even if I use a simple x^2+y^2 plot I get these funny gaps at the botom of the plot. I have looked through the FAQ files and can't seem to find a solution to it... is there one ?? from what I have seen so far there does not seem to be an easy solution. with a graph like the type above to change to coords=spherical or cylindrical does not show the same graph due to that change.
I tried to implement an small example sheet for using the RSA algorithmen with small numbers. Unfortunatly, I get confused by my own program and have difficulties to figure out what I am doing wrong. My message can be decoded with both keys, the public and private key what is obviously not correct.
below is my code with some comments:
restart: with (numtheory):
p := 13; # my first prime number
q := 23; # my second one
n := p*q;
I am of interest about using StateSpace(de, invars
How can I plot, say, y1=x+4, 0<x<5 and y2=2x+1, 0<x<10 on the same plot area?
Thank you,
Ozgur
I want to construct a sequence of diffenrential equations with
seq(diff(f[i],x)=k[i]*f[i],i=1..4);
but I get
0 = k[1]*f[1], 0 = k[2]*f[2], 0 = k[3]*f[3], 0 = k[4]*f[4]
Is there anyone can tell me what I have done wrong? Thanks a ton!!
This is my situation, please help me.
Cargando  MathematicalFunctions
Cargando  PDEtools
> with(DEtools);
> restart; m[1] := 1; m[2] := 1; l[1] := 1; l[2] := 1; g := 9.8; w := 1; ec1 := (((1/3)*m[1]+m[2]+w)*l[1]^2+((1/3)*m[2]+w)*l[2]^2+(2*((1/2)*m[2]+w))*l[1]*l[2]*cos(beta(t)))*(diff(alpha(t), t, t))+(((1/3)*m[2]+w)*l[2]^2+((1/2)*m[2]+w)*cos(beta(t)))*(diff(beta(t), t, t))-(2*((1/2)*m[2]+w))*l[1]*l[2]*sin(beta(t))*(diff(alpha(t), t))*(diff(beta(t), t))-((1/2)*m[2...
How to load Maple-NAG connector to execut this example ?
Is it an additional program to install ?
n := 4:
nnz := 11:
la := 22:
lfill := 1:
dtol := 0:
pstrat := "Nag_SparseNsym_CompletePiv":
milu := "Nag_SparseNsym_UnModFact":
a := Vector[row](la,[1.0,1.0,-1.0,2.0,2.0,3.0,-2.0,1.0,-2.0,1.0,1.0],datatype=float[8]):
irow := Vector[row](22,[1,1,2,2,2,3,3,4,4,4,4],datatype=integer[kernelopts('wordsize')/8]):
icol := Vector[row...
I was wondering if someone could assist me with the code for listcontplot.
I've tried the following:
M:=Student[LinearAlgebra]:-RandomMatrix(4,4);
listcontplot(M);
But this does not work.  Is there any way to use listcontplot, listcontplot3d, or any other command to generate something similar to what Excel calls a Surface - contourplot?
I see how to get the solutions of the Schroginger eqn
I have the function r=sqrt(1+(cos(2*theta)) and theta E [0,pi/2] I need to find the arc length of this function using maple 14
so far i have this
with vector (calculus):
ArcLength(sqrt(1+cos(2*theta)), theta=0..pi/2)
I dont know what to do after this
"I" is reserved for square root of -1.  I don't use complex numbers and want to use "I" in my equations.  How do I go about doing this?  I tried to unprotect it with a number of variations of quoting "I".
I'm using document mode with Maple 13 on Apple.
Thanks for your help.
My question is how do i get Maple to simplify every calculation that involves units automatically, right now i have to do this manually for every single one.
For example: This values all come from variables wich have units assigned to them.
Then i hit right click, Units -> Simplify and i get this:
I am using dsolve(..., type = series) to solve differential equations in the form of a power series. I plot these power series with different orders to observe how they converge. I use quite large orders (25 or even 50), and generating these solutions is slow.
I would like to generate power series with order 25, for example, and then truncate it to order 24 directly, instead of having to call dsolve a second time. I was hoping this could be done somehow using convert...
Hi All! I need your help.
I use the Student:-LinearAlgebra:-LynearSystemPlotTutor() and i can print it with:
print(Student:-LinearAlgebra:-LinearSystemPlotTutor);
then i got the:
module ()
local ModuleApply, LinearSystemPlotMaplet, PlotOptionsWrapper, UpdateDisplay, NewMatrix, the_plot, sysML, helpStr, linSysMaplet, M, axisLengthInfo, axisLabelInfo, axisType, axisScaling, plotOptionsReturn;
end module
If i would print the local...
If you type 1/1e6; then you get 0.000001000000000.
If you type 1/1e7; you will get
First 1908 1909 1910 1911 1912 1913 1914 Last Page 1910 of 2460
