How do I programmatically save the output of "C" code generation to a "cpp" file? I am doing all of these in Matlab via the Maple engine, which is version 10, I guess. I cannot seem to do "writeto" redirection here, because Matlab doesn't allow that I guess. And I like to use "fprintf" because it gives me more control of the code that is generated... If it works, I no longer need copy and paste.. But it didn't work at all. There was no error message, but the file was empty... Can anybody tell me why? Thanks! -------------------- fd:=fopen("trygenC.cpp", WRITE, TEXT)
Hi, It appears that maple has some sort of internal memory restriction, which sometimes causes it to stop during a computation with the following error message: Maple was unable to allocate enough memory to complete this computation, see ?alloc ..." Browsing through ?alloc, it appears that there's a way to increase this "software limit" , using something they call a "-T cl argument" but I was not able to find just how to go about it. Any idea how this could be done? thanks
bb:=proc(aa, n) add(add(aa[j][k], j=0 .. 5), k=0 .. n) end proc cc:=prep2trans(bb) dd:=C(cc, optimized) ??? Error using ==> maple at 129 Error, (in codegen/C) Unable to translate this subscript into C aa[i2][i1] -------------- I don't understand...
Hello everybody. I'm a newbies here. I would be glad if anyone of you here could please help me to create a maple code to perform a full pivoting where it permits both row and column exchange.The code is to be used to any kinds of nxn square matrix..Thank you..:)
I recently upgraded to Microsoft Excel 2007 and have tried unsuccessfully to tie in to Maple through the ADD-IN function within Excel. A note at the bottom of the spreadsheet says "Initializing Maple..." but nothing happens and the sheet locks up. Any suggestions?
looking for the fastest complex number arithmetics... Hi all, I am looking for the fastest complex number arithmetics. There is one part of my program which needs complex number arithmetics. The final result is a real number. So I had two choices: (1) Using the C++ class, and do all the operations in complex domain, and finally extract out the real part of the result. (2) Calculate the real part of result in closed-form by hand, and program everything in C/C++ in real domain. I used to do (2). And I used Maple to help me obtain the real part of the complex-valued expressions in closed form and generate the C code. The speed is about 10x faster than (1).
f := piecewise( is(floor(x)::odd), 1, 0 ): seq( f(n), n=-5..5 ); plot( f, -5..5 ); produces (Maple 11) the expected output (sequence alternates 1 and 0 - plot is a square wave). Replace the definition of f by f := piecewise( floor(x)::odd, 1, 0 ): and the seq command still operates as expected but the plot shows f=1 between 1 and 2 but otherwise 0. Does anybody know what is going on here? It's probably not important but I am confused. Toby
Hi folks! Does anybody know if Matlab and Maple and Mathematica works well and stable on Vista? How about speed on Vista? Thanks!
Suppose I have two lists of equal length, namely List1 and List2, whose elements are numbers from the list M=[0,.1,.2,.3,.4,.5,.6,.7,.8,.9,1]: Both the lists have to satisfy following condition: List1[x]+List2[x]
I have been attempting to use Maple 8 to compute the limit of a function defined by a procedure (rather than as a piecewise function). For example, consider the following procedure. f := proc(x) if is(x,numeric) then if x > 1 then 1; elif x <> returns undefined. limit( f(x),x=1,right) --> returns undefined. When I use a piecewise definition, all is well: f := x->piecewise( x>1, 1, x
Sorry, but I don't understand why Maple produces two different answers. (I make many analysis calculations, some expressions [math functions] come directly, e.g. 5x-3, some by Maple e.g. by series command.)
s:=x-1/2*x^2+1/3*x^3+O(x^4);
                               1  2   1  3    / 4\
                           x - - x  + - x  + O\x /
                               2      3
t:=series(ln(1+x),x,4);
                               1  2   1  3    / 4\
                               2      3
nops(s);
My laptop is broken and I am seriously considering purchasing a new laptop. I mainly use the laptop to do all kinds of programming, including Matlab, C/C++, Fortran, Maple, Mathematica, etc. I am wondering if anybody can tell some experiences about speed performance of Maple on Core Duo Dual Core processors? Are the computations on these computers really faster? I recall a few months ago I had tested a Monte Carlo program in Matlab on my friend's new Intel Quad Core (4 cpus). He paid $6000 for a desktop like that. The speed was not improved at all.
This one? int(log(c*exp(k*s)-d), s= 0 .. t) assuming (t>0, c>0, k>0, d>0) Thanks!
I'm trying to get the simple form of sum{k=1 to n} _2k C _k... I've tried to use Pascal's triangle, the gamma function, etc... but I couldn't get it... Somebody help~ My guess is _2k C _k is equal to binomial(2k,k). I used Maple... and the answer is ... as I see, a complex number!
F:=binomial(2*k,k);
                              binomial(2 k, k)
DefiniteSummation(F,k=1..n);
         (1/2)
    4 I 3                                            /[       3]            \
- -------------- - binomial(2 n + 2, n + 1) hypergeom|[1, n + -], [n + 2], 4|
Hello, I´m trying to create a maplets, but crash out with problem, I don´t now how to create in a smart way a method for count the number of varibles, I did that in the following lines: for Num from 1 to 1E6 do > A[Num]:=assigned(u[Num]): > if A[Num]=true then > N:=Num > end if; > end do: u[k] is a vector, and N, obviously the number of them. because I guess that the user, don´t want introduce more than a million of vectors, I don´t like that way. If somebody know the answer to my (maybe silly) question, please, explain it. Please replace this text with the link to your file.
First 2338 2339 2340 2341 2342 2343 2344 Last Page 2340 of 2457
