Dear All, I need your help to plot the numerical solution. many thanks.
The variable t in [0,T], x in [0,1], b in [0,2].
Difference finie for waves equation is :
pde:=diff(u(x, y,t), t$2) = c^2*(diff(u(x, y,t),x$2)+diff(u(x,y,t),y$2));
i: according to x, j according to y, and k according to t.
u[i,j,k+1]=2*u[i,j,k]-u[i,j,k-1]+(c*dt/dx)^2*(u[i-1,j,k]-2*u[i,j,k]+u[i+1,j,k])+ (c*dt/dy)^2*(u[i,j-1,k]-2*u[i,j,k]+u[i,j+1,k])
Boundary condition: u(t=0)=1, diff(u(x,y,t),t=0)=0, and the normal derivative on the boundary of Omega =0.
How can solve this problem and plot the numerical solution.
Using the two images from the branched question I tried to calculate the offset of the two images.  But it is too cumbersome and slow, can someone figure out a faster way?
Here's what I did,
I created both jpg images into a single row vector and then into an Array.  I then used a for loop with CircularShift to cycle one array and subtract it from the other.  I then took the absolute value and added all the values in the array and stored that value in another array.  The smallest value would indicate the highest probable position that both images have lined up.
Something like...
with(ArrayTools):
a:=convert(convert(img1,vector),Array)  #after img1 is padded to 184x184 from Markyan Hirnyk's answer
b:=convert(convert(img2,vector),Array)
for i from 1 to 100 do
  aa:=abs(CircularShift(a,i)-b):
  bb[i]:=add(k,k=aa):
min(convert(convert(bb,array),Array))
The problem is 100 shifts takes a long time, let alone go through the full image.  Is there a faster way to accomplish this?
As i asked at title; i want to determine natural frequency of a single or multi degree of freedom vibration system using MapleSim. but i can't and i don't know how i can do it. can every one help me plz?؟؟؟
Say I have a 3x3 matrix with real entries (like 3.4) and want to compute, say, A^(11). How can I do it and only have 5 digits in the output? I set Digits:=5; and used MatrixPower -- but got 10 digits, which is way too many for the classroom presentation.
Please see the attached worksheet for the error at the end, any idea what happens?
Besides, anyone know how to make plot array with each element has a plot and scatterplot in it?  I made my plot by making table first and then type the cmd individually.
Raw Data
avicel102_aero200 := Matrix(12, 3, {(1, 1) = 50, (1, 2) = 1.6621, (1, 3) = .22, (2, 1) = 100, (2, 2) = 3.33221, (2, 3) = .103, (3, 1) = 150, (3, 2) = 4.95533, (3, 3) = 0.43e-1, (4, 1) = 200, (4, 2) = 5.62147, (4, 3) = 0.37e-1, (5, 1) = 50, (5, 2) = 1.88627, (5, 3) = .207, (6, 1) = 50, (6, 2) = 1.90375, (6, 3) = .199, (7, 1) = 100, (7, 2) = 4.04708, (7, 3) = 0.89e-1, (8, 1) = 100, (8, 2) = 4.20413, (8, 3) = 0.87e-1, (9, 1) = 150, (9, 2) = 5.50509, (9, 3) = 0.41e-1, (10, 1) = 150, (10, 2) = 4.90453, (10, 3) = 0.49e-1, (11, 1) = 200, (11, 2) = 6.22001, (11, 3) = 0.16e-1, (12, 1) = 200, (12, 2) = 6.24435, (12, 3) = 0.23e-1}); avicel102_syloid := Matrix(13, 3, {(1, 1) = 50, (1, 2) = 1.76578, (1, 3) = .235, (2, 1) = 100, (2, 2) = 4.08314, (2, 3) = .128, (3, 1) = 150, (3, 2) = 4.85921, (3, 3) = 0.73e-1, (4, 1) = 200, (4, 2) = 5.66786, (4, 3) = 0.51e-1, (5, 1) = 50, (5, 2) = 2.06221, (5, 3) = .224, (6, 1) = 50, (6, 2) = 2.17294, (6, 3) = .216, (7, 1) = 100, (7, 2) = 4.03728, (7, 3) = .109, (8, 1) = 100, (8, 2) = 3.67978, (8, 3) = .116, (9, 1) = 150, (9, 2) = 5.78427, (9, 3) = 0.6e-1, (10, 1) = 150, (10, 2) = 5.43599, (10, 3) = 0.59e-1, (11, 1) = 200, (11, 2) = 6.26332, (11, 3) = 0.38e-1, (12, 1) = 200, (12, 2) = 6.10814, (12, 3) = 0.39e-1, (13, 1) = 200, (13, 2) = 6.83857, (13, 3) = 0.25e-1}); avicel301_101_aero200 := Matrix(12, 3, {(1, 1) = 50, (1, 2) = 1.106, (1, 3) = .2597543205, (2, 1) = 50, (2, 2) = 1.06, (2, 3) = .2564849561, (3, 1) = 50, (3, 2) = 1.129, (3, 3) = .2552025392, (4, 1) = 100, (4, 2) = 2.865, (4, 3) = .1280363098, (5, 1) = 100, (5, 2) = 2.793, (5, 3) = .127659333, (6, 1) = 100, (6, 2) = 3.088, (6, 3) = .1347147061, (7, 1) = 150, (7, 2) = 4.216, (7, 3) = 0.802489497e-1, (8, 1) = 150, (8, 2) = 4.044, (8, 3) = 0.838493001e-1, (9, 1) = 150, (9, 2) = 4.071, (9, 3) = 0.855901289e-1, (10, 1) = 200, (10, 2) = 4.826, (10, 3) = 0.627298821e-1, (11, 1) = 200, (11, 2) = 4.924, (11, 3) = 0.614759445e-1, (12, 1) = 200, (12, 2) = 4.76, (12, 3) = 0.61001365e-1})
X[1] := Column(avicel102_aero200, 3):
X[2] := Column(avicel102_syloid, 3):
X[3] := Column(avicel301_101_aero200, 3):
S := Array(1 .. 3):
S[1] := ScatterPlot(X[1], Y[1], labels = [Porocity, Tensile*Strength], title = Compactability*of*Avicel102*with*Aerosil200):
with(plots):NULL
vSST := Array(1 .. 3):
tpfit := proc (x, y) options operator, arrow; Fit(a*exp(-k*p)+c, x, y, p, output = [leastsquaresfunction, residualsumofsquares, degreesoffreedom]) end proc:SST := proc (y) options operator, arrow; Variance(y)*(NumElems(y)-1) end proc:NULL
for i to 3 do fnTP[i] := tpfit(X[i], Y[i])[1] end do:
for i to 3 do fnPC[i] := Fit(c*p^2+b*p+a, P[i], X[i], p, output = [leastsquaresfunction, residualsumofsquares, degreesoffreedom])[1] end do:
for i to 3 do vSST[i] := SST(Y[i]) end do:
for i to 3 do pSST[i] := SST(X[i]) end do:
for i to 3 do vSSR[i] := tpfit(X[i], Y[i])[2] end do:
for i to 3 do Rsquare[i] := 1-vSSR[i]/vSST[i] end do:
s := Array(1 .. 3):
for i to 3 do s[i] := plot(fnTP[i], p = 0 .. .26, legend = typeset(fnTP[i], R^2, "= ", Rsquare[i])) end do
for i to 3 do ps[i] := plot(fnPC[i], p = 0 .. 200, legend = typeset(fnPC[i], R^2, "= ", pRsquare[i])) end do
G := Array(1 .. 3):
G[1] := [S[1], s[1]]:
pG := [[PS[1], ps[1]], [PS[2], ps[2]], [PS[3], ps[3]]]:NULL
Table 1: Compactability Curve
display(G[1])
display(G[2])
display(G[3])
Table 2: Compressibility Curve
display(pG[1])
display(pG[2])
display(pG[3])
ff := proc (x) options operator, arrow; unapply(x, p) end proc:
gtp := map(ff, fnTP):
gpc := map(ff, fnPC):
TS1 := proc (pressure) options operator, arrow; (`@`(gtp[1], gpc[1]))(pressure/Unit('MPa'))*Unit('MPa') end proc:
TS2 := proc (pressure) options operator, arrow; (`@`(gtp[2], gpc[2]))(pressure/Unit('MPa'))*Unit('MPa') end proc:
TS3 := proc (pressure) options operator, arrow; (`@`(gtp[3], gpc[2]))(pressure/Unit('MPa'))*Unit('MPa') end proc:
por1 := proc (p) options operator, arrow; gpc[1](p/Unit('MPa')) end proc:
por1(x*Unit('MPa'))
HFloat(0.36333333333333295)-HFloat(0.0036139999999999957)*x+HFloat(9.666666666666651e-6)*x^2
por1(x);
HFloat(0.36333333333333295)-HFloat(0.0036139999999999957)*x/Units:-Unit('MPa')+HFloat(9.666666666666651e-6)*x^2/Units:-Unit('MPa')^2
ts := 2/3*(10*P/(Pi*D^2*(2.84*t/D-.126*t/W+3.15*W/D+0.1e-1))):
Target Weight of Tablet, m__t:
m__t := 700*Unit('mg')
700*Units:-Unit('mg')
Tablet True Density:NULL
`ρ__true1` := 1.8*Unit('g'/'cm'^3)
1800.0*Units:-Unit(('kg')/('m')^3)
Width of tablet w;
d := 7.747*Unit('mm')
7.747*Units:-Unit('mm')
Length of tablet, l:
l := 17.018*Unit('mm')
17.018*Units:-Unit('mm')
Cup Depth, h:
hh := 1.6764*Unit('mm')
1.6764*Units:-Unit('mm')
Cup Volume", `v__cup`"
v__cup := 119.789438*Unit('mm'^3)
119.789438*Units:-Unit(('mm')^3)
Die cross sectional area, v__die:
a__die := 118.9610524*Unit('mm'^2)
118.9610524*Units:-Unit(('mm')^2)
Equation to solve tablet thickness using tablet dimension and porocity:
Tablet bulk density:
`ρ__bulk` := `ρ__true`*sf
`ρ__true`*sf
Tablet volume:``
V__tablet := 2*V__cup+A__die*(t-2*H)
Tablet bulk Density:``
`ρ__bulk` := m__tablet/V__tablet
m__tablet/(2*V__cup+A__die*(t-2*H))
(14)
eq1 := m__tablet/(2*V__cup+A__die*(t-2*H)) = `ρ__true`*sf
(15)
Function for thickness:
thickness := unapply(simplify(solve(eq1, t), size), sf, A__die, H, V__cup, `ρ__true`, m__tablet)
proc (sf, A__die, H, V__cup, `ρ__true`, m__tablet) options operator, arrow; (2*sf*(A__die*H-V__cup)*`ρ__true`+m__tablet)/(A__die*sf*`ρ__true`) end proc
(16)
simplify(thickness(1-por[1](100*Unit(MPa)), a__die, hh, v__cup, `ρ__true1`, m__t))
HFloat(0.005719286791216391)*Units:-Unit('m')
(17)
t2 := proc (cc, A__die, H, V__cup, `ρ__true`, m__tablet) options operator, arrow; simplify(thickness(1-cc, A__die, H, V__cup, `ρ__true`, m__tablet)) end proc:
Tablet tensile strength:NULL
eq2 := `σ__t` = ts
`σ__t` = (20/3)*P/(Pi*D^2*(2.84*t/D-.126*t/W+3.15*W/D+0.1e-1))
(18)
Break force of tablet (N)
breakforce := unapply(subs(W = t-2*h, solve(eq2, P)), `σ__t`, D, h, t)
proc (`σ__t`, D, h, t) options operator, arrow; 0.9424777961e-3*`σ__t`*D*(5.*D*(t-2*h)-63.*t*D+1575.*(t-2*h)^2+1420.*t*(t-2*h))/(t-2*h) end proc
(19)
kp := simplify(breakforce(TS[1](100*Unit('MPa')), d, hh, 0.5719e-2*Unit('m')))
HFloat(286.99924404612904)*Units:-Unit('N')
(20)
convert(kp, units, kilopond)
HFloat(29.265778226624693)*Units:-Unit('kilopond')
(21)
t2(por[1](100*Unit('MPa')), a__die, hh, v__cup, `ρ__true1`, m__t)
(22)
hh
(23)
simplify(breakforce(TS[1](100*Unit('MPa')), d, hh, t2(por[1](100*Unit('MPa')), a__die, hh, v__cup, `ρ__true1`, m__t)))
HFloat(287.02451456724083)*Units:-Unit('N')
(24)
Encounter problem while chaning variable
 BF:=
proc (`σ__t`, D, p, A__die, hhh, V__cup, `ρ__true`, m__tablet) options operator, arrow; breakforce(`σ__f`, D, hhh, t2(p, A__die, hhh, V__cup, `ρ__true`, m__tablet)) end proc:
BF(TS1(100*Unit('MPa')), d, por1(100*Unit('MPa')), a__die, hh, v__cup, `ρ__true1`, m__t)
BF(HFloat(3.6712504621161846)*Units:-Unit('MPa'), 7.747*Units:-Unit('mm'), HFloat(0.09859999999999991), 118.9610524*Units:-Unit(('mm')^2), 1.6764*Units:-Unit('mm'), 119.789438*Units:-Unit(('mm')^3), 1420.00*Units:-Unit(('kg')/('m')^3), 667*Units:-Unit('mg'))
(25)
evalf(TS[1](100*Unit(MPa)))
(26)
plot(breakforce(TS1(x), d, hh, t2(por1(x), a__die, hh, v__cup, `ρ__true1`, m__t)), x = Unit('MPa') .. 200*Unit('MPa'), useunits = true)
Error, (in Units:-Standard:-+) the units `1` and `1/MPa` have incompatible dimensions
plot(t2(por1(x), a__die, hh, v__cup, `ρ__true1`, m__t), x = Unit('MPa') .. 200*Unit('MPa'), useunits = true)
plot(evalf(por1(xx)), xx = 10 .. 200)
but por1 works fine on its own with units
por1(Units:-Standard:-`*`(200, Unit('MPa')))
HFloat(0.02719999999999989)
(27)
plot(evalf(por1(xx)), xx = 10 .. 200);
Unloading Units:-Standard
Fitting_worksheet.mw
I also used a lot for for loop in this worksheet, can anyone suggest another way of doing it? And I think I initiated many Array(1..3) that is of no use.  But if I do not initiate and do the following
A[1]:=a :
A[2]:=b:
A[3]:=c:
A;
output: A
Only if I initiate A:=Array(1..3) and then define the element I can see the complete A array at the end.
I am trying to write a procedure that have the following input:  expr, xdata,ydata. [dependent variables list]
I want a procedure to calculate Rsquare following the method described in
http://www.mapleprimes.com/questions/120014-How-To-Calculate-Coefficient-Of-Determination
But I want the proc to take any abitary function and be able to identify the  dependent variable...how can I approach it? what function can I use to match [dependent variable list] in expr??
Is it possible to set maple to fill in a header or footer for every new document I make?
Now i have to do it fot each new file by hand:
View => Header footer ..=>
 - select custom  - goto tab cusom headers put in the left textfield "&[File] pag. &[Page]/&[Pages]"
I want to calculate a range.
eg. j=1...n-1 will use this equation
P(j,n):={((m/(2-1))(m/(2))^(j-1))/(2(m/(2))^(n)-1))}
j=n will use other equation.
How to create the command? I keep receive errors.
Lina
what is the best maple book? could every one introduce books which have studied about maple !?? which is the best due to everyones opinion ? tnx for answering.
I'm getting an error when I try to
plot(sin(x), x = -1..1, color = darkblue,tickmarks=[spacing(0.25),subticks=2]);
The error is
Error, (in plot) expecting option tickmarks to be of type list({"default", "piticks", "decimalticks", "pidefault", nonnegint, list(realcons), list(realcons = anything), spacing(realcons), spacing(realcons, realcons)}) but received [spacing(.25), subticks = 2]
What exactly am I doing wrong? After all, [...] is a list.
Even more confusingly, tickmarks=[[spacing(0.25),subticks=2],default] doesn't work either.
Any help appreciated!
I would like perform a symbolic integration to the following integrand with Heaviside function:
The integral I defined is as follows:
The output I got is
Could any one explain me how to avoid the undefined in the output. I tried to define the assumtions to constrain the solution. However, I failed to supress the undefined.
I expect a result of the integration should also be piecewise function.
Appreciate you constructive inputs.
restart:with(plots):
TSol:= f(x,y,Q); # The actual funtion is in the attached maple sheet because of its size.
animate( plot3d, [TSol,y=-1..1,x=0..1], Q=0..2,contours=65,style=patchnogrid, grid=[80,80], orientation=[-360,-180], lightmodel=light4, shading=zhue, transparency=0.3,style=contour);
plot3d(subs(Q=2,TSol),y=-1..1,x=0..1,contours=65,style=patchnogrid, grid=[80,80], orientation=[-360,-180], lightmodel=light4, shading=zhue, transparency=0.3,style=contour);
For Q = 2, why there is a big difference between these two ouputs?
 3d_anim_try.mw (If the maple sheet is not accessible then let me know, I will copy past the function (f(x,y,Q))?)
I have a question regarding maple reader.
It seems like in maple reader, one cannot interact with the output of the Explore function.... which mean I am forced to make my own component if I want to creat application for my co-worker to use..this is some what annoying.  Is there another way around?
please open the attached file in maple player and you will see the output created by Explore gives error message.  mapleplayer_test.mw
Download mapleplayer_test.mw
I have a problem solving with ODE's system solving. I have 2 equation and 4 initial  conditions. When i calculate like that,u can look this file.  beamsolvingfortim.mw. It is working it is giving me T1 and T2 equations depends on time.
 In 2. system which i have a problem i want to calculate this equations depends on x(displacement). I have again 2 equation and 4 boundry conditions. it is solving the ODE'S system without boundry conditions. (It is giving with C1 C2 C3 and I)Problem is when i want to find its values with boundry conditions it is not giving a result. Is there a problem with complex number(I) or boundry conditions are not enough?
> evalf(dsolve({sys}));
{X1s(x) = -3.060206320 + _C1 exp(-0.3487988669 x)
+ _C2 exp(0.3487988669 x) + _C3 exp(-0.3563227426 I x), X2s(x) =
-0.6321326989 _C1 exp(-0.3487988669 x)
+ 0.6321326989 _C2 exp(0.3487988669 x)
- 0.6053448484 I _C3 exp(-0.3563227426 I x)}
When i write like that, nothing is happening. I also upload the files. If u can help , i would be really appreciate.
eq2 := dsolve({A, B, bc}, [X1s(x), X2s(x)])
beamsolving(thick.mw
Hello everybody,
I want to use the physics package in the context of special relativity.  I am mostly interrested with the Lorenzts transformations, not having to unprotect gamma all the time, the 4-vectors for space, time and momentum in (ct,x,y).  For exemple, to be able to calculate the invariant (ct)^2-(r^2).  A small document (or worksheet) would be very nice of you.
I understande that someone could say that I want to use a gun to kill a fly.  But this is a process that will lead me in using it in general relativity and using tensors in my calculations.  It would be very interresting to have a Student,Physics package.  Don't you think so?
Thank you in advance for your trouble and comprehension.
Mario Lemelin
Maple 18 Ubuntu 13.10 - 64 bits
Maple 18 Win 7 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
First 1489 1490 1491 1492 1493 1494 1495 Last Page 1491 of 2471
