By default Maple labels vertices 1, 2, ...  and places these numbers within a circle making the position of the vertex.  Can one change the labels to, say, v1, v2, ... and place these outside the circles?  ..................Edgar
Write a program in Maple that solves the recurrence equations given for K[n] and R[n] numerically. Assume that if the recurrence equations return less than half a rabbit or fox, K[n] ≤ 0.5, respectively R[n] ≤ 0.5, at a time n, this means that the rabbits or foxes go extinct. Check that your program reproduces the equilibrium-solution if you start with the initial values K0 = Ke and R0 = Re.
Hi. I have an equation that consists lots of sines and cosines but I'm not sure how to differentiate it with respect to time. Whenever I do, I get zero. How do I communicate to Maple that theta changes with time so that it can perform the operation?
Is there any way to transfer the equation to MATLAB and perform it there by any chance? I don't know MATLAB though.
After doing some calculations, the result includes 20 rows,  3 columns.
but it doesn't appear. How can we see the result?
Please find the following code?
problem.mw
Please describe the step-by-step application of the rules of differentiation which produce this derivative:
diff(a(x)^b(x), x) =
a(x)^b(x)*((diff(b(x), x))*ln(a(x))+b(x)*(diff(a(x), x))/a(x));
why pdsolve does not work?
Q and alpha are constant. I want to find f(x,y).
"restart: w(x,y) :=Q*sin^(2)(Pi*x)*sin^(2)(Pi*y)"
proc (x, y) options operator, arrow, function_assign; Q*sin(Pi*x)^2*sin(Pi*y)^2 end proc
PDE := diff(f(x, y), x, x, x, x)+2*(diff(f(x, y), x, x, y, y))/alpha^2+(diff(f(x, y), y, y, y, y))/alpha^4+((diff(w(x, y), y, y))*(diff(w(x, y), x, x))-(diff(w(x, y), x, y))^2)/alpha^2
diff(diff(diff(diff(f(x, y), x), x), x), x)+2*(diff(diff(diff(diff(f(x, y), x), x), y), y))/alpha^2+(diff(diff(diff(diff(f(x, y), y), y), y), y))/alpha^4+((2*Q*sin(Pi*x)^2*Pi^2*cos(Pi*y)^2-2*Q*sin(Pi*x)^2*sin(Pi*y)^2*Pi^2)*(2*Q*Pi^2*cos(Pi*x)^2*sin(Pi*y)^2-2*Q*sin(Pi*x)^2*sin(Pi*y)^2*Pi^2)-16*Q^2*sin(Pi*x)^2*sin(Pi*y)^2*Pi^4*cos(Pi*x)^2*cos(Pi*y)^2)/alpha^2
pdsolve(PDE)
Download PLATE.mw
I currently have a list 2 elements long filled with lists 6 elements long similar to the following:
A := [[0, 1, 2, 3, 4, 5], list[0, 2, 4, 6, 8, 10]]
I would like to output 'A' (my list of lists) to a text file to look like the following:
0   0
1   2
2   4
3   6
4   8
5   10
Currently my code looks like this
L := [ ];
M := [ ];
for i from 0 to 5 do L := [op(L), 2*i]; M := [op(M), i] end do;
A := [M, L];
writedata(test, A, float);
Which provides me with almost what I need, but written horizontally instead of vertically:
0    1    2    3    4    5
0    2    4    6    8    10
How do I alter the code so that I can read my values vertically?
How do I solve for nonlinear differential equation with boundary value problem? Is it possible to solve nonlinear ODE by using Laplace Transform with Maple? If possible, can give me an example of solving nonlinear ODE using Maple. Thank you.
0.733333e^-1
0.733333e^-3
0.733333e^-5
0.733333e^-7
no matter what e is , expect to output the same 0.733333
I am trying to plot y:=x^2+x-12 as a curve and as a series of point. It is just not working. Suggestions, please.
Digitalize.mw
f := proc (x) options operator, arrow; x^2+x-12 end proc
n := 10
h := 5``
printf("\n    i        x       f (dec.form)    f (sci. notat.)\n"); printf("  ---------------------------------------------------\n"); for i from 0 to n do X[i] := i*h; Y[i] := f(X[i]); printf(" %5d  %9.4f  %13.9f  %17.10e\n", i, X[i], Y[i], Y[i]) end do
     0     0.0000  -12.000000000  -1.2000000000e+01
     1     5.0000   18.000000000   1.8000000000e+01
     2    10.0000   98.000000000   9.8000000000e+01
     3    15.0000  228.000000000   2.2800000000e+02
     4    20.0000  408.000000000   4.0800000000e+02
     5    25.0000  638.000000000   6.3800000000e+02
     6    30.0000  918.000000000   9.1800000000e+02
     7    35.0000  1248.000000000   1.2480000000e+03
     8    40.0000  1628.000000000   1.6280000000e+03
     9    45.0000  2058.000000000   2.0580000000e+03
    10    50.0000  2538.000000000   2.5380000000e+03
plot1 := plot([X[k], Y[k]], k = 0 .. n, style = point, symbol = soliddiamond, symbolsize = 24, color = blue)
plot2 := plot(f(x), x = 0 .. 50)
with(plots)
display([plot1, plot2])
Download Digitalize.mw
with(IntegrationTools):
# A very simple double integral
J:=Int(Int(x^2, x = 0 .. y), y = 0 .. 1);
value(J);
1/12
# Try a simple change of variables
Change(J, x=t*y, [t]);   # Why this form?
Intat(Intat(_a^2, _a = _b)-Intat(_a^2, _a = 0), _b = 1)-Intat(Intat(_a^2, _a = _b)-Intat(_a^2, _a = 0), _b = 0)
value(%);
1/12
# Now the same for 2*J
Change(2*J, x=t*y, [t]);  # OK, but why?
2*(Int(y^3*(Int(t^2, t = 0 .. 1)), y = 0 .. 1))
value(%);
1/6
Download IntegrationTools-Change.mw
Am trying to analyse a set of strings.   Can anyone help?
We have 10 x10 matrix into which we need to add connection score.
ExY := [WPKCPYWFYWCXHY, WPKCTEYFHCFEEE, HYCYTFHYYWWKCE, HYHHTFHKFEYHEH, HKXWYHFECTFFTF, HKWEHPPECWWHTC, HKXWYTPXHFHWYP, HKFEXCTFECXFKP, HKFEYPPEEEPHYW, HYTHCCFEWPPEXX, HKXKXCKFCHTEWK, HYEKPPCKFTWXXW];
Here is the code to create the connection matrix
A__c = A__a+A__d;
Blist:=[W,P,K,C,Y,F,X,H,T,E]:# basis letters
nWords:=numelems(ExY):Wletters:=length(ExY[1]):Bletters:=numelems(Blist):A:=Matrix(Bletters,Bletters):# set up dimensions
for iW from 1 to nWords do  # loop through words
  for iL from 1 to Wletters-1 do # loop through letters of each word
     fromLett:=C(iW,iL); # see char extraction from ExY list above
     toLett:=C(iW,iL+1); # ditto
     BfromLett:=Search(fromLett,Blist);# column id   <<<<<< the search is returning 0, it works if one uses "A" rather than say fromLett=A
     BtoLett:=Search(toLett,Blist);# row id   <<<<<  ditto here
     A(BfromLett,BtoLett):=A(BfromLett,BtoLett)+ 1; # add statistic to the A-matrix
  end do; # end letter loop
end do; # end word loop
Error, index out of bounds
The search function is failing:
Blist; Wletters; Bletters; nWords; fromLett; toLett; BfromLett; BtoLett; A; iW; iL;
                 [W, P, K, C, Y, F, X, H, T, E]
                               14
                               10
                               12
                              "W"
                              "P"
                 [0  0  0  0  0  0  0  0  0  0]
I found this paper.
http://benson-labs.com/uploads/stuff/POW15.pdf
I'm not sure if the population after 1 year is correct.
I wanted to get the formula from rsolve. But i have incorrorectly formulated the sum by day and the total.
Rattus_recursion.mw
Whilst trying to debug another problem on this site, this one
https://www.mapleprimes.com/questions/225688-How-To-Compute-Inverse-Of-A-Matrix-For
I came across a Maple bug(?) which was so serious, I thought either
  1. I'm being more than usually dim
  2. it needs it's own entry here, so that others can check
Problem can be summarized as:
When using 2D input, can the '.' character be used for simple matrix multiplication???? Because it isn't working for me!
Entering the '.' character places a bold, midline dot between the two arguments, but executing the result gives "Error unable to parse". Converting to 1-D input, no issues - everything works as expected.I should also point out that
  1. I never normally use 2D-input for my own work
  2. the attached worksheet executes correctly in Maple 2017.3, X86 64 WINDOWS, Sep 13 2017, Build ID 1262472.
If this is reproducible then wtf!
restart; with(LinearAlgebra); kernelopts(version)
`Maple 2018.1, X86 64 WINDOWS, Jun 8 2018, Build ID 1321769`
A := RandomMatrix(2, 2); B := RandomMatrix(2, 2)
Matrix(2, 2, {(1, 1) = 44, (1, 2) = -31, (2, 1) = 92, (2, 2) = 67})
Matrix(%id = 18446744074378134462)
A.B
Error, unable to parse
"A*B;"
LinearAlgebra:-Multiply(A, B)
Matrix(%id = 18446744074378136502)
A:= RandomMatrix(2, 2);
B:= RandomMatrix(2, 2);
A.B
Matrix(2, 2, {(1, 1) = -32, (1, 2) = -4, (2, 1) = -74, (2, 2) = 27})
Matrix(2, 2, {(1, 1) = -93, (1, 2) = -72, (2, 1) = -76, (2, 2) = -2})
Matrix(%id = 18446744074378132406)
Download matMulProb.mw
I'm start making an homepage about mathematic and wondt to link a workpage writen in Maple 16 into WP, thanks to whose ho have any idea :)
First 770 771 772 773 774 775 776 Last Page 772 of 2433
