Hi there,
1) I have imported my excel file using Tools>assistant>import data.
2) My excel file contains close to 35 columns.
3) Now, within Maple, I want to plot say Column B (Time) against Column C (Temperature) of the imported excel file.
4) Also, in addition, once I can plot two columns against each other, How can I include other columns in the same plot.
Any nudge in the positive direction will be appreciated.
I use gnuplot to generate graphs in C++.Now we all know that in C++,we  just pass a text file to gnuplot,tell it to plot the text file.
Now,in Maple I want to do the similar thing,like this:
Suppose I have some single variable function/procedure,say of x
then I can write a loop say,
for 0 to 100 by 0.01 do
x,f(x)
od;
With this I can see the output.Now if I want the plot of f(x) vs x,then how can I say it to Maple?
I have a system of three differential equations with three unknowns, say f(t), g(t) and h(t).
My problem is that the system involves also f(invh(g(t))), g(invh(g(t))) and f(invg(h(t))), where invh is the inverse of h and invg is the inverse of g.
How can I instruct Maple to deal with these inverse functions?
I came across this problem while helping another user find the maxima of an expression for
various values of a parameter here:
http://www.mapleprimes.com/questions/124104-Maximum-Points--Of-Function-With-More
For various values of ga, it was required to find the maxima in a range of 0<delta<2.
Plots of the expression indicate that one such maxima exists for each value of the parameter.
My approach was to find the zeros of the first...
The Units package includes various units that are called ton/metric ton/tonne/short tons but not long tons (LT). A long ton is equal to 2240 pounds of weight and is part of the imperial system, so it is also know as the "imperial ton" or the "weight ton".
This unit (the long ton) is used extensively in naval architecture and ocean engineering. I would hope that you consider adding it into the next update of the Units package.
Or perhaps, it would...
I am using Windows 64 bit Maple 14.
I am trying to read a package (stochastic9) stored in a text file, stochastic9.txt in the directory:
C:\Program Files\Maple 14
I can't read this or ANY file from ANY directory. Nor can I save ANY object to ANY directory. Here are some sample entries and error messages:
> currentdir();
"C:\Program Files\Maple 14"...
I really need a result to the integration below but Maple 13 just won't return one. Could you please help me or advise me as to what might be wrong or what I might try ? I'm integrating on the real line in x but even when I alter the limits of integration maple just returns the integrand.
s1:= int((1/8)*sqrt(2)*exp((1/2)*k^2*cos(x)^2/sigma^2)*exp(-(1/2)*k^2/sigma^2...
I have a system equations like { a + b = 1, c = a + b +1, d = a + c}
and the sovle function which give me then answer like { a = -2+d, b = -d+3, c = 2, d = d}
I just care about the information in form (name = numeric) like { c = 2 }
and i want the "core" equations which give me that information like { a +b = 1, c = a +b +1 } => {c = 2}
how i can i get the "core" equations of that.
The integrals are
v1:=int((1/(2*Pi) + Q* cos(k*phi))^2/ (1+ beta^2*((1/(2*Pi)) + Q* cos(k*phi) )^2),phi=-Pi..Pi);
v2:=int((1/(2*Pi) + Q* cos(k*phi))^2*cos(k*phi)/ (1+ beta^2*((1/(2*Pi)) + Q* cos(k*phi) )^2),phi=-Pi..Pi);
v3:=int((1/(2*Pi) + Q* cos(k*phi))^3*cos(k*phi)/ ((1+ beta^2*((1/(2*Pi)) + Q* cos(k*phi) )^2))^2,phi=-Pi..Pi);
v4 := int(exp((-1/2)*((psi-theta-k*sin(theta-phi))/sigma)^2),phi = - Pi ..Pi);
setupdiagramMQ.
I am having a strange experience with the arrow command.   In the attached worksheet, one can see that plot structures h, i & j and l, m & n are both doing the essentially the same thing:   A vertical line is to be drawn and arrows pointing up and down from the two endpoints are to be added.  The arrows are all of the...
As title
I need help in finding the maximum point of each curve (please see maple file link attached), or if possible display each maximum point (under different "ga") on the 3Dplot
Your help is appreciated
Correction.mw
Hello, I'm new to Maple.
when I write:
solve({Wa=Ve,-4*Vd+4*Ve=-4*Wa+4*Wb,12*Vc-24*Vd+12*Ve=12*Wa-24*Wb+12*Wc},{Wc});
Maple gives me no output.
Can somebody help me, what I'm doing wrong? (Maple 9.5)
Thank you for your help!
Hi colleagues. I executed a problem on Maple 12 and the results were on a matrix form as:
A=[11X11 Matrix]
How can i display the full content of the matrix and how can i extract one row or one column from the matrix???
First 1874 1875 1876 1877 1878 1879 1880 Last Page 1876 of 2464
