HI experts,
can anyone here help mi in transform a Mathematica v8.0 sheet into maple v.15 ?
I am still maple novice.
Thanks a lot
My MMA file as ZIP:
general_two_compartm.zip
Let A(-5,-3,-3), B(0,1,-2) be two points and
(d): x = t - 3, y = 2*t, z = t+2.
Find the coordinates the point M on (d) so that the area of the triangle ABM obtain minimum value.
This is my code.
restart; with(LinearAlgebra):
A:=: B:=: M:=:
u:=A-B: v:=A-M:
T:=CrossProduct(u,v):
S:=minimize(1/2*Norm(T,2), location = 'true');
M:=subs(op(1,op(1, S[2])),M);
Let A(-2, -1, 3), B(0, 1, 4) be two point and
(d): x = -t-2, y = t+1, z = -t-1 be a line.
Find coordinates point M lies on (d) so that area of the triangle ABM equal to 3*sqrt(5).
This is my code
A:=: B:=: M:=:
u:=A-B: v:=A-M:
sol:=solve(1/2*Norm(T,2)=3*sqrt(5),{t});
for i from 1 to 2 do print('M'[i]=(subs(op(sol[i]), M[1]), subs(op(sol[i]), M[2]),subs(op(sol[i]), M[3]))) end do;
i have a function f(alpha)=1+2cos5alpha, i had no trouble plotting f(alpha), but when i try to plot f(alpha.t) i keep getting empty plot.
please help
create the function f(x)=(x2,x=<0), (2x, 0<x<1), (2sin(Pi.x/2),x>=1). how do you find derivative in one command and integrate f(s)ds from -1 to 2.
I have created a MapleSim model including a few custom components. When I try to run the simulation, I receive the following error:
cannot resolve function `Main.'Typesetting:-mambiguous'`; there is no function `'Typesetting:-mambiguous'` visible in model `Main`
How do I know where the source of the error is?
Thank you,
Behzad
how do you analytically and numerically solve the IVP: y" + 4y' + 13y = cos2t, y(0)=2, y'(0)=-1.
Let A(1,0,0) be a point and two lines
d1: (x-5)/3 = (y-1)/1 = (z - 2)/2,
d2: (x-5)/1 = (y-1)/1 = (z - 3)/3
Let B and C be two point lies on d1 and d2, respectively so that the three points A, B, C
If log105 =c and log2050=d express log940 in terms of c and d ?
Hey everyone.
I have been trying to solve an ODE with BC with dsolve,numeric but always get the error below:
> Error, (in dsolve/numeric/BVPSolve) matrix is singular
My problem is not solving it (ie fine to do with LinearAlgebra package or similar), but why does this error occur? What is the problem with the ODE/BC that produces this error?
And is there a way of adjusting the ODE/BC to be able to solve it simply by using dsolve,numeric?
On my Dell Latitude E5400 laptop with up-to-date Fedora 16:
$ maple15
    |\^/|     Maple 15 (X86 64 LINUX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2011
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
>  log[2](8);
I've been trying to solve eqn1,eqn2,eqn3,eqn4 for T[water],T[air],T[Al],T[plastic] by using the defined variables listed above the set of eqn's, but everytime I get the "Warning, solutions may have been lost". Is there a solution to this or are the eqn's unsolvable?
> restart;
> h[infinity] := K[infinity]*(0.37e-1*RE[infinity]^(4/5)-871)*Pr[infinity]^3/L[plastic]:
> h[plastic] := N[plastic]*K[plastic]/L[plastic]:
> h[water...
Problem. Write the equation of the plane passing the point H(1,1,1) and cut the coordinates axes Ox, Oy, Oz at A, B, C respectively so that H is centre of the circumscribed of the trianlge ABC.
This is my code.
with(geom3d):
A:=:
B:=:
C:=:
H:=:
f:=(x,y,z)->x/a + y/b +z/c-1:
solve([f(H[1],H[2],H[3]) = 0, Norm(H - A, 2) = Norm(H - B, 2), Norm(H - A, 2) = Norm(H - C, 2)],{a,b,c}): assign(%):
Problem. Write the equation of the plane passing the point H(2, 1, 1) and cuts the coordinates Ox, oy, oz at A, B, C respectively so that H is orthocenter of the triangle.
This is my code.
with(geom3d):
A:= <a,0,0>:
B:=<0,b,0>:
C:=<0,0,c>:
H:=<2,1,1>:
eq:=solve([f(H[1],H[2],H[3]) = 0,DotProduct(B-C, A-H, conjugate = false...
Simply using display(array) we can create larger zoomed sized plots that I think some people would like but only for 2d but what about 3d plots ? - read on.
Now this expands only the width of the plot and works for all 2d plots.
a:=plot(sin(x)):
display(array([a]))  # displays plot at screen width size
What I think most people want is an easy way to adjust plot sizes from the default Maple install without having to load any special packages ...
First 1814 1815 1816 1817 1818 1819 1820 Last Page 1816 of 2471
