not be represented my a real expression numberical integration is required. Am needing to write a loop as seen on bottom of attached picture. Essentially to perform trapezoidal rule to return  structural motion (u).
Am looking for advice on how to write this loop in Maple.
I have attempted the for program in Maple per below with;
[F]:= Forcing Matrix
[t]:= time step matrix
Assigned initial conditions sim to pic below
for i from 1..2688 do
added the functions sim to bottom of pic for Ai, Bi, and ui
end do
This is just an obervation. May be due to me missing some clarification.
My understanding is that in Maple 2021, one can now export a complete Maple worksheet/document to Latex successfuly.
According to https://www.maplesoft.com/products/maple/new_features/  it says under "Latex export"
  Export is available for individual expressions or the entire document, though the latex command
So I would have expected that now all the online PDF documents for the new features in Maple 2021 to be generated from Latex for better formatting.
But when going over number of documents, they do not appear to have converted to Latex before generating the PDF.
Even the PDF document about the new latex command does not appear to have been generated from Latex. I can quickly recognize a PDF that was generated from Latex, and these PDF files are clearly not.
Looking at sample PDF from Maple website, it says the generator is "iText" and not latex compiler.
It looks like these documents were just a direct export of the Maple worksheet to PDF, instead of being exporting to Latex first, and then compiled to PDF.
Am I missing something? Why not take advantage of the Maple Latex export, and convert all the documents to Latex first and then generate the PDF from Latex? This would make them look much better in terms of formatting and math rendering.
Here are some examples
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/AdvancedMath.pdf
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/ODEsandPDEs.pdf
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/GraphTheory.pdf
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/Physics.pdf
  https://www.maplesoft.com/products/maple/new_features/Maple2021/PDFs/LaTeX.pdf
Why did not Maple documentation take advantage of the new export command of Maple's latex command? This would also have been a good way and an opportunity to show case the effectiveness of the new latex export command.
May be it was not done due to time constraint before the release date of maple 2021? Or are there other technical reasons?
How to draw a streamlines by using stream function provided in pdf. In the presence and absence of lambda parameter.
please help me to obtain graphs
1.pdf
Download 1.mw
This does not work with Maple 13. Can I still do something like this just using the linear operator D?
g:=x->x^(1/3);
f:=x->convert(g(x),surd);
D(f)(x)???
I need the derivative D(f)!!
Thank you!!!
mapleatha
Hi Mapke experts,Here is my try to solve the integration
int(x-t)^(-alpha)*a(t-bln(t+b/b),t from 0 to x)
I found it complicated to solve it symbolic, so \i try this:
assume(t,real):
x[0]:=0:a:=-0.1:alpha:=0.5:h:=0.001:b:=Gamma(2-alpha)/((1-alpha)*Gamma(1-alpha)):
for n from 0 to 0 do
t[n]:=n*h:
vo:=a*(x[n]-b*(ln((x[n]+b)/b))):
uo:=a*(t[n]-b*(ln((t[n]+b)/b))):
u1:=(int((x[n]-t[n])^(-alpha)*uo,t[n]=0..x[n])):
S[n]:=vo+u1:
data:=[seq([t[n],S[n]],n=0..100)]:
First 433 434 435 436 437 438 439 Last Page 435 of 2432
