what do i call a homogenous  differential equation that is the linear sum of "N" differential of unique classification? ie, the implicit construction of a third homogenous differential by the summation of two known, is it the span of the solution sets of the first two or union? i prefer span because well that leaves the door open for multivariate differential basis definitions, non commutative groups like sets of square matrices and all of the other extra arousing subject content.
When I type sin(pi/2) the result is sin(pi/2) (not "1.0)
What should I do to get "1.0" instead of replicating the sin(pi/2) ?!
I mean why the expression contating "pi" can not being simplified?
Is there any solution to this problem?
Hi! I'm trying to find the way to plot the solution with series representation. I need some help to find the easiest way.
Note: I realized some typing errors, which do not change the question a lot ,and I corrected them.
plot.mw
I am unable to see length of rigid body frame in MapleSim Examples - Physical Domain  - Multibody - 5 DOF robot? Is there a way to see them?
Onder
If an expression is of the form x^3 + x^2 + x + z + y^3 + y^2 + y + xy=0 ,
How to represent it in the following form,
           x^3 + y^3 + x^2 + y^2 + xy + x + y + z=0 ?
I have exported a maple document to latex, but it only shows the output of the commands used. Rather than the commands, and the procedures.
How do I get both to export together? and show up together?
Is there a way to automatically convert and paste my clipboard contents as 2D math?
any assistence here will be much appreciated the website gave me a zip containing the template tex and other files, but for what ever reason its not working when i copy in output using the maple to latex conversion feature from inside the interface. literally im sick of having to work outside of the maple interface but yes believe it or not this is the one thing i use to procrastinate writting a formal publication yep i really need the first one of those to get this done and dusted.
hi..when i use rule [for] in maple code i encounter error'''''
Error, (in dsolve/numeric/process_input) input system must be an ODE system, found {f1(x), f2(x), f3(x), ApproximateInt(-4*cos(theta)^2, theta = 0. .. 1, method = simpson), ApproximateInt(4*cos(theta)^2, theta = 0. .. 1, method = simpson), ApproximateInt(8*cos(theta)^2, theta = 0. .. 1, method = simpson)}''''''''
please help me for remove it
99999999999999.mw
i want for different beta for example beta=0, 40 and 80 this lines will computed three times
 ''with(Student[Calculus1]); a1 := ApproximateInt(g1*g1, theta = a .. 1, method = simpson); a2 := ApproximateInt(2*(g1*g1)+3*g1*(diff(g1, theta, theta)), theta = a .. 1, method = simpson).......................''
 by {for i from 1 by 1 to 3 do } and final gain ''ITRA_1_W[m] := eval(fy33*g3, fixedparameter)'' that have 3 amount.
when i use  rule {for i from 1 by 1 to 3 do ...  }   integral not computed and showed for example:::
a1=ApproximateInt(4*cos(theta)^2, theta = 0. .. 1, method = simpson)!!!!!!!!
thanks..
another problem with itegral, again intergal is getting unevaluated answers or folated ( infinity )
what should i do ?
Digits := 30;
30
N := 8;
8
proc (x, s) options operator, arrow; exp(x*s) end proc
proc (x) options operator, arrow; exp(2*x)+(exp(x*(x+2))-exp(-x-2))/(x+2) end proc
alpha := -1/2;
-1/2
-1/2
for n from 0 to N+1 do J[n] := unapply(simplify((-1)^n*(1-x)^(-alpha)*(1+x)^(-beta)*(diff((1-x)^(n+alpha)*(1+x)^(n+beta), [`$`(x, n)]))/(2^n*factorial(n))), x) end do;
proc (x) options operator, arrow; 1 end proc
proc (x) options operator, arrow; (1/2)*x end proc
proc (x) options operator, arrow; (3/4)*x^2-3/8 end proc
proc (x) options operator, arrow; (5/4)*x^3-(15/16)*x end proc
proc (x) options operator, arrow; (35/16)*x^4-(35/16)*x^2+35/128 end proc
proc (x) options operator, arrow; (315/256)*x+(63/16)*x^5-(315/64)*x^3 end proc
proc (x) options operator, arrow; (231/32)*x^6-231/1024-(693/64)*x^4+(2079/512)*x^2 end proc
proc (x) options operator, arrow; -(3003/2048)*x+(429/32)*x^7-(3003/128)*x^5+(3003/256)*x^3 end proc
proc (x) options operator, arrow; (6435/256)*x^8+6435/32768-(6435/128)*x^6+(32175/1024)*x^4-(6435/1024)*x^2 end proc
proc (x) options operator, arrow; (109395/65536)*x+(12155/256)*x^9-(109395/1024)*x^7+(328185/4096)*x^5-(182325/8192)*x^3 end proc
u := unapply(exp(2*x), x);
proc (x) options operator, arrow; exp(2*x) end proc
for i from 0 to N do phi[i] := J[i](x) end do
(1/2)*x
(3/4)*x^2-3/8
(5/4)*x^3-(15/16)*x
w1 := (1-x)^alpha*(1+x)^beta;
1/((1-x)^(1/2)*(1+x)^(1/2))
for j from 0 to N do S[j] := simplify(evalf(int(k(x, s)*subs(x = s, phi[j]), s = -1 .. x))) end do;
(-1.*exp(-1.*x)+1.*exp(x^2))/x
.5*(exp(x^2)*x^2+exp(-1.*x)*x+exp(-1.*x)-exp(x^2))/x^2
((.75*x^4-1.875*x^2+1.5)*exp(x^2)-.375*(x+2.)^2*exp(-1.*x))/x^3
((1.25*x^6-4.6875*x^4+8.4375*x^2-7.5)*exp(x^2)+(.3125*x^3+2.8125*x^2+7.5*x+7.5)*exp(-1.*x))/x^4
((2.1875*x^8-10.9375*x^6+30.8984375*x^4-56.875*x^2+52.5)*exp(x^2)+(-.2734375*x^4-4.375*x^3-21.875*x^2-52.5*x-52.5)*exp(-1.*x))/x^5
((3.9375*x^10-24.609375*x^8+94.74609375*x^6-267.01171875*x^4+502.03125*x^2-472.5)*exp(x^2)+(.24609375*x^5+6.15234375*x^4+49.21875*x^3+206.71875*x^2+472.5*x+472.5)*exp(-1.*x))/x^6
((7.21875*x^12-54.140625*x^10+263.935546875*x^8-1004.5341796875*x^6+2866.74609375*x^4-5457.375*x^2+5197.5)*exp(x^2)+(-.2255859375*x^6-8.12109375*x^5-94.74609375*x^4-606.375*x^3-2338.875*x^2-5197.5*x-5197.5)*exp(-1.*x))/x^7
((13.40625*x^14-117.3046875*x^12+692.09765625*x^10-3321.18896484375*x^8+12740.75537109375*x^6-36669.4453125*x^4+70382.8125*x^2-67567.5)*exp(x^2)+(.20947265625*x^7+10.26416015625*x^6+164.2265625*x^5+1478.0390625*x^4+8445.9375*x^3+30968.4375*x^2+67567.5*x+67567.5)*exp(-1.*x))/x^8
((25.13671875*x^16-251.3671875*x^14+1740.7177734375*x^12-10086.1083984375*x^10+48652.315521240234375*x^8-187783.857421875*x^6+543707.2265625*x^4-1049709.375*x^2+1013512.5)*exp(x^2)+(-.196380615234375*x^8-12.568359375*x^7-263.935546875*x^6-3167.2265625*x^5-24885.3515625*x^4-132721.875*x^3-470559.375*x^2-1013512.5*x-1013512.5)*exp(-1.*x))/x^9
A := Matrix(N+1, N+1):
for i from 0 to N do for j from 0 to N do A[i+1, j+1] := evalf(Int(phi[i]*phi[j]*w1, x = -1 .. 1, epsilon = 0.1e-24)) end do end do;
A
Matrix([[3.14159265358979323846264338328, 0., 0.111111111111111111111111111111e-32, 0., -0.333333333333333333333333333333e-32, 0., -0.173333333333333333333333333333e-31, 0., -0.291851851851851851851851851852e-30], [0., .392699081698724154807830422910, 0., 0.370370370370370370370370370370e-33, 0., -0.370370370370370370370370370370e-33, 0., -0.718518518518518518518518518519e-32, 0.], [0.111111111111111111111111111111e-32, 0., .220893233455532337079404612887, 0., 0.407407407407407407407407407407e-33, 0., 0.666666666666666666666666666667e-32, 0., 0.966666666666666666666666666667e-31], [0., 0.370370370370370370370370370370e-33, 0., .153398078788564122971808758949, 0., 0.740740740740740740740740740741e-33, 0., 0.128888888888888888888888888889e-31, 0.], [-0.333333333333333333333333333333e-32, 0., 0.407407407407407407407407407407e-33, 0., .117445404072494406650291081070, 0., -0.429629629629629629629629629630e-32, 0., -0.459259259259259259259259259259e-31], [0., -0.370370370370370370370370370370e-33, 0., 0.740740740740740740740740740741e-33, 0., 0.951307772987204693867357756671e-1, 0., -0.135555555555555555555555555556e-31, 0.], [-0.173333333333333333333333333333e-31, 0., 0.666666666666666666666666666667e-32, 0., -0.429629629629629629629629629630e-32, 0., 0.799362781468415055263543670536e-1, 0., 0.157777777777777777777777777778e-31], [0., -0.718518518518518518518518518519e-32, 0., 0.128888888888888888888888888889e-31, 0., -0.135555555555555555555555555556e-31, 0., 0.689246479939602777242545307758e-1, 0.], [-0.291851851851851851851851851852e-30, 0., 0.966666666666666666666666666667e-31, 0., -0.459259259259259259259259259259e-31, 0., 0.157777777777777777777777777778e-31, 0., 0.605783039009416503435830836897e-1]])
B := Matrix(N+1, N+1):
for j from 0 to N do for i from 0 to N do B[i+1, j+1] := evalf(Int(simplify(phi[i]*S[j]*w1), x = -1 .. 1, epsilon = 0.1e-5), 15) end do end do;
B := Matrix(B)
B := Matrix(9, 9, {(1, 1) = 3.41340669637960, (1, 2) = -.219853801558141, (1, 3) = -.371445167328337, (1, 4) = -0.940736800940411e-2, (1, 5) = -0.845889943042008e-1, (1, 6) = 0.334727115780295e-1, (1, 7) = -0.257221402047336e84, (1, 8) = Float(infinity), (1, 9) = Float(undefined), (2, 1) = .765483256689808, (2, 2) = .141014141031686, (2, 3) = -.165532642864785, (2, 4) = -0.499428359428865e-1, (2, 5) = -0.73434901130578e-2, (2, 6) = -0.111757807839544e-1, (2, 7) = 0.123803381671991e68, (2, 8) = Float(undefined), (2, 9) = Float(-infinity), (3, 1) = 0.515972557667626e-1, (3, 2) = .125811948358948, (3, 3) = 0.408759073542022e-2, (3, 4) = -0.716662760034337e-1, (3, 5) = -0.51685004360437e-2, (3, 6) = 0.716801959003042e67, (3, 7) = Int((43.3125*(2.*x^2-1.)*(0.625e-1*x^12-.46875*x^10+2.28515625*x^8-8.697265625*x^6+24.8203125*x^4-47.25*x^2+45.)*exp(x^2)+43.3125*(2.*x^2-1.)*(-0.1953125e-2*x^6-0.703125e-1*x^5-.8203125*x^4-5.25*x^3-20.25*x^2-45.*x-45.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^7), x = -1. .. 1.), (3, 8) = Float(-infinity), (3, 9) = Float(infinity), (4, 1) = 0.899030920810901e-1, (4, 2) = 0.21384118669396e-2, (4, 3) = 0.393313755295959e-1, (4, 4) = -0.17596837269261e-3, (4, 5) = -0.341293873201944e-1, (4, 6) = -0.107499338429209e52, (4, 7) = 0.188236331912532e46, (4, 8) = Float(-infinity), (4, 9) = Int(0.625000000000000e-1*((-15202687.5+502.73437500*x^18-5404.39453125*x^16+38584.8632812500*x^14-227832.934570312*x^12+1124337.93640137*x^10-4485461.88125610*x^8+13690902.3925781*x^6-29149795.8984375*x^4+36015890.625*x^2)*exp(x^2)+5.*(4.*x^2-3.)*(-.196380615234375*x^8-12.568359375*x^7-263.935546875*x^6-3167.2265625*x^5-24885.3515625*x^4-132721.875*x^3-470559.375*x^2-1013512.5*x-1013512.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^8), x = -1. .. 1.), (5, 1) = 0.463651486782722e-3, (5, 2) = 0.157757505144122e-1, (5, 3) = 0.7529674755144e-4, (5, 4) = 0.205695133452456e-1, (5, 5) = 0.323627840089429e50, (5, 6) = -0.194229780735106e-1, (5, 7) = Int((31.58203125*(8.*x^4-8.*x^2+1.)*(0.625e-1*x^12-.46875*x^10+2.28515625*x^8-8.697265625*x^6+24.8203125*x^4-47.25*x^2+45.)*exp(x^2)+31.58203125*(8.*x^4-8.*x^2+1.)*(-0.1953125e-2*x^6-0.703125e-1*x^5-.8203125*x^4-5.25*x^3-20.25*x^2-45.*x-45.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^7), x = -1. .. 1.), (5, 8) = Float(infinity), (5, 9) = Float(-infinity), (6, 1) = 0.63086454697723e-2, (6, 2) = 0.148539925067e-4, (6, 3) = 0.678853225186884e-2, (6, 4) = 0.10778334378e-5, (6, 5) = 0.131282639565718e-1, (6, 6) = -0.271179086613e-5, (6, 7) = -0.124971422339580e-1, (6, 8) = -0.810764520616245e86, (6, 9) = 0.973719186742316e103, (7, 1) = 0.225892591375e-5, (7, 2) = 0.119535935984917e-2, (7, 3) = 0.47254024736e-6, (7, 4) = 0.406635846209016e-2, (7, 5) = -0.353102865787386e29, (7, 6) = 0.914224761911803e-2, (7, 7) = Int(0.976562500000000e-3*(231.*(32.*x^6-48.*x^4+18.*x^2-1.)*(7.21875*x^12-54.140625*x^10+263.935546875*x^8-1004.5341796875*x^6+2866.74609375*x^4-5457.375*x^2+5197.5)*exp(x^2)+231.*(32.*x^6-48.*x^4+18.*x^2-1.)*(-.2255859375*x^6-8.12109375*x^5-94.74609375*x^4-606.375*x^3-2338.875*x^2-5197.5*x-5197.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^7), x = -1. .. 1.), (7, 8) = Int(0.976562500000000e-3*(231.*(32.*x^6-48.*x^4+18.*x^2-1.)*(13.40625*x^14-117.3046875*x^12+692.09765625*x^10-3321.18896484375*x^8+12740.7553710938*x^6-36669.4453125*x^4+70382.8125*x^2-67567.5)*exp(x^2)+231.*(32.*x^6-48.*x^4+18.*x^2-1.)*(.20947265625*x^7+10.26416015625*x^6+164.2265625*x^5+1478.0390625*x^4+8445.9375*x^3+30968.4375*x^2+67567.5*x+67567.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^8), x = -1. .. 1.), (7, 9) = Int(0.976562500000000e-3*(231.*(32.*x^6-48.*x^4+18.*x^2-1.)*(25.13671875*x^16-251.3671875*x^14+1740.7177734375*x^12-10086.1083984375*x^10+48652.3155212402*x^8-187783.857421875*x^6+543707.2265625*x^4-1049709.375*x^2+1013512.5)*exp(x^2)+231.*(32.*x^6-48.*x^4+18.*x^2-1.)*(-.196380615234375*x^8-12.568359375*x^7-263.935546875*x^6-3167.2265625*x^5-24885.3515625*x^4-132721.875*x^3-470559.375*x^2-1013512.5*x-1013512.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^9), x = -1. .. 1.), (8, 1) = 0.340365610524644e-3, (8, 2) = 0.5813755404e-7, (8, 3) = 0.59941816605747e-3, (8, 4) = 0.1233441019e-7, (8, 5) = 0.275221040025479e-2, (8, 6) = -0.804784322e-8, (8, 7) = -0.187505962866890e33, (8, 8) = Int(0.488281250000000e-3*(429.*(64.*x^6-112.*x^4+56.*x^2-7.)*(13.40625*x^14-117.3046875*x^12+692.09765625*x^10-3321.18896484375*x^8+12740.7553710938*x^6-36669.4453125*x^4+70382.8125*x^2-67567.5)*exp(x^2)+429.*(64.*x^6-112.*x^4+56.*x^2-7.)*(.20947265625*x^7+10.26416015625*x^6+164.2265625*x^5+1478.0390625*x^4+8445.9375*x^3+30968.4375*x^2+67567.5*x+67567.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^7), x = -1. .. 1.), (8, 9) = Int(0.488281250000000e-3*(429.*(64.*x^6-112.*x^4+56.*x^2-7.)*(25.13671875*x^16-251.3671875*x^14+1740.7177734375*x^12-10086.1083984375*x^10+48652.3155212402*x^8-187783.857421875*x^6+543707.2265625*x^4-1049709.375*x^2+1013512.5)*exp(x^2)+429.*(64.*x^6-112.*x^4+56.*x^2-7.)*(-.196380615234375*x^8-12.568359375*x^7-263.935546875*x^6-3167.2265625*x^5-24885.3515625*x^4-132721.875*x^3-470559.375*x^2-1013512.5*x-1013512.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^8), x = -1. .. 1.), (9, 1) = 0.6793714722e-8, (9, 2) = 0.68406690337078e-4, (9, 3) = 0.1624492831e-8, (9, 4) = 0.386156856246160e-3, (9, 5) = 0.815546544069708e28, (9, 6) = -0.277132564813689e67, (9, 7) = Int(0.305175781250000e-4*(6435.*(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(7.21875*x^12-54.140625*x^10+263.935546875*x^8-1004.5341796875*x^6+2866.74609375*x^4-5457.375*x^2+5197.5)*exp(x^2)+6435.*(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(-.2255859375*x^6-8.12109375*x^5-94.74609375*x^4-606.375*x^3-2338.875*x^2-5197.5*x-5197.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^7), x = -1. .. 1.), (9, 8) = Int(0.305175781250000e-4*(6435.*(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(13.40625*x^14-117.3046875*x^12+692.09765625*x^10-3321.18896484375*x^8+12740.7553710938*x^6-36669.4453125*x^4+70382.8125*x^2-67567.5)*exp(x^2)+6435.*(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(.20947265625*x^7+10.26416015625*x^6+164.2265625*x^5+1478.0390625*x^4+8445.9375*x^3+30968.4375*x^2+67567.5*x+67567.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^8), x = -1. .. 1.), (9, 9) = Int(0.305175781250000e-4*(6435.*(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(25.13671875*x^16-251.3671875*x^14+1740.7177734375*x^12-10086.1083984375*x^10+48652.3155212402*x^8-187783.857421875*x^6+543707.2265625*x^4-1049709.375*x^2+1013512.5)*exp(x^2)+6435.*(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(-.196380615234375*x^8-12.568359375*x^7-263.935546875*x^6-3167.2265625*x^5-24885.3515625*x^4-132721.875*x^3-470559.375*x^2-1013512.5*x-1013512.5)*exp(-1.*x))/((1.+x)^(1/2)*(1.-1.*x)^(1/2)*x^9), x = -1. .. 1.)})
G := Vector(N+1):
for i from 0 to N do G[i+1] := evalf(Int(phi[i]*g(x)*w1, x = -1 .. 1, epsilon = 0.1e-24)) end do;
12.1371438004283064513879002531
4.46097069166807099930513349705
1.64462130209908212771492915391
.558865818865511551008391285165
.171719662671619385727054996451
0.517117975778639694922219536331e-1
0.149941760016965250201187504967e-1
0.424140250877931274184205530350e-2
0.114813711532765772695860143813e-2
G[1]
C := simplify(Matrix(A+B))
C := Matrix(9, 9, {(1, 1) = 6.55499934996939323846264338328, (1, 2) = -.219853801558141, (1, 3) = -.371445167328337, (1, 4) = -0.940736800940411e-2, (1, 5) = -0.845889943042008000000000000000e-1, (1, 6) = 0.334727115780295e-1, (1, 7) = -0.257221402047336e84, (1, 8) = Float(infinity), (1, 9) = Float(undefined), (2, 1) = .765483256689808, (2, 2) = .533713222730410154807830422910, (2, 3) = -.165532642864785, (2, 4) = -0.499428359428865e-1, (2, 5) = -0.73434901130578e-2, (2, 6) = -0.111757807839544e-1, (2, 7) = 0.123803381671991e68, (2, 8) = Float(undefined), (2, 9) = Float(-infinity), (3, 1) = 0.515972557667626000000000000000e-1, (3, 2) = .125811948358948, (3, 3) = .224980824190952557079404612887, (3, 4) = -0.716662760034337e-1, (3, 5) = -0.516850043604370000000000000000e-2, (3, 6) = 0.716801959003042e67, (3, 7) = 0.666666666666666666666666666667e-32+43.3125*(Int(((-45.+.1250*x^14-1.00000*x^12+5.03906250*x^10-19.679687500*x^8+58.337890625*x^6-119.3203125*x^4+137.25*x^2)*exp(x^2)+(2.*x^2-1.)*(-0.1953125e-2*x^6-0.703125e-1*x^5-.8203125*x^4-5.25*x^3-20.25*x^2-45.*x-45.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^7), x = -1. .. 1.)), (3, 8) = Float(-infinity), (3, 9) = Float(infinity), (4, 1) = 0.899030920810901e-1, (4, 2) = 0.213841186693960000000000000000e-2, (4, 3) = 0.393313755295959e-1, (4, 4) = .153222110415871512971808758949, (4, 5) = -0.341293873201944e-1, (4, 6) = -0.107499338429209e52, (4, 7) = 0.188236331912532e46, (4, 8) = Float(-infinity), (4, 9) = 0.3125e-1*(Int(((-30405375.+1005.46875*x^18-10808.7890625*x^16+77169.7265625*x^14-455665.869140624*x^12+2248675.87280274*x^10-8970923.7625122*x^8+27381804.7851562*x^6-58299591.796875*x^4+72031781.25*x^2)*exp(x^2)+(-7.855224609375*x^10-502.734375*x^9-10551.53045654296875*x^8-126312.01171875*x^7-987495.99609375*x^6-5213858.203125*x^5-18075814.453125*x^4-36558843.75*x^3-26423718.75*x^2+30405375.*x+30405375.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^8), x = -1. .. 1.)), (5, 1) = 0.463651486782721999999999999997e-3, (5, 2) = 0.157757505144122e-1, (5, 3) = 0.752967475514400000000000000004e-4, (5, 4) = 0.205695133452456e-1, (5, 5) = 0.323627840089429e50, (5, 6) = -0.194229780735106e-1, (5, 7) = -0.429629629629629629629629629630e-32+31.58203125*(Int(((8.*x^4-8.*x^2+1.)*(0.625e-1*x^12-.46875*x^10+2.28515625*x^8-8.697265625*x^6+24.8203125*x^4-47.25*x^2+45.)*exp(x^2)+(8.*x^4-8.*x^2+1.)*(-0.1953125e-2*x^6-0.703125e-1*x^5-.8203125*x^4-5.25*x^3-20.25*x^2-45.*x-45.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^7), x = -1. .. 1.)), (5, 8) = Float(infinity), (5, 9) = Float(-infinity), (6, 1) = 0.63086454697723e-2, (6, 2) = 0.148539925066999999999999999996e-4, (6, 3) = 0.678853225186884e-2, (6, 4) = 0.107783343780000000000000000074e-5, (6, 5) = 0.131282639565718e-1, (6, 6) = 0.951280655078543393867357756671e-1, (6, 7) = -0.124971422339580e-1, (6, 8) = -0.810764520616245e86, (6, 9) = 0.973719186742316e103, (7, 1) = 0.225892591374999999999999998267e-5, (7, 2) = 0.119535935984917e-2, (7, 3) = 0.472540247360000000000000006667e-6, (7, 4) = 0.406635846209016e-2, (7, 5) = -0.353102865787386e29, (7, 6) = 0.914224761911803e-2, (7, 7) = 0.799362781468415055263543670536e-1+26.05517578125*(Int(((32.*x^6-48.*x^4+18.*x^2-1.)*(0.625e-1*x^12-.46875*x^10+2.28515625*x^8-8.697265625*x^6+24.8203125*x^4-47.25*x^2+45.)*exp(x^2)+(32.*x^6-48.*x^4+18.*x^2-1.)*(-0.1953125e-2*x^6-0.703125e-1*x^5-.8203125*x^4-5.25*x^3-20.25*x^2-45.*x-45.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^7), x = -1. .. 1.)), (7, 8) = .11279296875*(Int(((32.*x^6-48.*x^4+18.*x^2-1.)*(26.8125*x^14-234.609375*x^12+1384.1953125*x^10-6642.3779296875*x^8+25481.5107421876*x^6-73338.890625*x^4+140765.625*x^2-135135.)*exp(x^2)+(32.*x^6-48.*x^4+18.*x^2-1.)*(.4189453125*x^7+20.5283203125*x^6+328.453125*x^5+2956.078125*x^4+16891.875*x^3+61936.875*x^2+135135.*x+135135.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^8), x = -1. .. 1.)), (7, 9) = 0.157777777777777777777777777778e-31+1.24072265625*(Int(((32.*x^6-48.*x^4+18.*x^2-1.)*(4.5703125*x^16-45.703125*x^14+316.494140625*x^12-1833.837890625*x^10+8845.8755493164*x^8-34142.51953125*x^6+98855.859375*x^4-190856.25*x^2+184275.)*exp(x^2)+(32.*x^6-48.*x^4+18.*x^2-1.)*(-0.3570556640625e-1*x^8-2.28515625*x^7-47.98828125*x^6-575.859375*x^5-4524.609375*x^4-24131.25*x^3-85556.25*x^2-184275.*x-184275.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^9), x = -1. .. 1.)), (8, 1) = 0.340365610524644e-3, (8, 2) = 0.581375540399999999999999928148e-7, (8, 3) = 0.59941816605747e-3, (8, 4) = 0.123344101900000000000000128889e-7, (8, 5) = 0.275221040025479e-2, (8, 6) = -0.804784322000000000000001355556e-8, (8, 7) = -0.187505962866890e33, (8, 8) = 0.689246479939602777242545307758e-1+.104736328125*(Int(((64.*x^6-112.*x^4+56.*x^2-7.)*(26.8125*x^14-234.609375*x^12+1384.1953125*x^10-6642.3779296875*x^8+25481.5107421876*x^6-73338.890625*x^4+140765.625*x^2-135135.)*exp(x^2)+(64.*x^6-112.*x^4+56.*x^2-7.)*(.4189453125*x^7+20.5283203125*x^6+328.453125*x^5+2956.078125*x^4+16891.875*x^3+61936.875*x^2+135135.*x+135135.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^7), x = -1. .. 1.)), (8, 9) = 1.152099609375*(Int(((64.*x^6-112.*x^4+56.*x^2-7.)*(4.5703125*x^16-45.703125*x^14+316.494140625*x^12-1833.837890625*x^10+8845.8755493164*x^8-34142.51953125*x^6+98855.859375*x^4-190856.25*x^2+184275.)*exp(x^2)+(64.*x^6-112.*x^4+56.*x^2-7.)*(-0.3570556640625e-1*x^8-2.28515625*x^7-47.98828125*x^6-575.859375*x^5-4524.609375*x^4-24131.25*x^3-85556.25*x^2-184275.*x-184275.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^8), x = -1. .. 1.)), (9, 1) = 0.679371472199999999999970814815e-8, (9, 2) = 0.68406690337078e-4, (9, 3) = 0.162449283100000000000009666667e-8, (9, 4) = 0.386156856246160e-3, (9, 5) = 0.815546544069708e28, (9, 6) = -0.277132564813689e67, (9, 7) = 0.157777777777777777777777777778e-31+22.6819610595703125*(Int(((128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(0.625e-1*x^12-.46875*x^10+2.28515625*x^8-8.697265625*x^6+24.8203125*x^4-47.25*x^2+45.)*exp(x^2)+(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(-0.1953125e-2*x^6-0.703125e-1*x^5-.8203125*x^4-5.25*x^3-20.25*x^2-45.*x-45.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^7), x = -1. .. 1.)), (9, 8) = 0.196380615234375e-1*(Int(((128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(134.0625*x^14-1173.046875*x^12+6920.9765625*x^10-33211.8896484375*x^8+127407.553710938*x^6-366694.453125*x^4+703828.125*x^2-675675.)*exp(x^2)+(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(2.0947265625*x^7+102.6416015625*x^6+1642.265625*x^5+14780.390625*x^4+84459.375*x^3+309684.375*x^2+675675.*x+675675.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^8), x = -1. .. 1.)), (9, 9) = 0.605783039009416503435830836897e-1+.2160186767578125*(Int(((128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(22.8515625*x^16-228.515625*x^14+1582.470703125*x^12-9169.189453125*x^10+44229.377746582*x^8-170712.59765625*x^6+494279.296875*x^4-954281.25*x^2+921375.)*exp(x^2)+(128.*x^8-256.*x^6+160.*x^4-32.*x^2+1.)*(-.17852783203125*x^8-11.42578125*x^7-239.94140625*x^6-2879.296875*x^5-22623.046875*x^4-120656.25*x^3-427781.25*x^2-921375.*x-921375.)*exp(-1.*x))/((1.+x)^(1/2)*(1.-x)^(1/2)*x^9), x = -1. .. 1.))})
C1 := MatrixInverse(C)
t := C1.G
s[u] := add(subs(theta = sols[l+1], ((x+1)*(1/2))*k(x, ss(x, theta)))*u(ss(x, sols[l+1])), l = 0 .. N)
U := unapply(add(t[j+1].phi[j], j = 0 .. N), x)
with(numapprox)
E := infnorm(abs(u(x)-U(x)), x = -1 .. 1)
E[1] := (int((u(x)-U(x))^2, x = -1 .. .1))^(1/2)
plot([U(x), u(x)], x = -1 .. 1)
Download chebichef_cont.mw
 Is there anyone who could help me with this error? I am sure there is at least one solution for the equation.
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/EQ.mw .
Download EQ.mw
Typically sets are created like:
A:={a,b,c};
B:={c,q,w,e};
and then you can carryout A union B or B\A
what if  you wanted to create the set as
A:={values in some three dimensional space};
B:={volume, based on values taken from A};
Can these relationships be set up in Maple? If so, how? If there are commands that specifically handle these types of sets, what does maple call them?  I've seen the term 'set function' but what might Maple call them?
Note: I am not even sure i 'tagged' this correctly because it I am not sure the proper terms for these functions/sets.
I read a posting by Mr. Stephen Forrest on Thingiverse about using the exportplot command to export a 3D plot as a .stl file. I have a 3D printer and need the convert the plot from the Maple file into an .stl file.
Here is the posting I am referencing:
Thingiverse/3dmodelimportexport.pdf
I was able to follow the commands successfully in the referenced paper for a hyperboloid or revolution that I plotted in Maple - it was very helpful. However, I could not figure out how to access the temporary .stl file that was created so that I could open it using my 3D printer's software.
My question is: Once I execute the "exportplot(stl, hyprev)" command that I inputted, how can I find the file in the Temporary Directory in order to open it from the software I use for my 3D printer?
I would appreciate any further details you can provide for accessing the temporary .stl file I created in order to be able to print the object.
I wote a command that creates a plot with a single point:
plots[pointplot](a*[1, 1])
Before hitting Enter I called the context menu and chose Explore. As I change the parameter a the point remains fixed in the picture but the scales change. I wanted the opposite: the scales should stay fixed and the point should move. How can I do this using Explore or in some other way? I would like to see the point move as I drag a slider control.
Thanks for the help.
First 1121 1122 1123 1124 1125 1126 1127 Last Page 1123 of 2463
