Hello, with "logplot", if I use "scale" or change the minimum vertical range to some smaller values, the plot mechanism will automatically print "0., 0.5*0.0001, 0.0001, 0.5*0.001, 0.001, .... " at the y-axis numeric mark.
However, I want the 10^(-n) numeric format and alwasy keep the format.
How could I always get the 10^(-n) numeric format for y-axis ?
Thanks a lot!
a long equation has many Ei
how to convert into Gamma function using below identity
Ei(a, z) = z^(a-1)*GAMMA(1-a, z);
Please I need to adjust this expression (Physics) help me to find at least one other solution and thank you very much, since
A while ago, I had asked a question relating to calling to an MapleSim .msim simulation within maple .mw worksheet. (Thank you Acer! :) I got it working but then another issue just popped up...The basic structure is as follows:
A := MapleSim:-LinkModel('filename' = "TriplePendulum_WORKS_v2.msim")
for z from 1 to 50 do
     initialize_variables;
How can i specify the ground field C= complex numbers and calculate a primary decomposition for an ideal defined over C? For example
with(PolynomialIdeals):
J:= <x^2 +1 >;
PrimaryDecomposition(J);
should return x+I, x-I, but instead returns x^2+1
how can i install the DirectSearch optimization package for mac version (MAPLE 15)?
Gil
Some time ago I asked a question on maple primes concerning handling the numeric solutions of dsolve procedure.
They sent me to the discussion on option remember and indeed this helped a lot.
However there is another issue.
The method I am trying to implement requires iterative calls to dsolve/numeric with one of the functions defined from the previous...
Hi everyone,
My question is as following:
Given the numeric solution to the dsolve call as a procedure, I define a function of this procedure, say
u(x(t),t), where x(t)=proc(t)..proc - output from dsolve/numeric
Is there a way to have u as a function of t only and not of procedure x(t) and t?
Thanks in advance for any help
I need a procedure to unjumble a series of 9 letters into discernable 4 to 9 letter words. each letter can only be used once and it needs to include a given letter in each word. eg IOCMRELAE, and include R in each word
Acer did a similar thing a while back, but in this case it needs to tell it to permute 9 letters, then 8,....,then 4 (each including letter R).
 >with(StringTools): with(PatternDictionary):
>bid:= Create(`builtin`):
Hi, can you please show me how to use the Hankel function on Maple please?
Here is my equation, "P2a(P),PP+Pa(P),P- Ra(P)+P2a(P)=0" i'm trying to solve for "a(P)". Subscript of P means partial differentiation.
Many thanks
Hi, this is probably very simple but I can't seem to get Maple to show me the Matrix that I want. Could you please let me know what is the problem?
N0:=s->1-s;
N1:=s->s;
N:=s->[N0(s) N1(s)];
Both `$`N(s) and N(s) shows me the statement "error, in N[0] too many levels of recursion"
Then I change to Nj:=s->[N0(s) N1(s)];
The solution comes out to be [N
HI experts,
can anyone here help mi in transform a Mathematica v8.0 sheet into maple v.15 ?
I am still maple novice.
Thanks a lot
My MMA file as ZIP:
general_two_compartm.zip
Let A(-5,-3,-3), B(0,1,-2) be two points and
(d): x = t - 3, y = 2*t, z = t+2.
Find the coordinates the point M on (d) so that the area of the triangle ABM obtain minimum value.
This is my code.
restart; with(LinearAlgebra):
A:=: B:=: M:=:
u:=A-B: v:=A-M:
T:=CrossProduct(u,v):
S:=minimize(1/2*Norm(T,2), location = 'true');
M:=subs(op(1,op(1, S[2])),M);
Let A(-2, -1, 3), B(0, 1, 4) be two point and
(d): x = -t-2, y = t+1, z = -t-1 be a line.
Find coordinates point M lies on (d) so that area of the triangle ABM equal to 3*sqrt(5).
This is my code
A:=: B:=: M:=:
u:=A-B: v:=A-M:
sol:=solve(1/2*Norm(T,2)=3*sqrt(5),{t});
for i from 1 to 2 do print('M'[i]=(subs(op(sol[i]), M[1]), subs(op(sol[i]), M[2]),subs(op(sol[i]), M[3]))) end do;
i have a function f(alpha)=1+2cos5alpha, i had no trouble plotting f(alpha), but when i try to plot f(alpha.t) i keep getting empty plot.
please help
First 1813 1814 1815 1816 1817 1818 1819 Last Page 1815 of 2471
