I'm using Maple for a math project.  FYI, this is my first time ever using Maple, so I'm a complete newbie.  I'm lucky I even got as far as I did, because had I not stumbled upon the ? function, I'd still be stuck trying to figure out step 1.  Anyways, I entered this into a Maple document:
with(combinat, setpartition) :
P := {1, 2, 3, 4, 5, 6, 7, 8, 9, 10} :
setpartition(P, 1);
setpartition(P, 2);
setpartition(P, 3);
setpartition(P, 4);
I can't find a solution on the internet for this question.
I want to rotate a curve around the x-axis. That means a 3D plot.
Does anyone know how?
I worked a problem in my textbook using maple.I define two differential equations sys1:=[dy/dt=...,dx/dt=...] and its linearize point lin_point:=[...],then using linearize command,I obtained a state space description of the system.Now,I want to using state space description to get transfer function of the system,how can I do it directly without retype the state matrices a,b,c,and d manually?
My computer has 6 GB RAM and works with Windows Seven 7 (64 bits). When I am running my MAPLE program(Version 12), the MAPLE software needs the large amount of memory. But when the consumed memory exceeds over 2 GB, the CPU and computation  stop. Even if I used the Command {kernelopts(datalimit)}, the software did not allow me to use the memory more than 2097100 KB.
Okay I don't know why, but at some point my document went crazy somehow, so I closed it and when I opened it again it was like this ... the whole document, all what I had made, it was in one single line... =/
Just like this:
http://img827.imageshack.us/f/bugallmathinonelinewtf.png/
Can anyone help? Please... if I copy paste it to like word, I get it all shown, so it IS there..
I am trying to get the output listed into a vector or list, but I am unsuccessful. I get the error code "improper sequence". but the expression works:
N:=24
while N>1 do if evalb(type(N,even)=true) then N:=N/2;print(N);else N:=3*N+1;print(N);end if;end do;
The output generated is:
12
6
10
5
16
8
4
I would like to have the output as a list or a vector with two numbers,...
I would like to create a 3D plot using plot3d, however the function I'd like to plot is only defined on the integers and the arguments to plot3D define a range of real numbers.
I woul d appreciate any ideas on how to create this plot.
David
I am trying to solve this set of equations ,but i have spent a lot of time rewriting the equations and changing the signs..but i cant get rid of this erroe and solve it for the unknowns.....could anyone tell me what am i doing wrong ?
I made a model in MapleSim, and I want to analysis it in Maple.
But there was an error when I used the 'get equations' buttom.
and my piecewise equation is
Is there any problem to this equation?
I really didn't know how to solve it.
I'm trying to use maple to caluclate the product of eight 4x4 matrices. I need to find all the different permutations of these matrices so that means that there are 8!=40320 in total (I am multiplying all the matrices together but in all thier different orders). I can write a simple program with loops to find the products of say three of the matrices but when I try to create a program that calculates the full product of all eight then maple stuggles ...
I have Windows 7 on my laptop.  When I put the Maple disk into my DVD drive, it says the disk is blank.  I took it back to my school and it works fine on their computer.  Any suggestions?
I have downloaded the lead acid battery model from the link http://www.maplesoft.com/applications/view.aspx?SID=34125. I have made the whole system as a subsystem block and tried to generate a simulink sfunction block, but I was not successful. I am getting the below error while doing so.
 Error in Component Button43 with caption "Generate to Simulink":
(in MapleSim:-GetInitialConditions:-GetInitialConditions...
I have a problem understanding how the below reasoning works
for Bruss article “Sum the Odds to One and Stop,”
i) I would like to understand the die problem and more specificaly
why the probability is k(1/6)^1*(5/6)^(k-1). I have a hard time understanding this
ii) How can I apply this reasonong to a coin toss example?
I have managed...
Hi everybody:
I have the following problem. I obtained an asymptotic solution of a hard problem. The final result is a Maple procedure with five arguments; this function has hundred of term and it works beatifully in Maple. However, we need to convert this solution to C or Fortran code and  I am not able to do it.
After the sentence: Fortan(functionname, optimize, output="filename")
I get the following answer
Error, (in PrintTarget) assigning...
I have a worksheet for my students which implements a number of formulas for vector-valued functions such as unit tangent vector and curvature.  All in terms of parameter t.
Then in some cases we want to evaluate them for a specific value of t.  It works to say t:=2 and then recalculate the expressions.  But after this, what if I want to set t back to no value i.e. make it a variable again?  I have a solution:  delete the line that set...
First 1992 1993 1994 1995 1996 1997 1998 Last Page 1994 of 2470
