Here are two matrices:
Ts:=matrix([[cos(omega*t), cos(omega*t-2/3*Pi), cos(omega*t+2/3*Pi)], [sin(omega*t), sin(omega*t-2/3*Pi), sin(omega*t+2/3*Pi)],[1/2, 1/2, 1/2]]);
Xin:=matrix([[cos(omega*t+alpha)],[cos(omega*t+alpha-2/3*Pi)],[cos(omega*t+alpha+2/3*Pi)]]);
Then, if I attempt this operation, 'simplify(multiply(Ts, Xin));', this becomes the result:
Matrix(3, 1, [[cos(omega*t)*cos(omega*t+alpha)+cos(omega*t+(1/3)*Pi)*cos(omega*t+alpha+(1/3)*Pi)+sin(omega*t+(1/6)*Pi)*sin(omega*t+alpha+(1/6)*Pi)], [sin(omega*t)*cos(omega*t+alpha)+sin(omega*t+(1/3)*Pi)*cos(omega*t+alpha+(1/3)*Pi)-cos(omega*t+(1/6)*Pi)*sin(omega*t+alpha+(1/6)*Pi)], [(1/2)*cos(omega*t+alpha)-(1/2)*cos(omega*t+alpha+(1/3)*Pi)-(1/2)*sin(omega*t+alpha+(1/6)*Pi)]])
However, if I attempt to reduce each row, the previous result is reduced much further.
For example, this shows the expand operation applied to the first row and its result.
expand(3*cos(alpha)*(1/2)+(1/2)*cos(2*omega*t+alpha)-(1/2)*sin(2*omega*t+(1/6)*Pi+alpha)-(1/2)*cos(2*omega*t+(1/3)*Pi+alpha), trig);
3*cos(alpha)*(1/2)
Is there any way to reduce the entire matrix in a similar way, instead of using this element by element operation?
Is this an expected behaviour for simplify/size
I was simplifying a result from pdsolve, but did not check that the solution was null or () before calling simplify.
It turns out that  simplify((),size)  returns size for this. I find this is very strange.
I would have expected it to return ().
I can fix this by checking that sol is not null before calling simplify ofcourse. But the question is, why does simplify((),size) return size? What is the logic for this? From help:
The simplify(expr, size) calling sequence is used to attempt simplifying the expression size, performing only collections and simple decomposition of fractional powers in the coefficients - sometimes taking advantage of linear factors when they exist. No other mathematical simplifications of the expression or its subexpressions is performed. These operations, while simple and with low computational cost, may remarkably structure the expression and reduce its size.
is it possible what happens is this: becuase "sol" was null, the call simplify(sol,size) has actually become simplify(size) and the result is size.  So because the first slot in the call was (), it was ignored during the call and the first parameter became size insteal of sol?
Maple 2019 on windows 10.
 我计算了枫叶2019中的sin(0)和sin(pi),结果如下,是什么原因?
In the attached file, first, I use dsolve to analytically solve a system of equations. Maple solves it easily.
But, when I change the frequency (in the Sine function) of the second equation, Maple cannot solve it. Why?
question.mw
hi
i have an ode with its BCs,i defined those and tried to solve but it seems has problem,would you please see my code ?
plz see attached filesasa3.mw
Right now I am going through Bishop's ML book and as a part of the first exercise I need to define a polynomial that goes like this.
y(x,w) = w_0 + w_1 * x + w_2 * x^2 ... + w_m * x^m = sum (k=0 to m) w_k * x^k
Here is how I've written it out in Maple.
f := proc (x, w) options operator, arrow; sum(w[k]*x^k, k = 0 .. nops(w)) end proc
Sorry for the raw code, Maple Math won't accept the code I've written as a valid Maple expression for some reason. When I try to use this I get an error that says too many levels of recursion.
f(2, [a, b, c]);
Error, (in limit/mrv/limsimpl) too many levels of recursion
Where am I going wrong here?
I found that numerical integration of maple is a bit slow in many cases. Is there any external library for integration in maple. Please write how to use it as well. Thank you.
The following worksheet was run from my desktop and finds both currentdir() and interface(worksheetdir) to be "C:\Users\dharr\Desktop" (either from opening it within Maple 2017 or double-clicking on it). The startup code is
DocumentTools:-SetProperty("TextArea0",value,currentdir());
DocumentTools:-SetProperty("TextArea1",value,interface(worksheetdir));
But if I load it from Maple Player 2018, then both currentdir() and interface(worksheetdir) are "c:\program files\maple player".
It means an interactive application that runs in Maple won't run in Maple Player.
Is this a bug or deliberate strategy to make it harder to open datafiles within Maple Player?
(Can't load the worksheet contents right now)
Download Test.mw
I'm really after a simple workaround for a file open dialog with embedded components - any suggestions?
how can i construct this reccursive serie without loops or command proc :
for any n greater or equal 0 :u(n+1)=sin(u(n)) with u(0)=1.5
Please look at this codes!!!
i cant understand the idea of how maple works with parameters...
if u watch it exactly u can see that first maple understands that diff(a__1,t) is equall 1; but anfter that it couldnt load the value 1.
why?
what is hapening?
what can i do for this problem. its not the main code. i just send u an example of what  i want and what maple does. plz help me. tnx
i have a diff equation(in photo last one)ehich code coulde solve it?
Earlier smoothly working generation of normal distribution in v. 2019 unexpectedly shows the error:
RandV  := Statistics[RandomVariable](Normal(0, 1));
Statistics[Sample](RandV, 10);
Error, (in p) unable to convert Float(undefined) to an integer
When multiple request to DocumentTools:-Tabulate(...) are enclosed in the same group of commands (which typically happens when they are within a procedure), only the last one is displayed.
Is it possible to overcome this behaviour?
Hello, everyone: I have a question of drawing graph。
with(GraphTheory):
with(SpecialGraphs):
H := HypercubeGraph(3):
DrawGraph(H,
style = spring);
How  do I change  the vertex style   to polygon without line.
the aim graph  like figure below:
Thank you very much!
Greeting for all
 , How to plot gyroid surface by Maple where its equation is
Amr
First 707 708 709 710 711 712 713 Last Page 709 of 2433
