Maple 14:
1, i can't "tab" anymore.
my tab key is turned on(otherwise when i press tab, the curser goes to the next "section"), when i press tab, the curser simply moves over a tab but the words don't! and sometimes when i press tab, nothing happens, and often times, things start to get really buggy and weird.
2, i have to "enter" my module twice before it will work...here is what happens:...
Hi everybody,
I have these two (three) animations (a single animation and a array with two other animations) and I would like to plot the three animations such that when I click on the play button of one of them, all the three animations starts at the same time.. I don't know how to get this, please help me if you can!
This is the code of my animations that I'd want to run at the same time:
The first:
display([mech||(2..nstep+2)],insequence=true,gridlines=true,title="Mechanism...
s:= int((1/4)*sqrt(2)*exp(-(1/2)*(x+k*sin(-theta+phi))^2/sigma^2)*(1/(2*Pi)+Q*cos(k*phi))/(Pi^(3/2)*sigma), phi = -Pi .. Pi);
how to use reduce command to get prime ideal?
i find PrimeDecomposition and PrimaryDecomposition in package with(polynomialideal):
is the primedecomposition for prime ideal?
This is related to my previous question regarding int versus Int.
In the process of trying to answer my own question I tried the following:
> q := exp(-x1*log(x1)-x2*log(x2));
                         exp(-x1 ln(x1) - x2 ln(x2))
> evalf(subs(r = 1, int(int(Dirac(x1+x2-r)*q, x1 = 0 .. 1), x2 = 0 .. 1)));
0.
> evalf(subs(r = 1, int(simplify(int(Dirac(x1+x2-r)*q, x1 = 0 .. 1)), x2 = 0 .. 1)));
Can anyone explain why I get a different answer if I use int instead of Int in the following evaluation:
> evalf(subs(r = 1, Int(Int(Dirac(x1+x2-r)*q, x1 = 0 .. 1), x2 = 0 .. 1)));
1.676209155
0.
hi, i have a function in seri's with one unknown parameter and i want to solve it for this boundary condition : f(infinity)=1
I use pade approximation but in my case it doesnt work. i want to know is there exist other  method in maple for this problem. for example other rational function.
thx
for simple case 2*2,  A = matrix([[0,-1],[1,0]]);
using A, i understand f(x,y) = f(-y,x)
where do other case f(-x,-y) and f(y,-x) come from?
any command to list all cases with input a matrix A?
if A has more dimensions, what will the cases be ?
Hi , how do I get the binomial expansion of  1/sqrt(9+4*x^2) .  I am using expand(expression,binomial) . But Maple just
returns the expression.  Thanks .
how to x1, x2 ... with xi in procedure?
b := 1;
for i = 1 to 3 do
     b := b*1/(1-xi);
od;
but xi can not represent x1, x2, x3, which commands can present x1 x2 x3 ?
restart; with(Statistics)
#Define:
A := RandomVariable(Geometric(p))+1; F := Mean(A);M := abs(A-F)/A;
#and ask Maple to find a pdf of the r.v. M:
f := `assuming`([PDF(M, x)], [x > 0])
#Maple 15 gives an answer, but what does it mean by the output for this input
subs(p = 1/3, x = 3, f)
#or how do I plot this pdf of M? Does Maple give a correct answer?
# Why does the error message appear when I do subs(p = 1/3, x < 3, f...
which package containing command to find prime ideal and quotient of ideal?
How to assign value to matrix in procedure?
with(ArrayTools):
kontraHom := proc(M, s)
dim := Size(M);
n := dim[1];
m := dim[2];
R := [][];
for i from 1 to m do
    for j from 1 to s do
        for k from 1 to n do
            R[(j-1)*n+k,(j-1)*m+i] = M[i,k];
        od;
    od;
od;
c := y^2+2*y*x+x^2-y^2*x-y*x^2
solve(c);
{x = -y, y = y}, {x = y/(-1+y), y = y}
above polynomial find roots using solve
if do reverse to find back its polynomial c from {x = -y, y = y}, {x = y/(-1+y), y = y}
any command to do this? is it possible to do this? which book teach this?
First 1867 1868 1869 1870 1871 1872 1873 Last Page 1869 of 2464
