It's possible to define a field in Maple 15 with 2 kinds of indices, say type spacetime μ,ν,ρ... and one of the type integer, i,j,k varying from 1 to n?
I would like to define a field like Aμi where:
Aμ1=Aμ
Aμ2=Bμ
and so on.
Thank you Washington Inacio
I expected
int(x^(-13/10), x):
eval(%,x=1000)-eval(%,x=1/1000);
-(1/300)*1000^(7/10)+(10/3)*1000^(3/10)
but i get
int(x^(-13/10), x=1/1000..1000);
Write a procedure, primesum, whose input is a positive integer n and whose output is the sum of all primes p such that p is less than or equal to n. You may use th built-in procedure isprime.
Bonjour
Je n'arrive pas à faire fonctionner un montage simple.
J'ai un message d'erreur : (in dsolve/numeric/RunSimulation) unable to compile, please check your options by running with infolevel [ToExternal]:=1; simulation failed.
Que dois-je faire ?
Windows 7  64bits / Maple 61bits
Merci
Greetings,
I have purchased Maple 15 Student Edition 2 months ago. My problem is that when I click the button under the text "To obtain a complete annotated solution, click:" Maple crashes. This happens in the browse tasks window accessed through Tools>Tasks>Browse. In addition to this issue, the interactive commands does not seem to work. How can resolve these issues? I am running a 64-bit version of Maple 15 under Windows 7 Home Premium 64-bit.
Any help is appreciated.
MAPLE is not able to show me the output of nested loop. How can I get it?
for i from 0 to N do for j to 3 do
eqn[i] := sort(coeff(lhs(dequn[j]), epsilon, i)) = coeff(rhs(dequn[j]), epsilon, i)
end do
nested_loops.mwend do
What is the difference between them?
daesys0:={diff(I3(t),t) = 1/L*u(t), I1(t) = I3(t) + 1/R * u(t), I3(0)=0, I1(0)=0};
daesys0:={diff(I3(t),t) = 1/L*u(t), I1(t) = I3(t) + 1/R * u(t), I3(0)=0};
If I use the procedure for numerical solution, their solutions are similar.
Suppose I have a system of three coupled equations as:
eqn[1] := a*x+b*x^2+c*x^3
eqn[2] := a1*x+b*x^3
eqn[3] := a2*x^2+b2*x^3 = a*x^2
If I simply write
eqs :=( eqn[1], eqn[2], eqn[3])
the equations get coupled.
1. Can I do it using loop structure?
2. Secondly, after coupling suppose I want to collect coefficoent of x, x^2 and x^3 from three equations ang get the equation in form
eq[0]:=a=0,a1=0
evalhf: more than 500 locals
From where that restriction is? Is it workaroundable?
I was wondering if anyone knew of a solution to this: when you plot multiple curves on the same axis with Maple and specify the colors=["blue","red",.....] etc, the ordering is not preserved, Maple seems to just match whichever color to whichever function it pleases. This is v.annoying, surely there must be a way to get around this?
I seem to recall some code that converted 2d math into an easier readable format in modified 1d ascii text?  Can anyone direct me to such a post I can't find it nor can I recall how it was done?
I am not referring to lprint.
For example g^2/5*a should be shown as
  g
 5 * a
It's a pain to have to type it out by hand.
I am confused by the below results.
Why does LSSolve (given an arbitrary expected return) produce a higher risk
adjusted return than QPSolve which explicity is given an objective to maximize
risk adjusted returns? ie minimize Transpose(W).Cov.W-Transpose(W).ev
This to me seems very strange?!
Also, how do you specify in the objective function for LSSolve to maximize
risk adjusted returns? Now we have simply provide LSSolve with some user specified
Please help me  write a code for the following problem:
Write the equation of the plane which passes through the points A(-1, 3, -6) and B(2, 2, -10) and tangent to the sphere
(x-1)^2 + (y + 1)^2 + (z - 7)^2 = 9.
Thank you very much.
I want to get the zeroth order and first order perturbation equations of the following nonlinear coupled ODE.
restart; N := 1
alias(eta = e, theta = t)
eq[1] := 5*(diff(F(e), `$`(e, 3)))+(1+3/m)*F(e)*(diff(F(e), `$`(e, 2)))-(2+1/m)*(diff(F(e), e))^2-(4+2/m)*H(e)-(1-2/m)*e*(diff(H(e), e)) = 0
eq[2] := diff(H(e), e) = t(e)
eq[3] := 5*(diff(t(e), `$`(e, 2)))/Pr+(1+3/m)*F(e)*(diff(t(e), e))-5*(diff(F(e), e))*t(e)
eqs := eq[1], eq[2], eq[3]
Dear Forum,
I have a rational transfer function, like
Y(s)/X(s)=G(s)=(s^2+s+1)/(s^3-3*s^2+5)
With the DynamicSystems package, Maple can compute a state space representation, but I want a single DEQ in y(t) of 3rd order. What is the best way to let Maple compute this?
First 1818 1819 1820 1821 1822 1823 1824 Last Page 1820 of 2471
