I am currently conducting some research using Maple and was wondering if anyone knows whether it is possible to get Maple to identify the non-differentiable points of a function? Also, if I convert a function so that it is piecewise defined how can I extract the separate pieces of the function to work with them individually? Many thanks.
Having a little trouble parsing the data
with(StringTools):
a:= HTTP[Get]("http://www.swpc.noaa.gov/ftpdir/indices/DSD.txt")[2]:
b:=Split(a,"\n"):
results:=b[14..]:
results[1]
                   "2010 06 29   74     24      110      1    -999  ...
This is what what i would write in Vb. how do I write something similar in maple?
For j = 15 To 27 Step 3
                For k from 1 To 3
                    Select Case k
                    Case 1
hola
I need define a same equation with different parametric settings
gracias
I want to find the optimum of
G*(.7500000000*B*sqrt((1.-2.*a+a^2)*B^2/(a^2+B^2-2.*B^2*a+B^2*a^2))-.7500000000*B*sqrt((1.-2.*a+a^2)*B^2/(a^2+B^2-2.*B^2*a+B^2*a^2))*a+.7500000000*a*sqrt(a^2/(a^2+B^2-2.*B^2*a+B^2*a^2)))
(1-G)*(-6.250000000*10^(-12)*sqrt(a^2/(a^2+B^2-2.*B^2*a+B^2*a^2))*(5.833333333*10^9*B*sqrt((1.-2.*a+a^2)*B^2/(a^2+B^2-2.*B^2*a+B^2*a^2))-7.500000000*10^9)*(4.*a-3.*B*sqrt((1.-2.*a+a^2)*B^2/(a^2+B^2-2.*B^2*a+B^2*a^2))+3.*B*sqrt((1.-2.*a+a^2...
I am performing reliability analysis.  I have two types of data:
1.  Suspended data (data that has not failed)
2.  Failed data
I require to calcaulte how many ways the data can fail for example:
1. F1   Time = 10
2. S1  Time = 100
3. F2  Time = 200
4. S2  Time = 250
The number of combinations for this data is 3:
F1, S1, F2, S2
F1, F2, S1, S2
F1, F2, S2, S1
Hello all,
I'm working through an optimization problem, and I'm running into a problem adding constraints on the variables I am trying to optimize. I'll attempt to ask the question in a general sense, but if it's not clear, I'll be more specific.
I have a procedure called EIG that calculates the sum of the squared residuals of a model compared to experimental data by inputting 6 variables. I'm trying to minimize this function by using the Optimization...
If you work with Maple on a daily basis sometimes you come across
things that seem impossible to do. Yesterday I tried to have two colors
in a histogram ie -3..-1 = red and -1..3 =blue but I could not figure
out how to do it...hummm.....any suggestions?
with(Statistics):
n:=5000:
A:=Sample(RandomVariable(Normal(0,1)),n):
Histogram(A,bincount=100, color=blue);
I don't quite understand about some parameters of flexible beam. Please introduce  briefly.
1. Truncation order of inertial terms
2. Truncation order of elastic coordinates
3. Number of elastic coordinates
help_for_maple_quest.docplease give a explain how to work for operations.
 I would like to select the color of the arrow for T,N and B.
Thank you for any suggestions.
Ralph Wallace
with(VectorCalculus):with(plots):
Display the tangent, principal normal and binormal vectors on a curve.
c:=sqrt(a^2+b^2);
Hello all,
I have a little problem with an expression I have to develop in taylor/series.
Here it is:
sinh(sqrt(omega/nu+m^2)*h)
I want to develop it in "nu", giving that "nu" is a small parameter, and it says that it doesn't exist a series expansion.
But when I can obtain the series expansion of the "sqrt" part only of the expression, which yields:
E.g. I want to modify the Binomial distribution in a way, that k is not the number of successes, but the outcome.
Let's assume each success wins $100, while a failure results in $0.
My thought was to substitute k for k/100, but that produces an error message.
Can anyone tell me, how to implement that in Maple?
Thanks a lot.
i use fsolve to find appraxmaite solution. there are some parameter in my equastion wher i do loop in this pramater form 0.. 1000,000,00
i have other problem with "fsolve and digits". when Digits =12;  i cannot find  approx solution using "fsolve"
when i decrease or increase  the digit "Digits:=11 , Digits:=13",  i find the  approx solution using "fsolve".
i donot know what is wrong!!!
First 2002 2003 2004 2005 2006 2007 2008 Last Page 2004 of 2463
