Maple doesn't completely check the condition on the number of trials "n" for Binomial and NegativeBinomial distributions (package Statistics).
The attribute "Conditions" explicitely says that n must be a strictly positive integer but no strictly positive real valuereturna an error (ok, it would be stupid to set n to a non integer value !!!).
I think it is a default that ought to be corrected in future releases (this default still exists in Maple 2018)
kernelopts(version)
with(Statistics):
BINOMIAL DISTRIBUTION
X := RandomVariable(Binomial(n, p)):
L := [attributes(X)][3]:
A := exports(L)
Conditions, ParentName, Parameters, CDF, CharacteristicFunction, Kurtosis, Mean, Median, Mode, MGF, ProbabilityFunction, Skewness, Support, Variance, VariationCoefficient, CDFNumeric, QuantileNumeric, RandomSample, RandomSampleSetup, RandomVariate
L:-Conditions
[0 <= p, p <= 1, n::posint]
# Maple should return an error for N is not of type posint
# It seems that Sample uses floor(N)
N := 10.49; type(N::posint);
P := 1/2:
X := RandomVariable(Binomial(N, P)):
Mean(X), N*P;
ProbabilityFunction(X, k);
S := Sample(X, 10^6):
Mean(S);
# A non consistent result (only non negative values of k should be accepted)
eval(ProbabilityFunction(X, k), k=evalf(Pi));
N := 10.49
5.245000000, 5.245000000
piecewise(k < 0, 0, binomial(10.49, k)*(1/2)^k*(1/2)^(10.49-k))
HFloat(4.998903)
.1096019539
NEGATIVE BINOMIAL DISTRIBUTION
X := RandomVariable(NegativeBinomial(n, p)):
A := exports(L):
L:-Conditions
[0 < n, 0 < p, p <= 1]
N := 10.49:
P := 1/2:
X := RandomVariable(NegativeBinomial(N, P)):
Mean(X)
Download BinomialLaw.mw
Yeah, i have tried evalf[10](sqrt(25)).
How can i get a simple number as answer? I'm loving the software but i just wished i could type in:
int(sin(x), x = 0 .. pi)
and get 2 instead of (2.739493386*10^(-116) + (2.739493386*10^(-116))*I)*pi.
Also, when i type evalf[50](pi), i wish to get all the 50 digits, but i just get \pi :/.
Please help me.
i have a matrix named S. it has two variables with the names sigma1 and tau. i do some computations with these varibels to obtain a matrix named S_NEW. when i calculate S_NEW with parameters and then i substitute parameter tau with zero i got the answer a zero Matrix. but when i put tau=0 at the initiation of my code, i got another answer. what is the problem?
the second issue is related with the name of parametes in maple. when the varible has the name sigma1 (and tau=0), the matrix S_NEW is a matrix with the only component of (1,1). when i change the parameter name to sigma the matrix S_NEW is a matrix with the only component of (3,3). where is the problem?
restart:with(LinearAlgebra):
tau:=0;
S:=Matrix(3,[[sigma1,tau,0],[tau,0,0],[0,0,0]]):B1:=Matrix(3):
A12,B12:=(Eigenvectors(S)):
V12:= Matrix(Normalize~([Column(B12,1..3)],Euclidean)):
S_NEW:=simplify(V12^+.S.V12) assuming real ;
Matrix(3, 3, {(1, 1) = sigma1, (1, 2) = 0, (1, 3) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0})
eval(S_NEW,tau=0)
Download problem.mw
I have installed the Physics Package with:
PackageTools:-Install("5137472255164416", version = 329, overwrite)
I have a question about the calculation of the Tensor determinant:
I use two ways to calculate the determinant of the same matrix:
The first with Physics package and the second with LinearAlgebra Package:
It is easy to calculate analytically the result it is : -1
But Physics Package gives : +1 and LinearAlgebra gives: -1
My question is why I found +1 with Physics Package : What I doing wrong ?.
Please find my source hereafter:
with(Physics)
Setup(coordinates = {X = [t, x, y, z]}, dimension = 4, metric = {(1, 1) = 1, (2, 2) = -1, (3, 3) = -1, (4, 4) = -1}, signature = `+---`, mathematicalnotation = true)
Define(H[mu, nu] = Matrix(4, {(1, 1) = 1+h, (1, 2) = h, (2, 2) = -1+h, (3, 3) = -1, (4, 4) = -1}, shape = symmetric))
H[]
H[determinant]
with(LinearAlgebra)
B := Matrix(4, {(1, 1) = 1+h, (1, 2) = h, (2, 2) = -1+h, (3, 3) = -1, (4, 4) = -1}, shape = symmetric)
Determinant(B)
Thanks for your answer,
Sincerely yours
Xavier
This for me seems strange. A first oder ODE of degree one of form   A+B*y'=0. Asking Maple for its classification, it gives exact AND rational.  After rewriting it in the form y'=f(x,y) , now Maple says it is rational only. It no longer recognize it as exact.
How could this be possible? It is the same ODE, just rewrittng differently.  Maple 2019.1 on windows.
Typesetting:-Settings(typesetprime=true):
ode:=2*x/y(x)-y(x)/(x^2+y(x)^2)+(-x^2/y(x)^2+x/(x^2+y(x)^2))*diff(y(x),x) = 0;
DEtools:-odeadvisor(ode);
2*x/y(x)-y(x)/(x^2+y(x)^2)+(-x^2/y(x)^2+x/(x^2+y(x)^2))*(diff(y(x), x)) = 0
[_exact, _rational]
dsolve(ode)
y(x) = x/tan(RootOf(-_Z+x*tan(_Z)+_C1))
new_ode:=convert(ode,D); #so I can solve for y'
RHS:=solve(new_ode,D(y)(x));
2*x/y(x)-y(x)/(x^2+y(x)^2)+(-x^2/y(x)^2+x/(x^2+y(x)^2))*(D(y))(x) = 0
(2*x^3+2*x*y(x)^2-y(x)^2)*y(x)/(x*(x^3+x*y(x)^2-y(x)^2))
new_ode:=diff(y(x),x)=RHS;
DEtools:-odeadvisor(new_ode);
diff(y(x), x) = (2*x^3+2*x*y(x)^2-y(x)^2)*y(x)/(x*(x^3+x*y(x)^2-y(x)^2))
[_rational]
dsolve(new_ode)
_C1-arctanh((-2/(x^4*(1/y(x)^2+(x-1)/x^3)))^(1/2)*x/((-2*x+2)/(x^3*(1/y(x)^2+(x-1)/x^3))+2)^(1/2))+((-2*x+2)/(x^3*(1/y(x)^2+(x-1)/x^3))+2)^(1/2)/(-2/(x^4*(1/y(x)^2+(x-1)/x^3)))^(1/2) = 0
Download why_type_changed.mw
eq := solve({2*m-5 < 0, -3*m <= 5}, {m})
{-5/3 <= m, m < 5/2}
" implies result list m  in  `&Zopf;`, so m can m=0, m=1, m=2 and count=3"``
count := 0:
countt = 4
eq := solve({m-3 < 0, -m <= 6}, {m})
{-6 <= m, m < 3}
" implies result list m  in  `&Zopf;`, so m can m=-6, m=-5, m=-4, m=-3, m=-2, m=-1, m=0, m=1, m=2 and count=3"
count := 0:
countt = 9
i want to list variable m in integer number from solve?
Can you help me?
@acer
@Carl Love
Download help_list_integer_equation.mw
I want to solve for the coefficients in some multivariate polynomials by equating them to other known multivariate polynomials.
Something like this. I have
p[1]=(a+b)*x^2+(a+c)*x*y+d*z;
p[2]=(a-b)*x+e*y*z+f*z^2;
I want to impose that p[1]=x^2+2*x*y+3*z and that p[2]=x+4*y*z and I want Maple to tell me the values of (a,b,c,d,e,f).
Sounds simple enough, but I have not been able to do it
I want to solve an ODE system numerically, but maple show not converge for iteration, can you give a solution
with(VectorCalculus);
with(linalg);
pi := 4; eta := 6; mh := .1; mv := .3; bh := .15; Nh := 400; Nv := 200; bv := .25; b := .8; d := .1; p := .5; B := 10; A := 1; alpha := .25; beta := .7; K := 400; r := .5; c := .9; q := .8; Sh0 := 225; Sv0 := 100; Ih0 := 175; Iv0 := 600; P0 := 50; T := 35; B := 10;
eq1 := diff(L1(t), t) = -L1(t)*(-bh*b*Iv(t)/Nh-mh)-L2(t)*bh*b*Iv(t)/Nh; eq2 := diff(L2(t), t) = -L2(t)*(-mh-d)+L3(t)*bv*b*Sv(t)/Nv-L4(t)*bv*b*Sv(t)/Nv; eq3 := diff(L3(t), t) = -(L4(t)*Iv(t)+L3(t)*Sv(t))*L3(t)/(2*B^2)-L3(t)*(-bv*b*Ih(t)/Nv-mv-L3(t)*Sv(t)/(2*B^2)-(L4(t)*Iv(t)+L3(t)*Sv(t))/(2*B^2)-P(t)*alpha)-L4(t)*(bv*b*Ih(t)/Nv-L3(t)*Iv(t)/(2*B^2))-L5(t)*P(t)*alpha; eq4 := diff(L4(t), t) = -A-(L4(t)*Iv(t)+L3(t)*Sv(t))*L4(t)/(2*B^2)+L1(t)*bh*b*Sh(t)/Nh-L2(t)*bh*b*Sh(t)/Nh+L3(t)*L4(t)*Sv(t)/(2*B^2)-L4(t)*(-mv-L4(t)*Iv(t)/(2*B^2)-(L4(t)*Iv(t)+L3(t)*Sv(t))/(2*B^2)-P(t)*alpha)-L5(t)*P(t)*alpha; eq5 := diff(L5(t), t) = L3(t)*Sv(t)*alpha+L4(t)*Iv(t)*alpha-L5(t)*(r*(1-P(t)/Nv)-P(t)*r/Nv+alpha*(Sv(t)+Iv(t))-q*c); eq6 := diff(Sh(t), t) = pi-bh*b*Sh(t)*Iv(t)/Nh-mh*Sh(t); eq7 := diff(Ih(t), t) = bh*b*Sh(t)*Iv(t)/Nh-mh*Ih(t)-d*Ih(t); eq8 := diff(Sv(t), t) = eta-bv*b*Sv(t)*Ih(t)/Nv-mv*Sv(t)-P(t)*Sv(t)*alpha-L3(t)*Sv(t)^2/(2*B^2)-L4(t)*Sv(t)*Iv(t)/(2*B^2); eq9 := diff(Iv(t), t) = -L3(t)*Sv(t)*Iv(t)/(2*B^2)+bv*b*Sv(t)*Ih(t)/Nv-mv*Iv(t)-P(t)*Iv(t)*alpha-L4(t)*Iv(t)^2/(2*B^2); eq10 := diff(P(t), t) = P(t)*r*(1-P(t)/Nh)+P(t)*alpha*(Sv(t)+Iv(t))-q*P(t)*c
fcns := {Ih(t), Iv(t), L1(t), L2(t), L3(t), L4(t), L5(t), P(t), Sh(t), Sv(t)}; a := dsolve({eq1, eq10, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9, Ih(0) = Ih0, Iv(0) = Iv0, L1(T) = 0, L2(T) = 0, L3(T) = 0, L4(T) = 0, L5(T) = 0, P(0) = P0, Sh(0) = Sh0, Sv(0) = Sv0}, fcns, type = numeric);
  Sh(t), Sv(t)}
Hello forums,
I appreciate all the help that has been given to me throughout the past months.  I'm trying to solve a differential equation that involves a matrice in it.  I'm not sure if I am entering in the problem in correctly nor do I know what commands to use.  Can someone please be of assistance and teach me?
William
Solving_a_linear_algebra_differential_equation.mw
Dear Maple users
I wanted to create a list of random datapoints for the "simple linear regression model". Standard deviation sigma is given, slope a and fixed value b given for the line as well. Before the code below I had some random x-values created for the data points saved in the list X. To calculate the corresponding y-values randomly from a normal distribution with standard deviation sigma and mean equal to a*x+b I wrote the code below:
randomize():
for i from 1 by 1 to N do
    mean:=a*X[i]+b:
    Yvar:=RandomVariable(Normal(mean,sigma));
    S:=Sample(Yvar,1);
    Z[i]:=S[1];
Y:=convert(Z,list):
It actually works, but I just found it a bit strange having to repeatedly ask for a random sample with only a single member. Isn't it possible to do it more efficiently? I am aware of the special properties of the normal distribution, which would make it possible to take only one sample and add the mean afterwards, but I am not looking for ad hoc solutions, rather appropriate commands to create simgle random values from a distribution.
Erik
I am using A:=LinearAlgebra:-RandomMatrix(10,10,generator=-10..10) to generate a random matrix. How may I specify that every row of A has at least three non-zero entries?
Hello, i'm doing an interface for LU decomposition. I need to do a multiple windows interface using maplets, and i want to click one button on the inicial interface to open another window with other interface. I also need to create the second interface having N TextFields (N value will be inserted on the first window). Somebody knows how to do it?
Suppose I have a list of plywood dimensions
4 - 40.625" x 20"
2 - 36" x 20"
2 - 34.75" x 20"
3 - 33.75" x 12"
6 - 18.825" x 12"
3 - 32.5" x 12"
3 - 33.75" x 19.5"
How many sheets of 4' x 8' plywood do I need to minimize the cost of my project?
How does maple produce a Betweeness centrality matrix for unweighted, strongly connected graphs?
8/24/19. Updated question the bottom
I need to find if expression has  a "-" in front of it or not.  This is for formatting purposes for something I am doing, that is all.
I was using the command sign() for this, and it seems to work OK, but sometimes a Maple error is generated or not leading term sign is returned.
The sign function computes the sign of the leading coefficient of expr.
Is there a better and more robust way to do this other than using sign() or Am I using sign wrong?
expr:=-sin(x)/ln(y)+1;
op(expr);
-sin(x)/ln(y)+1
-sin(x)/ln(y), 1
#why this gives 1 as sign for the above?
sign(expr);
#workaround?
sign(op(1,expr))
-1
expr:=sin(x)/ln(y)+1;
sign(expr);
sin(x)/ln(y)+1
expr:=-x;
sign(expr);
-x
-1
expr:=-LambertW(exp(p))+1;
sign(expr)
-LambertW(exp(p))+1
-1
expr:=-LambertW(exp(p))/(1+LambertW(exp(p)))+1;
sign(expr)
Error, invalid argument for sign, lcoeff or tcoeff
#it seems the following is a work around for the above case
#but why it is needed just here?
sign(op(1,expr))
-1
Download q1.mw
UPDATE
Thanks to comment below about using frontend. I never used this before except for now. It seems a very useful command and I think I will be using it a lot more from now on.
Just to clarify again what I want. I am just looking to see if there is a leading negative sign in front of an expression. I am not looking to find if the expression itself can be postive or negative when evaluated or anything more subtle or deep than that.
I simply want to check if there is literally a "-" in front of the maple expression. That is all.
Only issue left, is why Maple still gives Error, invalid argument for sign, lcoeff or tcoeff for the last example below? Here is the updated worksheet.
frontend(sign,[expr]);
-sin(x)/ln(y)+1
-1
sin(x)/ln(y)+1
expr:=-x;
-x
-1
frontend(print,[expr]);
-LambertW(exp(p))+1
-O+1
-1
expr:=-LambertW(exp(p))/(1+LambertW(exp(p)))+1 ;
-O/(1+O)+1
Download q1_2.mw
First 657 658 659 660 661 662 663 Last Page 659 of 2433
