The ODE diff(y(x),x) = sec(x)^2*sec(y(x))^3  can be solved as separable. So the answer should be
simple_answer:=sin(y(x))*(cos(y(x))^2+2)=C_1+3*tan(x);
as can be seen by direct integration of each side of the differential equation. I am trying to make Maple give the same answer, but not having any luck.
ode:=diff(y(x),x) = sec(x)^2*sec(y(x))^3;
sol:=dsolve(ode, y(x),implicit);
I tried simplify(sol,trig) and tried simplify(sol,size).  Both Maple answer, and the simple answer solve the ODE.
Is there a way to make Maple dsolve give the simpler answer, or simplify/convert the answer it gives to the simpler one? I am newbie in Maple.
I'm looking over a file someone else made (I jusut have the image of it not the .mw), and there's a line that looks like this:
H1|
    | t=0.45.
H1 is an equation is set from an interpolation expansion line, and I believe this input solves the equation when the variable t is equal to 0.45. But how do I enter this into Maple? Thanks.
I am using Maple 2015 and when assigning a name to a function or expression and hit enter, it appears like in the following picture.
However, I want to make it appear like in the following picture:
How can I make that ?
Thank you !
Can someone help me with this:
reverse_eng.mw
happy new year!
I was trying to solve a system of ODE using Maple, but to my surprise, Maple recognizes diff((phi(t), t)) as a variable which is different than t.
My code is as following:
dsys := {2*m1*(a+l*sin(phi(t)))^2*(diff(diff(theta(t), t), t))+4*m1*(a+l*sin(phi(t)))*l*cos(phi(t))*(diff(theta(t), t))*(diff(phi(t), t)) = M, 2*m1*l^2*(diff(diff(phi(t), t), t))+4*m2*l^2*sin(2*phi(t))*(diff(phi(t), t))*(diff(phi(t), t))+4*m2*l^2*sin(phi(t))^2*(diff(diff(phi(t), t), t))-2*m1*(a+l*sin(phi(t)))*l*cos(phi(t))*(diff(theta(t), t))*(diff(theta(t), t))-2*m2*l^2*(sin(2*phi(t)))(diff(phi(t), t))*(diff(phi(t), t)) = -(2*(m1+m2))*g*l*sin(phi(t))-2*k*l^2*sin(2*phi(t)), phi(0) = 0, theta(0) = 0, (D(phi))(0) = 0, (D(theta))(0) = 0}
subs({M = 10, a = .5, g = 9.81, k = .1, l = .5, m1 = 10, m2 = 1}, dsys);
dsn1 := dsolve(dsys, numeric)
The error I got was Error, (in dsolve/numeric/process_input) input system must be an ODE system, got independent variables {t, diff(phi(t), t)}
I don't get why this is happening. Could you show me what's going on?
I solve a set of equations in this way and I have three set of answers ,but I don`t know wich one is true.
and I have another question ,how can I assume v[0] like a constant?
alpha[2]:= 2.727272728*10^5: alpha[4]:= 3738.685337: alpha[6]:= -30.18675539: alpha[7] := -4.116375735*10^6: alpha[8] := 1.859504132*10^10: alpha[9]:= 2.489142857*10^(-12):
l10:=(alpha[7]*v[0]^2+1)*gamma[i*n]^4+(-alpha[4]*beta[n]^2+alpha[8]*v[0]^2-alpha[9])*gamma[i*n]^2+(2*I)*gamma[i*n]*alpha[2]*beta[n]*v[0]+(2*I)*gamma[i*n]^3*alpha[6]*beta[n]*v[0]-beta[n]^2 = 0:
l11 := subs(i = 1, l10);
l12 := subs(i = 2, l10);
l13 := subs(i = 3, l10);
l14 := subs(i = 4, l10);
l15 := (exp(I*(gamma[n]+gamma[2*n]))+exp(I*(gamma[3*n]+gamma[4*n])))*(gamma[3*n]^2-gamma[4*n]^2)*(gamma[n]^2-gamma[2*n]^2)+(exp(I*(gamma[n]+gamma[4*n]))+exp(I*(gamma[2*n]+gamma[3*n])))*(gamma[2*n]^2-gamma[3*n]^2)*(gamma[n]^2-gamma[4*n]^2)+(exp(I*(gamma[2*n]+gamma[4*n]))+exp(I*(gamma[n]+gamma[3*n])))*(gamma[2*n]^2-gamma[4*n]^2)*(-gamma[n]^2+gamma[3*n]^2) = 0;
l1 := combine(expand(evalc(l15)), trig):
l2 := combine(expand(evalc(Re(l15))), trig):
l3 := combine(expand(evalc(Im(l15))), trig): v[0] := 1; 1
fsolve({l1, l11, l12, l13, l14}, {beta[n], gamma[n], gamma[2*n], gamma[3*n], gamma[4*n]}):
fsolve({l11, l12, l13, l14, l2}):
solve({l11, l12, l13, l14, l3}):
Reyhaneh
Friends in Maple
I have a Vehicle Routing Problem I wish to cast as a integer model. VRP is a kind of TSP and knapsack problem hybrid  I would be grateful if someone can finish it. answers included. This isn't homework BTW.
VRP_IP.mw
with(plots):with(plottools):
p1:=plot( x^3,x=-1..1,thickness=20,color=red):
p2:=plot(-x^3,x=-1..1,thickness=20,color=blue):
p3:=display(rectangle([0.5, 1],[0.75,-1],color=green)):
p4:=display(rectangle([-1,-0.1],[1,0.1],color=yellow)):
display(p1,p2,p3,p4); # order = 4312
#  display(p3,p4,p1,p2); # order = 4312 (the same)
It seems that the rectangles are plotted first, in reversed order, and then the curves, in direct order.
Has someone an explanation?
Cmaple always print the source code first and then print output , how to print output only without printing heading logo and source code by default when use cmaple
When print a formula , if variable has power, the power will print in another row
how can it print like a^2 in one row
I would like to minimuze the following function 4 x ^2 + 4 x y  under constraint  16=x^2 y  and both x , y  nonnegative real number
this is my code
with(Optimization)
Minimize(4*x^2+4*x*y, {x^2*y = 16}, assume = nonnegative)
The result obtained from this code is strange
because when i do directly the computation without maple by substituting y =16/x^2 and simple derivation i get the minimum is at x=2 and so y=4 and therefore the minimum is 48
But as i say using my code I obtained a different solution
whats is the problem occurs in this situation
Many thanks
I am using MAPLE 2016.1.
I have created an animation of points on a polarplot (2D), but would like it to be projected into 3D, with time t being the 3rd axis.  Here is my code for the polarplot animation:
Repltlist := proc (t) options operator, arrow; [[sin(t), 0], [cos(t), (1/3)*Pi], [cos(2*t), (2/3)*Pi]] end proc;
Impltlist := proc (t) options operator, arrow; [[-sin(3*t), 0], [-2*cos(t), (1/3)*Pi], [-cos(4*t), (2/3)*Pi]] end proc;
titleName := "Polar representation of time-dependence of degrees of freedom in configuration space"; captionName := "Re - red, Im - blue";
P := animate(polarplot, [Repltlist(t), color = "Red"], t = -Pi .. Pi, symbol = solidcircle, style = point, color = red, symbolsize = 12, frames = 100, gridlines = true);
Q := animate(polarplot, [Impltlist(t), color = "Blue"], t = -Pi .. Pi, symbol = solidcircle, style = point, color = blue, symbolsize = 12, frames = 100, gridlines = true);
R := display([P, Q], title = titleName, caption = captionName); R;
I have been trying use the plots[transform] to 'lift' this polarplot into 3D:
with(plottools); with(plots);
plrPt(2); f := proc (tt) options operator, arrow; plottools:-transform(proc (r, theta) options operator, arrow; [r, theta, tt] end proc) end proc; display((f(2))(plrPt(2)));
but the last command gives no output.
Can anyone help?
MRB
PS:  I am now attemptiing to do the lift to 3D by using a cylinderplot but would like know why the transform function is not able able to lift the polarplot into 3D.
Hello; I found another ODE which Maple gives division by zero on.  Is this also a bug?
dsolve(x*(a^2*x+(x^2-y(x)^2)*y(x))*diff(y(x),x)^2-(2*a^2*x*y(x)-(x^2-y(x)^2)^2)*diff(y(x),x)+a^2*y(x)^2-x*y(x)*(x^2-y(x)^2) = 0, y(x));
Error, (in dsolve) numeric exception: division by zero
This is from a book. Using Maple 2016.1 on windows.
Please Sir/Ma, I'm trying to generate a recurrent relations of this series and I try to use "if" "else" condition but I didn't get it right. Any one with useful suggestions. Appreciate
Y[0] := A; Y[1] := B;
if k = a then delta(k-a) := 1 else 0 end if;
for k from 0 to 10 do Y[k+2] := solve(add(delta(i-1)*(k-i+1)*(k-i+2)*Y[k-i+2], i = 0 .. k)+add((delta(i)-delta(i-1))*(k-i+1)*Y[k-i+1], i = 0 .. k)+lambda*Y[k] = 0, Y[k+2]) end do;
y := sum(Y[j]*x^j, j = 0 .. 10);
I use maple 12 on my dual core laptop and i plan to buy maple 2016 and an 8 core system to get advandage of multiple processors.
Does maple 2016 functions get advandage of multiprocessor systems or it will be the same as having one processor?
First 1061 1062 1063 1064 1065 1066 1067 Last Page 1063 of 2463
