I'm trying to plot the fourier transform of a function(a sigmoid) and maple refuses to plot it. It seems to try to compute it symbolically then craps out because it can't reduce it to a computable form. Of course trying to do some type of numerical evaluation is impossible because it substitutes the numerical value for the transform variable.
S := x->erf(x):
plot(abs(fourier(S(x),x,w)),w=0..100):
Just want to plot the transform, I do not understand why it is do difficult for maple to do numerically. It should fall back on a numerical routine instead of crapping out.
How does one sync two or more different animations? Ideally it would be something like display(..., synchronize=true)
Hi, I am trying to solve a recurrence with rsolve:
rsolve({f(1) = 1, f(n) = n + sum(f(i), i=1..n-1)}, f)
Unfontunately, maple just prints the same function without evaluation:
How to get the expected result 2^n - 1 from maple?
when evalhf is used it shows error. please help
evalhf.mw
Hello everyone, Greetings!
I am facing a really strange problem. I need to write an expression, however, maple out of nowhere assigns values to the variable used. only to those which are written inside sin (). In previous versions the out put is fine. Is there a new way to write expressions in maple 2019? I am not sure.
96*sin(2*beta*y)*cos(2*beta*y)*beta^4 + 96*sin(2*beta*y)*beta^4
(0.525982730176588e-113+0.525982730176588e-113*I)*beta^4
Download strngmpl.mw
I get the following when MAPLE starts...
Warning, .hdb help databases are deprecated, 'C:\Program Files\Maple 2018\lib\OrthogonalExpansions.hdb' will not be used, see ?HelpTools,Migrate help page for more information
I have recently loaded an orthogonal expansions package created for earlier versions of MAPLE.
How can I remove the message?
MRB
How I can take Laplace inverse?
LAPLACE
Maple Worksheet - Error
Failed to load the worksheet //convert/LAPLACE
Download LAPLACE
Hi, im working on integration methods and i would like to make a routine that put to left side from a equation only the terms that have 'j+1'. So for example, we have the heat-conduction equation and we want to develope a approximated solution by an implicit method, so:
at this point i have tryed different ways in order to select only the terms that T [any,j+1], because we want T[i,j+1],T[i+1,j+1] and T[i-1,j+1] to the lhs of the equation and the rest to the rhs
I would like to make Maple read only the second index as a criteria to select or not.
Someone have any idea on how to make maple deal with it?
I have encountered the situation frequently where I want to simplify an equation by cancelling out terms on both sides.  I have tried simplify() with a variety of assumptions(J,L>0,etc) and I haven't been able to get it to work.  On a simple equation, one can use 'solve' however there are situations where solve doesn't work and I just want to simplify the equation not solve it.
The script below shows the situation.  I cancel out JL and the complex exponential by manually identifying that they are common factors.  Is there an automatic way of doing this type of simplification?
If I use expand() it clearly shows the common factors on both sides but I haven't found the command that removes any common terms.
E2 := (sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(j+1)*m/J)*exp(-(2*I)*Pi*l*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)+(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(j-1)*m/J)*exp(-(2*I)*Pi*l*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)-4*(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*j*m/J)*exp(-(2*I)*Pi*l*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)+(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*j*m/J)*exp(-(2*I)*Pi*(l+1)*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)+(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*j*m/J)*exp(-(2*I)*Pi*(l-1)*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L) = h^2*(sum(sum(`#mover(mi("ρ",fontstyle = "normal"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*j*m/J)*exp(-(2*I)*Pi*l*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)
E3 := E2*J*L; E4 := simplify(lhs(E3)) = simplify(rhs(E3))
J*L*((sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(j+1)*m/J)*exp(-(2*I)*Pi*l*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)+(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(j-1)*m/J)*exp(-(2*I)*Pi*l*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)-4*(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*j*m/J)*exp(-(2*I)*Pi*l*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)+(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*j*m/J)*exp(-(2*I)*Pi*(l+1)*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)+(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*j*m/J)*exp(-(2*I)*Pi*(l-1)*n/L), n = 0 .. L-1), m = 0 .. J-1))/(J*L)) = h^2*(sum(sum(`#mover(mi("ρ",fontstyle = "normal"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*j*m/J)*exp(-(2*I)*Pi*l*n/L), n = 0 .. L-1), m = 0 .. J-1))
sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*(m*(j+1)*L+l*n*J)*Pi/(J*L)), n = 0 .. L-1), m = 0 .. J-1)+sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*(m*L*(j-1)+l*n*J)*Pi/(J*L)), n = 0 .. L-1), m = 0 .. J-1)-4*(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L)), n = 0 .. L-1), m = 0 .. J-1))+sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(n*(l+1)*J+L*j*m)/(J*L)), n = 0 .. L-1), m = 0 .. J-1)+sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(n*(l-1)*J+L*j*m)/(J*L)), n = 0 .. L-1), m = 0 .. J-1) = h^2*(sum(sum(`#mover(mi("ρ",fontstyle = "normal"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L)), n = 0 .. L-1), m = 0 .. J-1))
subsindets(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*(m*(j+1)*L+l*n*J)*Pi/(J*L)), n = 0 .. L-1), m = 0 .. J-1)+sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*(m*L*(j-1)+l*n*J)*Pi/(J*L)), n = 0 .. L-1), m = 0 .. J-1)-4*(sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L)), n = 0 .. L-1), m = 0 .. J-1))+sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(n*(l+1)*J+L*j*m)/(J*L)), n = 0 .. L-1), m = 0 .. J-1)+sum(sum(`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(n*(l-1)*J+L*j*m)/(J*L)), n = 0 .. L-1), m = 0 .. J-1) = h^2*(sum(sum(`#mover(mi("ρ",fontstyle = "normal"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L)), n = 0 .. L-1), m = 0 .. J-1)), specfunc({Sum, sum}), proc (S) options operator, arrow; op(1, S) end proc)
`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*(m*(j+1)*L+l*n*J)*Pi/(J*L))+`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*(m*L*(j-1)+l*n*J)*Pi/(J*L))-4*`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L))+`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(n*(l+1)*J+L*j*m)/(J*L))+`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(n*(l-1)*J+L*j*m)/(J*L)) = h^2*`#mover(mi("ρ",fontstyle = "normal"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L))
simplify((`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*(m*(j+1)*L+l*n*J)*Pi/(J*L))+`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*(m*L*(j-1)+l*n*J)*Pi/(J*L))-4*`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L))+`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(n*(l+1)*J+L*j*m)/(J*L))+`#mover(mi("u"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(n*(l-1)*J+L*j*m)/(J*L)) = h^2*`#mover(mi("ρ",fontstyle = "normal"),mo("ˆ"))`[m, n]*exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L)))*(1/exp(-(2*I)*Pi*(J*l*n+L*j*m)/(J*L))))
2*`#mover(mi("u"),mo("ˆ"))`[m, n]*(-2+cos(2*Pi*m/J)+cos(2*Pi*n/L)) = h^2*`#mover(mi("ρ",fontstyle = "normal"),mo("ˆ"))`[m, n]
Download common_factors.mw
How can I expand the series in multi-variable, where all variable tends to infinity.
Suppose I have a function F(x,y,z) and I want the series of F in all three variable at {x=Infinity, y=infinity, z=infinity}
Does MAPLE have capabability to do multidimensional FTs i.e. (x,y)->(u,v)? If not, are there any links to MAPLE packages which meet this requirement that can be recommended?
Melvin Brown
I used thread for a loop and found that it takes more time than evalf. Please help to decrease the computational cost. Thank you.
thread_mp.mw
Consider the finite field G:=GF(p,k) for some prime p and a positive integer k. Let H be an nxm matrix over G.
My question: How to obtain the minimum number of linearly dependent columns of the H over G.
-Can we solve symbolically matrix equations where the matrices are ungiven by MAPLE?
For a simple example;
Let A.B+2B=C.
where A nxn is matrix and B, C and nx1 matrices. (all matrices are ungiven)
Question: Find symbolically matrix B in terms of C and A?
My try:
We can quickly calculate Matrix B by hand.  We have (A+2I)B=C and so B=(A+2I)^(-1).C   ( where (A+2I) is invertible and I is nxn identity matrix)
Briefly: Can we do for the more complex and difficult equations by MAPLE?
Hello, i wish to get dot displayed for time derivative and prime displayed for space derivative. I put typesetting in extended mode but it seems to only work for variable that depend only of time. So how can i get (in 2D math) dot displayed for derivative in time and prime displayed for space?
Example u(x,t):
diff(u(x,t),x) --->  u'(x,t) output displayed in prime
diff(u(x,t),t)  --->  u^. (x,t) output displayed in dot
First 696 697 698 699 700 701 702 Last Page 698 of 2433
