Hello everyone, I'm trying to run a simple calculation (Water flowing out of a pressurised container) using a combination of conservation of energy and conservation of mass. I have working models of the same system without pressurisation (purely gravity working) which work fine in Maple, but when re-writing the pressure as a function of the height of the water I receive the error:
"Error, (in DEtools/convertsys) unable to convert to an explicit first-order system".
The formula used is:
"Eq1:= -Rho_Water * A_Barrell * v_Barrel = Rho_Water * A_Nozzle * v_Nozzle"
Which returns:
"Eq1:= -25.23733555 * d/dt h_Water(t) = 0.5982 * (-190.1309944 - 13.64385474 * h_Water(t) + (d/dt h_Water(t))2)1/2"
With initial condition:
"ics1:= h_Water(0) = 0.2"
After giving the command:
"Sol1:= dsolve({Eq1, ics1}, numeric)"
Maple returns the aforementioned error. When trying to solve non-numerically the output is a list filled with "RootOf" and "_Z". Instinctively I would say the square root in the second part of the equation is the problem here, but I would not know how to fix this. Does anybody have a quick fix for this problem? Or is there a fundamental issue with the equation? Thank you in advance!
I have matrix:
m1 := Matrix([[x[0,0]=1,x[0,1]=1,x[0,2]=0,x[0,3]=0,x[0,4]=0,x[0,5]=0],[x[1,0]=0,x[1,1]=0,x[1,2]=1,x[1,3]=1,x[1,4]=0,x[1,5]=0],[x[2,0]=0,x[2,1]=0,x[2,2]=0,x[2,3]=0,x[2,4]=1,x[2,5]=1]]);
How to get values on the rhs of x without using for loops and create a matrix using these values?.
Results should be:
m2 := Matrix([[1,1,0,0,0],[0,0,1,1,0,0],[0,0,0,0,1,1]]);
How to write a code to get following Matrix D?
MY TRY: (But it' s not completely what I seek)
k:=1:
M:=2:
N:=2^k*(M+1):
U:=Matrix(M+1,M+1):
for r from 2 to M+1 do
for s from 1 to r-1 do
if type(r+s,odd) then
U(r,s):=2^(k+1)*sqrt((2*r-1)*(2*s-1)):
 else 0 end if:
#Let's find Matrix D, In here it' s shown matrix DD
DD:=Matrix(N,N,shape=diagonal,fill=U);
I hope everyone helps me about the problem of converting a permutation into numbers and vice versa on maple
Let Sn denote the set of all permutations of the set {0, 1, ..., n − 1}
Lehmer code is a bijective function l : Sn ->{0, 1, 2, ..., n! − 1}.
Define function l(S)=Sum(ci x (n − 1 − i)! ) where S in Sn and ci is the number of elements of the set { j > i | sj < si }
Inverse Lehmer code is a bijective function l−1 : {0, 1, 2, ..., n! − 1} -> Sn
For example: n=4 -->{0, 1, 2, 3}, for S = (0, 2, 1, 3) , so c0 = 0, c1 = 1 ( j=2 > i=1 and sj = 1 < si = 2), c2 = 0, c3 = 0 -->
I(S) = 0 x (3-0)! + 1 x (3 - 1)! + 0 x (3-2)! + 0 x (3 - 3)! = 2! = 2. So I((0, 2, 1, 3)) =2  and I-1(2) = (0, 2, 1, 3).
How to calculate I and I-1 on maple? Please help me! Thanks alot.
##########  omega and theta are variables,where J[3],F[2],H[2],etc are constants.
#### I tried with "evlf" and "evlc" command but maple was not ready to provide the solution,please help me to solve this
t1:=-1/(-16.*omega^2+exp(-4*omega)+exp(4*omega)-2.)*(-(0.5817764173e-1*I)*exp((2/9)*omega*cos(theta))*omega^5*cos(theta)*J[3]-(.6981317009*I)*exp((2/9)*omega*cos(theta))*omega^4*cos(theta)*H[3]-0.4524927691e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^3*G[3]-.6205615118*exp(.1111111111*omega*(2.*cos(theta)-9.))*cos(theta)*omega^3*H[2]+.6205615118*exp(.1111111111*omega*(2.*cos(theta)-9.))*cos(theta)*omega^3*F[2]+.9308422676*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^4*H[3]-.1034269187*exp(.1111111111*omega*(2.*cos(theta)-9.))*cos(theta)*omega^3*G[2]-0.7757018900e-1*exp(.1111111111*omega*(2.*cos(theta)-9.))*cos(theta)*omega^2*G[2]-0.7757018898e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^4*J[3]-0.9696273622e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^3*J[3]-0.4524927691e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^2*J[3]-.2714956613*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^2*H[3]-0.7757018898e-1*exp(.2222222222*omega*(cos(theta)-9.))*cos(theta)*omega^4*G[3]+0.8726646261e-1*exp((2/9)*omega*cos(theta))*omega^3*J[3])*cos((2/9)*omega*sin(theta));
t2:=int(int(t1,omega=0..infinity),theta=0..2*Pi);
Is there any Maple command to detect whether the degree of a polynomial w.r.t. all variables is less or equal 1?
For example, if $f=ax+by-1$ when $x$ and $y$ are variables then the output is true and if $g=a*x^2+b*y-c$ then it returns false.
Problem copying a document to Maple Cloud (Public domain)
• Reset password
• Verified email is correct
• Chose File → Save to Cloud... (or clicked Send Document to Cloud on Maple Cloud palette) either way opend Login dialog
• Entered  Account = Maplesoft account, my Email and password then clicked Log in.  The following message appears: "The account type or email address or password is incorrect"
I've saved .mw files to Maple Cloud before with no problems.  Any help appreciated.
Thanks, Les
I have the equation (𝑑𝑥/𝑑𝑡)^2=𝑎𝑥^3+𝑏𝑥^2+𝑐𝑥+𝑑.
How do I plot 𝑑𝑥/𝑑𝑡 against x? (as the coefficients a, b, c and d vary)
I expect it looks like the following graph:
Thank you for your help.
Hello everybody! I want to build closed geodesic on a cube. I know how to determine the next face, but I do not know how to determine which edge and in what proportion the geodesic will cross.
Here is NET for geodesic on cube. Geodesic type (3,9). Yes, 3 and 9 is not relative prime, but geodesic (1,3) not closed.
Or did I choose the wrong way to solve the problem? Help pls. Thanks.
Is there a riemann sum to integral converter?
If not then,
So I thought I could make some progress using the maple limit command in the this problem:
limit(Sum(csc(Pi*x/i)^3*sin(Pi*x)^3/i^3, i = 1 .. n), n = infinity)
which gives signum(sin(Pi*x)^3/x^3)*infinity
but what does this mean?
How do I convert Sum(csc(Pi*x/i)^3*sin(Pi*x)^3/i^3, i = 1 .. n), n = infinity to an integral or from this result?
I'm trying to solve this set of two equations forn where (EQ1 and EQ2 are already défined in fontions of the followings variables (k, wr ,R,Pi), and i'm using the following loop
eqns:={EQ1,EQ2}:
for i from 1 by 1 to 101 do R:=(i-1):S:=fsolve((eqns), {k, wr},{k=0..10,wr=0..10} ):v(i):=(subs(S,(wr))):w(i):=(subs(S,(k)))end do:
Error, invalid input: subs received fsolve({-0.6391108652e160*k+0.2384499927e160*wr+0.714075224e160*k^3-0.4729440685e160*wr^3-0.4025871558e160*k^5+0.1700629083e159*wr^5-0.4813673552e156*k^9+0.1033594302e160*k^7-0.1044324938e156*wr^7-0.1017755535e159*k^3*wr^4+0.2163976160e160*k^5*wr^2-0.7986601863e160*k^4*wr-0.2729449277e160*k^6*wr+0.8693579523e154*k^3*wr^6+0.4453377949e156*k^4*wr^5-0.2636332727e157*k^5*wr^4-0.5817233940e157*k^7*wr^2+0.5719400327e157*k^6*wr^3-0.2875232976e161*k^2*wr+0.2294793648e161*k*wr^2+0.1483050053e158*k^2*wr^5-0.3944893217e159*k^4*wr^3-0.464413477e159*k^2*wr^3+0.2760407324e157*k^8*wr+0.8238787577e156*k*wr^6-0.1081920595e...
i do get a solution for Pi/2 and Pi/3 but beyond this value i get the above error
Dear Sir,
I have a question: I have an analytic function depending on a real parameter that is of the form  F_y (z) with y>0 and z is complex.
I search the zeros  of F_y(z), that is the complex z staisfying F_y(z)=0. I used  the Maple function
RootFinding:-Analytic(F, z, re = -5 .. 0, im = -100 .. 100, );
but he displays me an error message  "Error, (in RootFinding:-Analytic) the function, -(100+I*z)^(1/2)*(80-I*z)^2*cosh((1/150)*(100-I*z)^(1/2)*Pi)*sinh((1/150)*(100+I*z)^(1/2)*Pi)+(100-I*z)^(1/2)*(80+I*z)^2*cosh((1/150)*(100+I*z)^(1/2)*Pi)*sinh((1/150)*(100-I*z)^(1/2)*Pi)+(2*I)*y*z^2*cosh((1/150)*(100-I*z)^(1/2)*Pi)*cosh((1/150)*(100+I*z)^(1/2)*Pi), depends on more than one variable: {y, z}. "
Can you help me to resolve my problem?
Best regards,
Zayd.
Is there an option or setting to tell Maple not to return trivial solution as a solution to a PDE? Even though trivial solution is correct, it is not something I wanted, and it is making it hard for me to check if the solution is trivial or not.
Here is an example:
pde:=I*diff(f(x,t),t)=-diff(f(x,t),x$2)+2*x^2*f(x,t):
bc:=f(-infinity ,t)=0,f(infinity,t)=0:
pdsolve([pde,bc],f(x,t))
Mathematica returns this
If there is no such option in Maple, what would be a good way to check for trivial solution using Maple code?
Just checking if rhs(sol)=0 does not work all the time, as some actual solutions are returned with 0 in rhs, like this example
pde := diff(u(x, y), x) + u(x,y)*diff(u(x, y),y) =0:
sol:=pdsolve(pde,u(x,y)):
sol:=DEtools:-remove_RootOf(sol)
So I need either find a way to tell Maple not to return trivial solution, or good robust way to check if solution returned is the trivial solution so I can reject it.
Any suggestion from the Maple experts how to handle this? I am now just interested in result from pdsolve, not dsolve.
The input is the PDE itself, read from a file. So this has to be done without visual inspection on the screen as the program reads the PDE from a file and process it. So the dependent variable and the independent variables are all included in the PDE itself. To make it more clear, I need a function such as
is_solution_trivial :=proc(pde,sol)
     #decide if sol is trivial solution or not.
     #one possibility is to find from the PDE the dependent variable
     #and the independent variables as in u(x,y,t,....) and then check
     #if sol  has the form u(x,y,t,....) =0 ?
The above I can use until I figure how to tell Maple NOT to return trivial solution in first place!
Maple 2019.1
I am trying to find p and q from this simultaneous equation as a function of system parameters. I do not know the parameters and I need an expression. But Maple simply just gives p=0 and q=0 as an answer
Eq1:=61*q*L__1^2*C*e*eta/(16*omega__n^2)+5*q*L__1^2*C*e^3*eta^3/(8*omega__n^4)+3*C*p^3*gamma__1*(1/4)+3*q*C*p^2*R__n/(4*omega__n)+q*L__1^2*C*e^4*eta^4/(16*omega__n^5)+145*q*L__1^2*C/(64*omega__n)+3*q^3*C*R__n/(4*omega__n)+3*p*C*q^2*gamma__1*(1/4)+q*R*C/(4*omega__n)+19*q*L__1^2*C*e^2*eta^2/(8*omega__n^3):
Eq2:=-3*C*p^3*R__n/(4*omega__n)-3*p*C*q^2*R__n/(4*omega__n)-p*L__1^2*C*e^4*eta^4/(16*omega__n^5)-5*p*L__1^2*C*e^3*eta^3/(8*omega__n^4)-19*p*L__1^2*C*e^2*eta^2/(8*omega__n^3)-61*p*L__1^2*C*e*eta/(16*omega__n^2)-145*p*L__1^2*C/(64*omega__n)-p*R*C/(4*omega__n)+3*q*C*p^2*gamma__1*(1/4)+3*q^3*C*gamma__1*(1/4):
sys := { Eq1 , Eq2 };solve( sys, {p,q} );
Is there any way to help Maple to try other conditions, I know the only solution should not be just p=0 and q=0.
Baharm31
Hi everyone.I need to know what is "t" in this equation.
(1+0.25cost)×(cos7t)=0.1
I dont need numeric solution.I need step by step solution.
First 683 684 685 686 687 688 689 Last Page 685 of 2433
