What is incorrect I am getting the error:
y := (diff(tau(t), t))^2
(diff(tau(t), t))^2
"(∂)/(∂ (tau)) y"
Error, invalid derivative
"(∂)/(∂ tau) y"
Download errr.mw
You know in maple's linear algebra the Xij is true for i,j>0, X00 is meaningless.
Is it possible in Maple when we call X00 it returns the X11 element of the matrix, instead of
Error, Matrix index out of range
I try to do this by writing a procedure as bellow:
X := proc (i, j)
X[i+1, j+1]
end proc
but it does not work.
with(LinearAlgebra);
X := proc (i, j)
X[i+1, j+1]:
X := Matrix(2, 2, [[m[1, 1], m[1, 2]], [m[2, 1], m[2, 2]]]);
X[0, 0];
Any suggestion?
From  time to tiime Malel emits a sort of "Boiing" noise when I make a keyboard error. I am not sure exaclty when it does this, but it is loud. Is it possible to turn it off? I have looked quite extensively and cannot find out anything.
Hi all you out there.
I have an UNSORTED sequence  L of floats with elements in the range [a, b > a].
Let c some number such that c < b.
I want to find the smallest k such that L[k] > c.
This problem is related to the search of the "First Hitting Point" (or "First Passage Time") of a random process.
The attached file provides a notional example.
It contains a procedure named FirstHittingPassage which doesn't satisfies me for it is based on an unsmart  "confusion" between an Array and a list.
Would you have a smarter way to proceed ?
FirstHittingTime.mw
I need help with writing the code, I have this for part a but I dont think it is correct
   with(Student[Calculus1]);
   Tangent(2/(1+exp(-x)), x = 0, output = plot);
(a) Find an equation of the tangent line to the curve
                        y = -----------
                            1 + exp(-x)
 at (0,1).
(b) Graph the curve and the tangent line on the same axes.
(c) Use animate to show how the tangent line to the curve changes as we move along the curve between x=-5 and x=5.
Having trouble with starting off the three ways to complete this question.
Give three ways to plot the unit circle?
Hi everybody,
I'm facing that strange and blocking situation:
I was in a Maple 2018 worksheet "W"   (Windows 7, worksheet mode, not document mode) when, probably from some spurious keys combination, the small vertical bar that materializes the position of the mouse disappeared, rendering any further writting impossible.
In the same Maple session I had a few other worksheets  where the this same bar was still present: so it was not a Windows problem (this bar appeared in Word documents too).
I quitted Maple and ran it again. The result is still the same: among all the worksheet I load, only the worksheet  "W"  does not exhibit the location of the mouse.
This problem still persists after rebooting my working station.
Does anyone have any idea to fix this ?
I was trying the solution given in
https://www.mapleprimes.com/questions/225083-Maple-Command-To-Find-Domain-Of-Function
Which works fine for some functions, but fail for some reason for other functions.
f:=x*ln(y);
solve(evalc(Im(f)), {x,y});
But fails on
f:=sqrt(x)*ln(y);
Using Maple 2018.1 with Physics
`2018, July 3, 20:10 hours, version in the MapleCloud: 78, version installed in this computer: 74`
Why this error happen on some functions? Is there a way around it?
One way to workaround it I found, is to use solve for one variable at a time. Now Maple do not give an error
f:=sqrt(x)*ln(y);
solve(evalc(Im(f)), {x});
solve(evalc(Im(f)), {y});
Strange it failed when using {x,y} at same time on this one, but not on the first one. But the above answer is wrong. For "x", it should be x>=0 and not x=0. If I remove the "y" now it gives correct answer
f:=sqrt(x)*ln(y);
f:=sqrt(x);
This makes no sense to me.
I am finding too many bugs in Maple making it not useable and having to keep coming with workarounds.
Maybe it should be tested more thoroughly before release.
How to compute inverse of a square matrix in maple?
Like below matrix:
Matrix(6, 6, [[1/EE__1, -nu__21/EE__2, -nu__31/EE__3, 0, 0, 0.], [-nu__12/EE__1, `#mn("1")`/EE__2, -nu__32/EE__3, 0, 0, 0.], [-nu__13/EE__1, -nu__23/EE__2, `#mn("1")`/EE__3, 0, 0, 0], [0, 0, 0, 1/GG__23, 0., 0], [0, 0, 0, 0., 1/GG__13, 0], [0., 0., 0, 0, 0, 1/GG__12]])
Maple help say there is a mode n number, but what actually is it?
how I can dsolve these equations?
thanks.
Boundary conditions are:
u(0) = 0, u(0.1e-2) = 0, w(0) = 0, w(0.1e-2) = 0, (D(w))(0) = 0, (D(w))(0.1e-2) = 0
error masseage:
error.mw
dsys3 := {1.857142857*10^11*(diff(u(x), x, x)), 1.547619048*10^10*(diff(w(x), x, x, x))-1.300000000*10^11*(diff(w(x), x)), -1.300000000*10^11*(diff(w(x), x, x))+3.541600000*10^(-13)*(1.082793750-81250.00*w(x))/(1.019000000*10^(-6)-w(x))^2+1.040549102*10^(-32)/(1.019000000*10^(-6)-w(x))^4-2.124960000*10^(-15)*(1.082793750-81250.00*w(x))*(diff(w(x), x))^2/(1.019000000*10^(-6)-w(x))^4+1.151020000*10^(-10)*(diff(w(x), x))^2/(1.019000000*10^(-6)-w(x))^3-7.083200000*10^(-16)*(1.082793750-81250.00*w(x))*(diff(w(x), x, x))/(1.019000000*10^(-6)-w(x))^3+2.877550000*10^(-11)*(diff(w(x), x, x))/(1.019000000*10^(-6)-w(x))^2-2.081098205*10^(-34)*(diff(w(x), x))^2/(1.019000000*10^(-6)-w(x))^6-4.162196410*10^(-35)*(diff(w(x), x, x))/(1.019000000*10^(-6)-w(x))^5, u(0) = 0, u(0.1e-2) = 0, w(0) = 0, w(0.1e-2) = 0, (D(w))(0) = 0, (D(w))(0.1e-2) = 0, ((D@@2)(w))(0) = 0, ((D@@2)(w))(0.1e-2) = 0}; dsol5 := dsolve(dsys3, numeric, abserr = 0.1e-1, output = array([.5]))
Download error.mw
is there a way to have output left justified, instead of centered?
in other words, i want this:
4-1
not the normal
4-1
When I run a proc, I get an error
Error, (in SolveTools:-Inequality:-Piecewise) piecewise takes at least 2 parameters
But when I do restart; and then run the same command where the error was generated from inside the proc, but outside the proc, I get no error.
So I did not understand why it fails inside the proc, as I am typing the same exact command.
It turned out that an internal symbol _Z1 must have got messed up due to earlier calls made in the proc. It seems to have assumptions on it. To show this, here is screen shot. Only when I cleared the assumptions on _Z1, did it work. I do not use _Z1 any where in my code. This came back from a Maple call.
Now to proof this:
assume(_Z1::integer);
solve({x <> (  (1/2)*Pi+_Z1*Pi ), x < infinity, -infinity < x},{x})
I never set _Z1 myself in my code. This was done by Maple internally somewhere and caused this error. In my proc, I made call to singular and to solve only. And noticed this problem.
What should I do to avoid this problem? Why Maple fails above when its own _Z1 symbol is assumed integer? Is this a bug?
As a workaround for now, I could do this
_Z1:='_Z1'; #when I clear this, the error goes away. Why?
sol:=solve({x <> (1/2)*Pi+_Z1*Pi, x < infinity, -infinity < x},{x}):
simplify(sol) assuming _Z1::integer;
ofcourse,  I do not know that Maple will use _Z1 all the time, since I have to hardcode this in the code for now to pass through this problem. So this is a temp. solution for me.
untit.mw
This is a new question came up from a follow up to https://www.mapleprimes.com/questions/225083-Maple-Command-To-Find-Domain-Of-Function
Does Maple have support for removing points from an interval automatically? An example will make this clear. This is all on the real line. No complex domain.
Given one interval,. say real_domain :=  x>-infinity and x<infinity: and now I want to remove from this interval, another interval. This second interval can be defined as single point(s) or as interval(s) itself.
I will give an example of both.
when the singularity interval to remove is defined as one or more single points, here is an example using one point:
singlarity_pt := 1/2:
So I want Maple to give me automatically the new interval as   {x>-infinity and x<1/2} , {x>1/2 and x<infinity}:
Becuase the singularity point was "removed" from the real domain. I tried solve, but it did not work
solve(x<>singlarity_pt and real_domain,{x})
I know I could probably code this by hand, and add logic to figure it if the singularities are points. But this can get complicated if the real domain itself has many sub intervals itself. I thought Maple should be able to do this. fyi, In Mathematica, this is done as follows
singularity = 1/2;
realDomain = -Infinity < x < Infinity;
Reduce[x != singularity && realDomain , x, Reals]
Here is second example where now the singulartiy interval to remove, is not single point, but an interval itself. I found that in this case, solve did the right thing
singlarity_domain := x>-1/2 and x<1/2:
Now the final domain should be   -infinity<x<-1/2 , 1/2<x<infinity,
solve( not(singlarity_domain) and real_domain,{x})
The question is, why it worked when the singulaity is an interval, but it did not work when it is a specific point? And how can one make it work for single points? Is there a different command to use other than solve for this?
In general, singularities can contain single points and also intervals, but single points is more commin. So I need it to work for both cases.
This has to be done non-interactivally and without plotting or such, as it will be part of a script.
Thanks for any hints
In the following problem at two example are given. For Z=2 the sum is converging whereas at Z=4 it is not converging. Thank you
PROBLEM.mw
First 803 804 805 806 807 808 809 Last Page 805 of 2433
