I am trying to solve a system of PDEs numerically and having following error
Error, (in pdsolve/numeric/plot3d) unable to compute solution for t>HFloat(0.0):
solution becomes undefined, problem may be ill posed or method may be ill suited to solution
Please have a look at attached worksheet and help me out.
Moreover, I want to include boundary conditions are not normal to the boundary. Anyone knows how to do so? Any help would be appreciated.
Is it possible in Maple to choose the dimensions for a plot? I mean to choose the height and the width of the plot?
For example, to enlarge the plot to the whole width of the maple page? Is it possible?
I need to do this because I have to plot together objects of different dimensions
 and so the smaller ones look too small, so I would like to enlarge the plot to solve the problem.
Sorry for may be stupid question, but please see the following example:
a := proc() A end:
a();
                               A
a[b]();
if i restrict value in matrix to 0,1  or 0,1,2 of dimension 2*2 or 3*3
how to show all combination of matrix ?
I use rk4 to solve this equation with the paramater w = 500, I want to get the numbers of steps.
And when I change the parameter w = 1000, I want to obtain the numbers ofsteps?
Here is the procedure:
Digits:= 32;
w :=  500;
ode := diff(y(t), `$`(t, 1)) = 2*I*y(t) + sin(w*t)*y(t)*y(t):
ics := y(0) = 1:
p2 := dsolve({ics, ode}, numeric, method = classical[rk4]):
Thanks for your help.
is there any way to solve this integration?
int((1/200*(x-r))*r*(1+(a+(1/400)*(1+a^2)^(3/2)*r^2)^2)^(3/2),r=0..x)
how to implement the unwrap function from Matlab?
Description
Q = unwrap(P) corrects the radian phase angles in a vector P by adding multiples of when absolute jumps between consecutive elements of P are greater than or equal to the default jump tolerance of radians. If P is a matrix, unwrap operates columnwise. If P is a multidimensional array, unwrap operates on the first nonsingleton dimension.
Gracias
One thing I think is a bit strange is the notion that the loop counter
is assigned a value after the loop is done. Why is that ?
for example:
for i to 10 do
print(i)
The above code will simply print 1..10 but then if you simply run:
i;
then 11 will be printed out. How often do you actually need i to be assigned
a value after the loop is done?
I think it would have been much better if i is unassigned when the loop is done
I have a computer of CPU Core i7. I want to use all power of CPU during implementing MAPLE software. But when I execute MAPLE, only a part of power of CPU is used. I can check it by "Windows task manager". "CPU Usage" of this is so less than 100%.
How I can apply all cores of CPU in analyses by MAPLE?
I have an expression as the following:
exp2:= A*y(r)*diff(t(r),r)^2+B*t(r)/r+C*t(r)*y(r)+D*y(r)*t(r)^3+E*diff(y(r),r,r)*diff(t(r),r)+F*diff(y(r),r)*t(r)^2/r^2;
I want to extract coefficients of some functions (or relations) which is existence in expr2 by MAPLE. Please make an attention to following examples:
The coefficients of "diff(t(r),r)^2" is "A*y(r)".
The coefficients of "t(r)^2" is "F*diff(y(r),r)/r^2".
The coefficients of "y(r...
exp1:=E(z)*(diff(t(r), r))/(1-nu(z)^2)+E(z)*nu(z)*t(r)/((1-nu(z)^2)*r)+(E(z)*z/(1-nu(z)^2)-(4/3)*E(z)*z^3/(h^2*(1-nu(z)^2)))*(diff(y(r), r))+(E(z)*nu(z)*z/(1-nu(z)^2)-(4/3)*E(z)*nu(z)*z^3/(h^2*(1-nu(z)^2)))*y(r)/r-(4/3)*E(z)*z^3*(diff(p(r), r, r))/(h^2*(1-nu(z)^2))-(4/3)*E(z)*nu(z)*z^3*(diff(p(r), r))/(h^2*(1-nu(z)^2)*r);
I want to replace the following parameter instead of coefficients of t(r), y(r), p(r) and their derivatives as the following:...
I'm trying to substitute a list of equations into an expression as so:
V:=ReSeq([seq(seq(u(t)^r*v(t)^s=y(r,s),r=0..w+e+1),s=0..w+e+1)]); # where ReSeq reverses the order of the sequence
for i from 1 to nops(V)-1 do
N[i]:=algsubs(V[i],N[i-1]);
where N[0] is a polynomial in u(t) and v(t). But it keeps giving y(1,0)*y(2,0) instead of y(3,0).
what are the command of characteristic set and basic set of polynomial in maple?
google can not find, do the commands exists?
I have two system of differential equations, the first one is implicit differential equations and the second one is BVP problem.
Maple can't give answers for both of them.
Can you help me ,Numerical approach is very appreciated.
thank you in advance.
unsolved_problems.mw
First 1870 1871 1872 1873 1874 1875 1876 Last Page 1872 of 2464
