I am trying to solve an optimization problem but I am getting an error message which does not make sense.
I have a procedure file called f. The decsiion vector is x[1..4]. and returns the objective function value Ls.
I then specify the constraints as a set and ask it to optimize
constraints:={x[1]+x[2]+x[3]+x[4]=65,x[1]<=20,x[2]<=15,x[3]<=20,x[4]<=15};
sol := NLPSolve( f,constraints, assume=nonnegative,minimize);
Error, (in Optimization:-NLPSolve) constraints must be specified as a set or list of procedures
This error makes no sense to me. Can anyone help?
 Hello,every one,i want to solve system of equations but i recieve an error ,how can i find the coeffecients c1,c2,c3,c4?thank.
A := 45*x*c4+72*c3 = 0:
B := 56*c2*c4+28*c3^2 = 0:
C := M^2*(-x^5*c4-x^4*c3-x^3*c2-x^2*c1+c1+c2+c3+c4+1)^n*c4+42*beta*c1*c4+42*beta*c2*c3 = 0:
E := M^2*(-x^5*c4-x^4*c3-x^3*c2-x^2*c1+c1+c2+c3+c4+1)^n*c3+30*beta*c1*c3+15*beta*c2 = 0:
F := M^2*(-x^5*c4-x^4*c3-x^3*c2-x^2*c1+c1+c2+c3+c4+1)^n*c2+20*beta*c1*c2-20*beta*c1*c4-20*beta*c2*c4-20*beta*c3*c4-20*beta*c4^2-20*beta*c4-20*c4 = 0:
G := M^2*(-x^5*c4-x^4*c3-x^3*c2-x^2*c1+c1+c2+c3+c4+1)^n*c1+6*beta*c1^2-12*beta*c1*c3-12*beta*c2*c3-12*beta*c3^2-12*beta*c3*c4-12*beta*c3-12*c3 = 0:
beta*c1+beta*c2^2+beta*c2*c3+beta*c2*c4+beta*c2+c2 = 0:
M^2*(-x^5*c4-x^4*c3-x^3*c2-x^2*c1+c1+c2+c3+c4+1)^n = 0:
with(SolveTools):
PolynomialSystem({{45*c4*x+72*c3 = 0}, {30*beta*c1*c3+15*beta*c2 = 0}, {42*beta*c1*c4+42*beta*c2*c3 = 0}, {20*beta*c1*c2-20*beta*c1*c4-20*beta*c2*c4-20*beta*c3*c4-20*beta*c4^2-20*beta*c4-20*c4 = 0}, {6*beta*c1^2-12*beta*c1*c3-12*beta*c2*c3-12*beta*c3^2-12*beta*c3*c4-12*beta*c3-12*c3 = 0}}, {c1, c2, c3, c4}, {beta = 2, x = 1/5})
Error, invalid input: too many and/or wrong type of arguments passed to SolveTools:-PolynomialSystem; first unused argument is {beta = 2, x = 1/5}
Download Numerical.mw
Here is my question.
convert(diff(lambda(t-t1), t), diff)
eval(diff(lambda(t2), t2), {t2 = t-t1})
subs(lamda(t-t1) = sin(t-t1), %)
I am trying to substitute value of lambda(t-t1) further but it is not taking the value.
Sunit
Download question2.mw
#Hello people in Mapleprimes,
#After
restart;interface(typesetting=extended);
diff(f(x),x);
#shows f'(x).
#But,
diff(f(t1),t1);
#shows just df(t1)/dt1, not f'(t).
#Can't I show f'(t1) not df(t1)/dt1?
#Is this a way peculiar to Maple?
#I hope someone could give me some hints.
#Best wishes.
#taro
I would like to know how one would add a superscript in maple? For example, I need to label an axis with unit cm^-1 but it shows 1/cm (like a fraction) when executed. How could I avoid this so the graph label would output cm^-1? Thank you for your help in advance!
Gambia Man
Please how do I type accents in code edit region of maple 2015.1 (for instance putting "Hat over" on alpha)?
hello every one.please help me with solving this equations.i can not solve this and i need it.thanks
eq1 := (cos(beta2)-1)*w11-sin(beta2)*w12+(cos(alpha2)-1)*z11-sin(alpha2)*z12-cos(delta2) = 0; eq2 := (cos(beta2)-1)*w12+sin(beta2)*w11+(cos(alpha2)-1)*z12+sin(alpha2)*z11-2*sin(delta2) = 0; eq3 := (cos(beta3)-1)*w11-sin(beta3)*w12+(cos(alpha3)-1)*z11-sin(alpha3)*z12-3*cos(delta3) = 0; eq4 := (cos(beta3)-1)*w12+sin(beta3)*w11+(cos(alpha3)-1)*z12+sin(alpha3)*z11-4*sin(delta3) = 0; eq5 := (cos(beta4)-1)*w11-sin(beta4)*w12+(cos(alpha4)-1)*z11-sin(alpha4)*z12-5*cos(delta4) = 0; eq6 := (cos(beta4)-1)*w12+sin(beta4)*w11+(cos(alpha4)-1)*z12+sin(alpha4)*z11-6*sin(delta4) = 0; eq7 := (cos(beta5)-1)*w11-sin(beta5)*w12+(cos(alpha5)-1)*z11-sin(alpha5)*z12-7*cos(delta5) = 0; eq8 := (cos(beta5)-1)*w12+sin(beta5)*w11+(cos(alpha5)-1)*z12+sin(alpha5)*z11-8*sin(delta5) = 0; alpha2 := -20; alpha3 := -45; alpha4 := -75; alpha5 := -90; delta2 := 15.5; delta3 := -15.9829; delta4 := -13.6018; delta5 := -16.7388; P21 = .5217; P31 = 1.3421; P41 = 2.3116; P51 = 3.1780;
   If I have a fraction like this w^2/(w^4+2*w^2+1) , how can I make it presented in Maple as  '1/(w^2+1/w^2+2)' (Both numerator and denominator divided by w^2) ?
Thanks in advance!
When using units, then e.g. "2 m" is show as expected below, but "1 m" shown as only "m".  Even through correct, it is a non-standard way to write physical values.
How to get the physical values in a format of "{numerical} {unit}" even when the numerical part is 1?
In a simple example below I try to write an equation with an unknown value present among other values that have unit, but I get an error since the unknown value d does not have a unit yet.
How to write such expressions, e.g. for use in solve later?
Dear MapleSoft,
Would it be possible you once design a MapleSim webinar for users with more emphasis on Modelica (language, examples, etc.), on how to build more complex custom components, not just a simple DC motor? I think this would be very useful and could extend / enhance the use of MapleSime even more.
Tx in advance,
best regards
Andras
you write:
In the code below the new function g is defined based on existing function f, but the new function g is then dependent on f at the time of definition, which is shown since later changes to f will change value of g.
How to fix definition of g based on f at the when g is defined, so later changes of f does not alter g ?
Hello every one,please help me for plotting this equation(T).L=1,t=10,a=0.1,x=0..1
First 1134 1135 1136 1137 1138 1139 1140 Last Page 1136 of 2463
