Hi all.
Assume that we have partitioned [0,a], into N equidistant subintervals and in each subinterval we have M sets of poly nomials of the following form:
where Tm(t)=tm( namely Taylor Series) and tf is a(final point)
for Example with N=4, M=3 we have:
now we want to approximate a function, asy f(t), in this interval with following form:
Assume that we have
where '"." means common derivetive. How can we do the later integran in right way?
Note that t is unknown
Mahmood   Dadkhah
Ph.D Candidate
Let B is a list of polynomial conditions such that  are none zero. Consider one polynomial f. How can I detect that f is none zero w.r.t. B? For example if B=[a-1,b+2,b-c,ac-1] and f=a^2c-ac-a+1. From B we can conclude that a<>1 and b<>2 and b<>c and ac<>1. How can I deduce that f<>0 w.r.t. B automatically?
I have been trying to plot Riemann Zeta Function on certain range, but it takes a lot of time(several minutes ,maybe hours).These are the basic things.
How to speed up ploting Zeta?
The same problem with Optimization.
Zeta-Problems.mw
Mathematica don't have this such problems.
Mathematica ploting Zeta with 0.125 second and optimizing 3.42 second.Maple few hours maybe......
I want to make a for loop inside another loop, but this code does not seem to work well.
for i from 0 to 10 do
  for n from 0 to 10 do
  i+n
  end do
How would I find inflection points? I believe it would the same as if I was finding critical points for f '.
Function is:(7-x)*sin(x^2-7)
So would it be:
a:=fsolve(f2,-2.4..2.4);
b:=fsolve(f2,-2.4..-0.06);
c:=fsolve(f2,-0.06..2.4);
d:=fsolve(f2,1.49..3);
e:=fsolve(f2,-3 ..-1.52);
Plz and thanks!
I am a new use of Maple. I have a expression :
2.560000000*10^(-30)*k1*(2.309486127*10^38*n-1.154743064*10^38-1.186994552*10^37*k2^2*n^2+2.373989104*10^37*k2^2*n+8.541613702*10^37*k2*n^2-1.154743064*10^38*n^2+7.119519043*10^37*n^2*k1^2+6.495962587*10^37*k1*n^2-1.293058266*10^38*k2*n^2*k1-1.186994552*10^37*k2^2-1.708322740*10^38*k2*n+1.293058266*10^38*k2*n*k1+8.541613702*10^37*k2-3.529088273*10^37*k1-2.966874313*10^37*k1*n)/(1.620847396*10^9*n-1.620847396*10^9)
I want to simplify it. Obviously, it can be simplifed by simplifying the coeffecient of each terms.
When I use 'simplify' command in Maple 18, I couldn't got what I want.
Any suggetstions?
  I have the following input
with( Statistics ):
a:=2;c:=0.3;
g:= exp(-a*x) + c*a*exp(-a*x);
#f := x -> piecewise( x < 0, 0, x>0, g );
 f :=x -> piecewise( x < 0, 0, x>0, exp(-a*x) + c*a*exp(-a*x));
norm_factor:=int( f(x), x=0..infinity );
print(norm_factor);
randomize():
F := Distribution( PDF = 1/norm_factor*f ):
X := RandomVariable( F ):
N := 20;
S := convert( Sample(X,N), list );
print(`cc`,S[1]);
The code works. However, if I comment out
 , then use
i.e.
 #f :=x -> piecewise( x < 0, 0, x>0, exp(-a*x) + c*a*exp(-a*x));
It is said "
Error, (in Statistics:-Sample) unable to construct the envelopes for _R, try to specify the initial range"
The norm_factors are actually the same for both inputs. What is the reason for the error message?  Suppose I still want to use something like
,how to fix the problem?
Thank you very much
I'm drawing a complete blank on this.
The probability of a branch breaking in a particular tree as someone climbs is 2%.  After the person has climbed over 40 branches, did any of them break?  I'm trying to set that up as a simulation in Maple but I'm not sure about how to do it.
I guess if I generate a random number and it falls under .02 it breaks, is that how I determine that?
randomize():
n := 0;
for i to 40 do
ran := evalf(rand()*10^(-12));
if ran < 0.2e-1 then n := n+1: end if:
print("Branch broke", n, "times")
I'm not sure I've got the probability right.
Shading is not valid as an option in the command defining a plottools object e.g. a parallelepiped, and yet shading can be selected in the actual display of the object. Is there a way to code for shading when creating the object?
Ive been trying to solve critical points for maple but i keep getting this werid equation:
(1/7)*RootOf(tan(_Z)^2+4*_Z*tan(_Z)+4*_Z^2+28*tan(_Z)-140*_Z-1176)+1+(1/14)*tan(RootOf(tan(_Z)^2+4*_Z*tan(_Z)+4*_Z^2+28*tan(_Z)-140*_Z-1176)).
What I have typed
f:=x->(7-x)*sin(x^2-7);
f1:=D(f);
When I try putting:
solve(f1(x)=0);
I get that werid equation
Can I make a button with the code so it will execute the entire worksheet?
I have tried without sucess to run the
Equation manipulator.
I get the following error:
Error, (in Maplets:-Tools:-CleanElements) invalid input: op expects 1 or 2 arguments, but received 0
Do I have to load some package for it to run?
I have searched for a solution but can not find one.
Getting desperate.. anyone?
TIA
LWc
I want write loop for this code:
V := 24;
eq := {Eq2, Eq3};
ans := fsolve(eq, {a1 = 0, a3 = 0});
r := 0;
W1 := rhs(ans[1])*phi11(r)+rhs(ans[2])*phi21(r)
V and W1 is Variable, I change V and solve eq and determinen a1 and a3 after i calculated W1
I want write Loop for this,
can you help me????????/
%piecewise(``, x+y-2*z = 1, ``, 2*x+y-3*z = 5, ``, -x+y+z = 1); What does % here do?
I can find no help page to explain the functionality of the percent sign in this command and removing it produces an error. Please explain this.
How  can we draw diagrams in tripartite coordinate system?
First 1259 1260 1261 1262 1263 1264 1265 Last Page 1261 of 2470
