I want to make a procedure that takes a function as an input, but everything I've tried has turned the function into a string.
This is what I want to do.
newtons := proc( f::function, x, n::integer)
But when I try and use the the function f that I defined, it just gets treated like a string or something. I can't put variables into it, I cant evaluate anything from it.
How do I get proc to see f as a function?
There are some answers up here, but they are for given known functions.
I need to place parentheses around functions that are automatically created.
For example, the function $f(x)$ takes many polynomial values during the execution
of a procedure. For examplle, it takes the values, 2x-1, x^2+3x+2, x^3-2x-3, etc.
How do I automatically place parentheses around these polynomials?
mapleatha
I have this problem to my system:
sol := pdsolve(sys2, {bcs, ics}, numeric)
sol:-plot3d(u1(x, t), x = 2 .. 3.2, t = 100 .. 1000)
Error, (in pdsolve/numeric/plot3d) unable to compute solution for t>HFloat(0.0):
unable to store HFloat(undefined)+HFloat(undefined)*I when datatype=float[8]
It is 1 pde and 1 ode.
What can I do to solve it?
Best
Dear Maple community,
I am trying to solve a system of linear equations, each of which is homogenous of degree 1 (i.e., defined up to a scale/constant factor), and was wondering whether one can use Maple to solve for ratios of variables (defined relative to a numeraire). An example of my problem is attached (Example.mw). More specifically:
- Equation (1) defines the system,
- Equations (2) through (4) exemplify the system for J=3 and S=1 (creating the system of 3 equations in 3 unknowns: {dlog R[1,1], dlog R[2,1], dlog R[3,1]},
- Function A solves this system for the unknowns and the subsequent commands simplify dlog R[1,1] (and dlog R[2,1]) using the model's constraints (side relations). Not surprizingly, I get the error message "Error, (in simplify/siderels:-Recurse) indeterminate expression of the form 0/0", which results from the fact that the system is homogenous of degree 1 (and, hence, each dlog R is defined only up to a scale),
- However, in principle, it should be possible to choose one of the dlog R's, say, dlog R[1,1] as a numeraire and express the other two "unknowns" (dlog R[2,1], and dlog R[3,1]), relative to it, in order to ultimately solve this system for dlog R[2,1]/dlog R[1,1] and dlog R[3,1]/dlog R[1,1] as functions of exogenous variables only.
I'd appreciate any advice how I can use Maple to tackle this problem. Thank you very much in advance!
There is issue with saving big numbers to txt file on WIndows
Please look at the file:
txt_issue.mw
Function save just cutting a big number.
Hi, Maple seems to automatically sort my list in some numerical order. Is there a way to overcome this? I want my list as it is.
I'm trying to calculate the convolution of the radiation forve in the time domain. I need to do a state space representation of a function K(t), where :
t=[0; 1; 2; 3];
k=[0.1; 0.2; 0.3; 0.4];
If you could help me with finding the appropriate command that give the matrix A, B C and D
just a remarque that in matlab used imp2ss (based on the Hankel SVD method)
Hello there,
Is there any way to make the equation 'Given_eq_3_37a' in the calculation below to be 'desired'?
Perhaps, the issue of the 'L__1' and '1/L__1' might have been in the way, but perhaps that might be overcome in a different way.
Thank you,
In Kwon Park
Given_eq_3_37 := M = k_ * sqrt(L__1 * L__2);
M = k_*(L__1*L__2)^(1/2)
Given_eq_3_30 := k_ = sqrt((L__m)^2 / (L__1 * L__2p));
k_ = (L__m^2/(L__1*L__2p))^(1/2)
Given_eq_3_37a := simplify(subs([Given_eq_3_30], Given_eq_3_37));
M = (L__m^2/(L__1*L__2p))^(1/2)*(L__1*L__2)^(1/2)
desired := M = sqrt(L__m^2/(L__1*L__2p)*(L__1*L__2));
M = (L__m^2*L__2/L__2p)^(1/2)
Download Q20201001.mw
I am trying to construct a controler for a UR5e robot, I have a simulation of the robot in maplesim and have started to look for a way to use multibody analysis to provide me with the Jacobian. However it only provieds the constraint Jacobian and as I have no position constraints on the robot, it returns nothing.
I then came across
Link: https://www.youtube.com/watch?v=d3xJge_09E0&t=374s
However it is old and does not exactly say how to do it.
So I thought I should ask this wonderful comunity if they have an recomended way to construct the Jacobian from a maplesimmodel? I am still a beginner at maplesim and maple so any help is appreciated.
With thanks for helping me
Eric Ragnarsson
Hello everyone. I want to know how I can extract terms from a multivariate polynomial with the following 2 conditions:
  1. It should have the lowest sum of the degree of x and of y; and
  2. deg(x) - deg(y) should be either 0 or -1.
For instance, if I've f(x) = 100x^2y^2 + 35yx + 45x, I want an output of 35yx (not 45x; even though degree sum is 1, less than 2).
On the other hand, if I've g(x) = 13x^2y^2 + xy^2 + 2yx^2, I want an output of xy^2 (not yx^2 also).
Hello everyone, I have some weird problems with the maple. The problems are different for the document mode and the worksheet mode, however I strongly believe that they are connected. Starting with the document mode:
I simply cannot execute any command with the symbolic notation. As you can see below, I can execute basic mathematical calculations but I can't do any symbolic math.
On the other hand, I can execute all the commands in the worksheet mode. For example check the screenshot.
However, when I try to save that file in the worksheet mode, I get this error:
And, when I close the file and re-open again, I find all the stuff I wrote in the "math mode" disappeared
In the worksheet below, variable x can be returned to type name after being assigned a value , but concatenated variable name A||1 cannot. Is there a way to return a concatenated variable to type name after it has been assigned a value, so it can be re-used as an unknown in solve commands?
Concatenate_Question.mw
Hello Everyone,
I have an equation system which is under-determined and thus yields infinite solutions.
These usually come in the form of "_t1[1]" or similar variables. Mostly one, sometimes even two.
I am also working on a script for automated solving of a buckling problem and the solution yields of course these t-variables.
Everytime the code run, I get a different t-variable, which makes automation harder.
Please see attached code. (Of course simplified, not my actual code.)
It starts with a random matrix and a solution vector for the equation system.
The system is solved and its coefficients transfered to an equation.
However every time I hit "Enter" on the LinearSolve command, the name of the _t4[1] variable changes.
Is there a way to keep getting the same variable name? How do you work with this?
Best Regards,
Lennart
A := Matrix(4, 4, {(1, 1) = 1, (1, 2) = 3, (1, 3) = 4.5, (1, 4) = 7, (2, 1) = 0, (2, 2) = 2, (2, 3) = 5, (2, 4) = 9, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0}); B := Vector(4, {(1) = 0, (2) = 0, (3) = 0, (4) = 0}); C := LinearAlgebra[LinearSolve](A, B)
Vector[column](%id = 18446746248681490062)
W1 := C[1]; W2 := C[2]; W3 := C[3]; W4 := C[4]; Q := W1*x^4+W2*x^3+W3*x^2+W1
(HFloat(3.0)*_t4[2]+HFloat(6.5)*_t4[1])*x^4+(-HFloat(2.5)*_t4[2]-HFloat(4.5)*_t4[1])*x^3+_t4[2]*x^2+HFloat(3.0)*_t4[2]+HFloat(6.5)*_t4[1]
Download MultipleTCoefficients.mw
when i solve adomian polynomials there is a derivative withrespect to t and then put t is equal to zero. now i have to find the dervative of function with respect to t but it is already equals to zero. and i change the variable the Df could not b solved.
F(u[i]) := u[i]^2:
for n from 0 while n <= 6 do F(u[n]) := x[n]^2; V[n] := (diff(F(sum(t^i*u[i], i = 0 .. n)), [`$`(t, n)]))/factorial(n) end do:
t := 0;
for i from 0 while i <= n-1 do A[i] := V[i] end do;
x[0]^2
(D(F))(u[0])*u[1]
(1/2)*((D@@2)(F))(u[0])*u[1]^2+(D(F))(u[0])*u[2]
(1/6)*((D@@3)(F))(u[0])*u[1]^3+((D@@2)(F))(u[0])*u[1]*u[2]+(D(F))(u[0])*u[3]
(1/24)*((D@@4)(F))(u[0])*u[1]^4+(1/2)*((D@@3)(F))(u[0])*u[1]^2*u[2]+(1/2)*((D@@2)(F))(u[0])*u[2]^2+((D@@2)(F))(u[0])*u[1]*u[3]+(D(F))(u[0])*u[4]
(1/120)*((D@@5)(F))(u[0])*u[1]^5+(1/6)*((D@@4)(F))(u[0])*u[1]^3*u[2]+(1/2)*((D@@3)(F))(u[0])*u[1]*u[2]^2+(1/2)*((D@@3)(F))(u[0])*u[1]^2*u[3]+((D@@2)(F))(u[0])*u[2]*u[3]+((D@@2)(F))(u[0])*u[1]*u[4]+(D(F))(u[0])*u[5]
(1/720)*((D@@6)(F))(u[0])*u[1]^6+(1/24)*((D@@5)(F))(u[0])*u[1]^4*u[2]+(1/4)*((D@@4)(F))(u[0])*u[1]^2*u[2]^2+(1/6)*((D@@4)(F))(u[0])*u[1]^3*u[3]+(1/6)*((D@@3)(F))(u[0])*u[2]^3+((D@@3)(F))(u[0])*u[1]*u[2]*u[3]+(1/2)*((D@@3)(F))(u[0])*u[1]^2*u[4]+(1/2)*((D@@2)(F))(u[0])*u[3]^2+((D@@2)(F))(u[0])*u[2]*u[4]+((D@@2)(F))(u[0])*u[1]*u[5]+(D(F))(u[0])*u[6]
Download Adomian_Polynomials.mw
First 499 500 501 502 503 504 505 Last Page 501 of 2432
