Hello. I am trying to solve the following polynomial system. Maple solution is empty but when I add the polynomial X4_4-2^(1/2)/10 to the list then maple gives me a set of solutions. What could I be doing wrong?
with(SolveTools):
F:=[
10*X4_4 + Y1_1,
10*X4_4*Y1_1 + 2,
20*X4_4*Y3_1,
2*Y3_1,
10*X4_4*Y1_2,
20*X4_4*Y3_2 + 2,
10*X4_4 + 2*Y3_2,
4*L2 - 7*L1 + 5*L3 - 6*L4 + 5*L5 + 9*L6 - 6*L7 - 1,
L1 + 10*L2*X4_4,
10*L5*X4_4,
2*L4 + 20*L3*X4_4,
2*L7 + 20*L6*X4_4
V:=[X4_4, Y1_1, Y1_2, Y3_1, Y3_2, L1, L2, L3, L4, L5, L6, L7]:
Sols := PolynomialSystem(F, V);
I have a system that I want to solve it,
But I get
''too many levels of recursion''
code_solve_system_of_equations.mw
Thank you for your help
Since strings are not mutable objects in Maple, the package provides two procedures, StringTools:-OldStringBuffer and StringTools:-StringBuffer, which appear heavily correlated with Java's  and .
The help page of StringBuffer claims that use of a is much more efficient than the naive approach:
`G` and `F` are taken from the link above.
G := proc()
   description "extremely inefficient string concatenator";
   local   r;
   r := proc()
       if nargs = 0 then
       elif nargs = 1 then
           args[ 1 ]
           cat( args[ 1 ], procname( args[ 2 .. -1 ] ) )
       end if
   r( args )
# # This can be transformed into an O(1) algorithm by passing a string buffer to the recursive calls.
F := proc()
   description "efficient version of G";
   local    b, r;
   b := StringTools:-StringBuffer();
   r := proc()
       if nargs = 1 then
           b:-append( args[ 1 ] )
           b:-append( args[ 1 ] );
       end if
   r( args ):-value()
s := 'StringTools:-Random(10, print)' $ 1e4:
NULL;
time(G(s));
                             5.375
time(F(s));
                             1.125
But why not use the built-in cat directly?
time(cat(s));
                               0.
time(StringTools:-Join([s], ""));
                               0.
Clearly, this is even more efficient
Here is the last example in that link.
FilterFile := proc( fname::string, filter )
   local   b, line;
   do
       line := readline( fname );
       if line = 0 then break end if;
       b:-append( filter( line ) )
   b:-value()
end proc: # verbatim
filename__0 := FileTools:-JoinPath(["example", "odyssey.txt"], 'base' = 'datadir'):
filename__1 := URL:-Download("https://gutenberg.org/ebooks\
/2600.txt.utf-8", "War-and-Peace.txt"):
fclose(filename__0):
    time[real]((rawRes0 := FilterFile(filename__0, StringTools:-Unique)));
                             0.223
fclose(filename__1):
    time[real]((rawRes1 := FilterFile(filename__1, StringTools:-Unique)));
                             1.097
Nevertheless,
close(filename__0):
use StringTools, FileTools:-Text in
	time[real]((newRes0 := String(Support~(fscanf(filename__0, Repeat("%[^\n]%*c", CountLines(filename__0))))[])))
end;
                             0.118
close(filename__1):
	time[real]((newRes1 := String(Support~(fscanf(filename__1, Repeat("%[^\n]%*c", CountLines(filename__1))))[])))
end;
                             0.580
evalb(newRes0 = rawRes0 and newRes1 = rawRes1);
As you can see, these experiments just tell an opposite story. Isn't the so-called "StringBuffer" obsolete today
Digits:=30;
h0:=0.156;
d:=0.32*h0;
l:=1;
h1:=h0-d;
h2:=h0+d;
h3:=0.5*h0;
g:=9.8;
d1:=1;
Term:=5;
Num:=150:
n:=1:
l1:=l/n;
p:=2;
for N from 1 to Num do
lambda:=2*n*Pi/l:## N1 wei sha ba tiao shu
k0:=evalf(0.5*Pi+2*(N-1)*Pi/(Num-1)):
tau0:=evalf(k0*h0):
omega:=evalf((g*k0*tanh(k0*h0))^(1/2)):
E:=g/(omega)^2:
k1:=abs(fsolve(omega^2=g*k*tanh(k*h1),k)):
tau1:=evalf(k1*h1):
k2:=abs(fsolve(omega^2=g*k*tanh(k*h2),k)):
tau2:=evalf(k2*h2):
k3:=abs(fsolve(omega^2=g*k*tanh(k*h3),k)):
tau3:=evalf(k3*h3):
F:=tau->tanh(tau1)+tau*add((eval(diff(tanh(tau),tau$s),tau=tau1))/s!*(tau-tau1)^(s-1),s=1..10);##F1(K)
T:=tau->tanh(tau2)+tau*add((eval(diff(tanh(tau),tau$s),tau=tau2))/s!*(tau-tau2)^(s-1),s=1..10);##F2(K)
P:=tau->(sinh(2*tau)-2*tau*cosh(2*tau))/(2*tau+sinh(2*tau))^2;##P
Q:=tau->(16*tau^4+32*tau^3*sinh(2*tau)-9*sinh(2*tau)*sinh(4*tau)+12*tau*(tau+sinh(2*tau))*((cosh(2*tau))^2-2*cosh(2*tau)+3))/3/(2*tau+sinh(2*tau))^4; ##Q
A:=unapply(taylor(2*(tau-tau1)/sinh(2*tau)-tanh(tau)*(h0-E*tau*tanh(tau))*(2*tau+sinh(2*tau))/((E*tau*tanh(tau)-h2)*F(tau)*sinh(2*tau)),tau=tau1,Term+1),tau);##A(K)
B:=unapply(taylor((1+2*tau/sinh(2*tau))^2*(-(tau-tau1)/lambda^2/E/(E*tau*tanh(tau)-h2)/F(tau)-(h0-E*tau*tanh(tau))*(tau-tau1)*tanh(tau)/(E*tau*tanh(tau)-h2)/F(tau)*P(tau)+(tau-tau1)^2*Q(tau)),tau=tau1,Term+1),tau);##B(K)
for j from 0 to Term do
a[j]:=coeff(A(tau),tau-tau1,j):
b[j]:=coeff(B(tau),tau-tau1,j):
for m from 1 to Term do
f1[0]:=1;
f2[0]:=1;
f1[m]:=-(add(f1[m-i]*((m-i)*a[i]+b[i]),i=1..m))/(m*(m-1+1/2));##pm(z1)
f2[m]:=-(add(f2[m-i]*((m-i+1/2)*a[i]+b[i]),i=1..m))/((m+1/2)*(m+1/2-1+1/2));##qm(Z2)
CC:=unapply(taylor(2*(tau-tau2)/sinh(2*tau)-tanh(tau)*(h0-E*tau*tanh(tau))*(2*tau+sinh(2*tau))/(E*tau*tanh(tau)-h1)/T(tau)/sinh(2*tau),tau=tau2,Term+1),tau);
DD:=unapply(taylor((1+2*tau/sinh(2*tau))^2*(-(tau-tau2)/lambda^2/E/(E*tau*tanh(tau)-h1)/T(tau)-(h0-E*tau*tanh(tau))*(tau-tau2)*tanh(tau)/(E*tau*tanh(tau)-h1)/T(tau)*P(tau)+(tau-tau2)^2*Q(tau)),tau=tau2,Term+1),tau);
j:='j':
cc[j]:=coeff(CC(tau),tau-tau2,j):
dd[j]:=coeff(DD(tau),tau-tau2,j):
i:='i':
f3[0]:=1;
f4[0]:=1;
m:='m':
f3[m]:=-(add(f3[m-i]*((m-i)*cc[i]+dd[i]),i=1..m))/(m*(m-1+1/2));
f4[m]:=-(add(f4[m-i]*((m-i+1/2)*cc[i]+dd[i]),i=1..m))/((m+1/2)*(m+1/2-1+1/2));
xi11:=unapply(add(f1[j1]*(tau-tau1)^(j1),j1=0..m-1),tau);
xi12:=unapply(add(f2[j2]*(tau-tau1)^(j2+1/2),j2=0..m-1),tau);
xi21:=unapply(add(f3[j3]*(tau-tau2)^(j3),j3=0..m-1),tau);
xi22:=unapply(add(f4[j4]*(tau-tau2)^(j4+1/2),j4=0..m-1),tau);
u0:=evalf(g*tanh(tau0)*(1+2*tau0/(sinh(2*tau0)))/(2*k0));
u01:=evalf(g*tanh(tau3)*(1+2*tau3/(sinh(2*tau3)))/(2*k3));
u1:=evalf(g*(1-(tanh(tau0))^2)*(sinh(2*tau0)-2*tau0*cosh(2*tau0))/(4*(2*tau0+sinh(2*tau0))));
H:=evalf((1+2*tau0/sinh(2*tau0))/(-lambda*k0*d));
delta00:=evalf((lambda*d*u1/u0+I*k0)*H);
delta01:=evalf((lambda*d*u1/u0-I*k0)*H);
delta11:=evalf((lambda*d*u1/u0+I*k0)*H*exp(I*k0*l));
delta12:=evalf((lambda*d*u1/u0-I*k0)*H*exp(-I*k0*l));
delta21:=evalf(exp(I*k0*(l1)));
delta22:=evalf(u0*k0*exp(I*k0*(l1)));
delta31:=evalf(exp(-I*k0*(l1)));
delta32:=evalf(-u0*k0*exp(-I*k0*(l1)));
delta41:=evalf(exp(I*k3*(l1)));
delta42:=evalf(u01*k3*exp(I*k3*(l1)));
delta51:=evalf(exp(-I*k3*(l1)));
delta52:=evalf(-u01*k3*exp(-I*k3*(l1)));
delta61:=evalf(exp(I*k3*(l1+d1)));
delta62:=evalf(u01*k3*exp(I*k3*(l1+d1)));
delta71:=evalf(exp(-I*k3*(l1+d1)));
delta72:=evalf(-u01*k3*exp(-I*k3*(l1+d1)));
Y11 := evalf(exp(k0*(l1 + d1)*I));
Y12 := evalf(-exp(-k0*(l1 + d1)*I));
Y21 := evalf(u0*k0*exp(k0*(l1 + d1)*I));
Y22 := evalf(-u0*k0*exp(-k0*(l1 + d1)*I));
G11 := evalf(exp(k0*(2*l1 + d1)*I));
G12 := evalf(-exp(-k0*(2*l1 + d1)*I));
G21 := evalf(u0*k0*exp(k0*(2*l1 + d1)*I));
G22 := evalf(-u0*k0*exp(-k0*(2*l1 + d1)*I));
W11 := evalf(exp(k3*(2*l1 + d1)*I));
W12 := evalf(-exp(-k3*(2*l1 + d1)*I));
W21 := evalf(u01*k3*exp(k3*(2*l1 + d1)*I));
W22 := evalf(-u01*k3*exp(-k3*(2*l1 + d1)*I));
Z11 := evalf(exp(k3*(2*l1 + 2*d1)*I));
Z12 := evalf(-exp(-k3*(2*l1 + 2*d1)*I));
Z21 := evalf(u01*k3*exp(k3*(2*l1 + 2*d1)*I));
Z22 := evalf(-u01*k3*exp(-k3*(2*l1 + 2*d1)*I));
V11:=evalf(exp(I*k0*2*(l1+d1)));
V21:=evalf(u0*k0*exp(I*k0*2*(l1+d1)));
delta91:=evalf(exp(I*k0*l));
delta92:=evalf(exp(-I*k0*l));
Hi:=(Matrix([[1,1],[delta00,delta01]]))^(-1);
H0:=Matrix([[1,1],[delta00,delta01]]);
H1:=(Matrix([[delta21,delta31],[delta22,delta32]]))^(-1);
H2:=Matrix([[delta41,delta51],[delta42,delta52]]);
H3:=(Matrix([[delta61,delta71],[delta62,delta72]]))^(-1);
H4 := Matrix([[Y11, Y12], [Y21, Y22]]);
H5 :=( Matrix([[G11, G12], [G21, G22]]))^(-1);
H6 := Matrix([[W11, W12], [W21, W22]]);
H7 := (Matrix([[Z11, Z12], [Z21, Z22]]))^(-1);
H8 := Matrix([[V11], [V21]]);
Ht:=Matrix([[1],[delta11]]);
e1:=Matrix([[evalf(xi11(tau0)),evalf(-xi12(tau0))],[evalf(eval(diff(xi11(tau),tau),tau=tau0)),evalf(eval(diff(-xi12(tau),tau),tau=tau0))]]);
e2:=(Matrix([[evalf(xi11(tau0)),evalf(xi12(tau0))],[evalf(eval(diff(xi11(tau),tau),tau=tau0)),evalf(eval(diff(xi12(tau),tau),tau=tau0))]]))^(-1);
EE:=evalm(e1.e2);
ee1:=Matrix([[evalf(xi21(tau0)),evalf(xi22(tau0))],[evalf(eval(diff(xi21(tau),tau),tau=tau0)),evalf(eval(diff(xi22(tau),tau),tau=tau0))]]);
ee2:=(Matrix([[evalf(xi21(tau0)),evalf(-xi22(tau0))],[evalf(eval(diff(xi21(tau),tau),tau=tau0)),evalf(eval(diff(-xi22(tau),tau),tau=tau0))]]))^(-1);
EEE:=evalm(ee1.ee2);
MM:=evalm(Hi.EE.EEE.H0.H1.H2.H3.H4.H5):
R:=evalf(MM[2,1]/MM[1,1]):
Kr:=abs(evalf(R)):
KR[N]:=abs(Kr);
N:='N':
seq(KR[N],N=1..Num);
listplot([seq([0.5+2*(N2-1)/(Num-1),KR[N2]],N2=1..Num)]);
I have written a program that checks many possible cases of something. In a line of the code I have programmed  that it prints the number of cases checked every 100 cases checked. However when the number is 200, 300, 400, etc, the number is printed in a new line, and I would like just to replace the precceeding number with the new one. Is it possible? How?
*** Edited to make more clear ***
The function algcurves.puiseux creates generator series for an algebraic function at a point.  The code below generates a few terms of each of the five generator series for the 1,2,3,4 and 5-cycle branch of  w(z) at the origin written implicitly as f in the code below.  Consider the 3-cycle branch:  I extract the 3-cycle generator and plot the imaginary sheet.  Note that's only one surface of a 3-valued function..  In order to plot the other two surfaces the generator series has to be conjugated.   The documentation doesn't appear to have a option to do this.
If there's no procedure for doing this already and some are interested in this, we need to conjugate each individual monomial separately and  multiply each power of z expressed in terms of p/3 by the root of unity raised to the power p.   Not hard to do manually  for a few terms (see updated notebook below)  but I would like to generates several hundred terms.  Note in my updated notebook below how each monomial is multiplied by (exp(2k Pi i/3))^p (for k=1,2) where p is the numerator of the exponent in this case over 3 for the associated power of z.  We can graphically check if this is correct by stitching the sheets together as a Riemann surface via plots:-display(convert({sheet1Plot, sheet2Plot, sheet3Plot}, list)) which shows a 3-valued analytically-continuous surface wraping  around the z-plane three times.   I'll try to write a procedure but I'm brand new to Maple so might take a while.  Maybe call it as
                         conjugatedSeries=conjugatePuiseux(generator,k)
for sheet k.
with(algcurves); f := 6*w^14+z^30+z^32+w^15*(z^2+2)+w^12*(z^3+z)+w^9*(z^9+z^5)+w^5*(z^20+z^14); puiseuxList := convert(puiseux(f, z = 0, w, 5), list)
[(-z)^(9/4), -(-z)^(16/5), -3-(350887/472392)*z^4-(4381/52488)*z^3+(365/243)*z^2-(1/18)*z, -16*(-z)^(14/3)+(2/3)*(-z)^(13/3)+(1/3)*(-z)^(10/3)+2*z^3-(-z)^(4/3), (35663903797/2166612408926208)*(-6*z)^(9/2)-(3407/944784)*z^4-(28431487/69657034752)*(-6*z)^(7/2)-(310547/104976)*z^3-(62285/26873856)*(-6*z)^(5/2)-(1/972)*z^2-(5/15552)*(-6*z)^(3/2)+(1/36)*z-(1/6)*(-6*z)^(1/2)]
sheet1 := puiseuxList[4]
sheet1Plot := plot3d([Re(r*exp(I*t)), Im(r*exp(I*t)), Im(eval(sheet1, z = r*exp(I*t)))], r = 0 .. .15, t = 0 .. 2*Pi, colorscheme = ["Red"])
sheet2 := -16*(exp((1/3)*(2*Pi*I)))^14*(-z)^(14/3)+(2/3)*(exp((1/3)*(2*Pi*I)))^13*(-z)^(13/3)+(1/3)*(exp((1/3)*(2*Pi*I)))^10*(-z)^(10/3)+2*(exp((1/3)*(2*Pi*I)))^9*z^3-(exp((1/3)*(2*Pi*I)))^4*(-z)^(4/3); sheet3 := -16*(exp((1/3)*(4*Pi*I)))^14*(-z)^(14/3)+(2/3)*(exp((1/3)*(4*Pi*I)))^13*(-z)^(13/3)+(1/3)*(exp((1/3)*(4*Pi*I)))^10*(-z)^(10/3)+2*(exp((1/3)*(2*Pi*I)))^9*z^3-(exp((1/3)*(4*Pi*I)))^4*(-z)^(4/3); sheet2Plot := plot3d([Re(r*exp(I*t)), Im(r*exp(I*t)), Im(eval(sheet2, z = r*exp(I*t)))], r = 0 .. .15, t = 0 .. 2*Pi, colorscheme = ["Blue"]); sheet3Plot := plot3d([Re(r*exp(I*t)), Im(r*exp(I*t)), Im(eval(sheet3, z = r*exp(I*t)))], r = 0 .. .15, t = 0 .. 2*Pi, colorscheme = ["Green"])
-16*(-1/2+((1/2)*I)*3^(1/2))^14*(-z)^(14/3)+(2/3)*(-1/2+((1/2)*I)*3^(1/2))^13*(-z)^(13/3)+(1/3)*(-1/2+((1/2)*I)*3^(1/2))^10*(-z)^(10/3)+2*(-1/2+((1/2)*I)*3^(1/2))^9*z^3-(-1/2+((1/2)*I)*3^(1/2))^4*(-z)^(4/3)
-16*(-1/2-((1/2)*I)*3^(1/2))^14*(-z)^(14/3)+(2/3)*(-1/2-((1/2)*I)*3^(1/2))^13*(-z)^(13/3)+(1/3)*(-1/2-((1/2)*I)*3^(1/2))^10*(-z)^(10/3)+2*(-1/2+((1/2)*I)*3^(1/2))^9*z^3-(-1/2-((1/2)*I)*3^(1/2))^4*(-z)^(4/3)
Download puiseuxPlotsVer2.mw
I have tried to translate the Mathematica-Code of OEIS (A219954):
with MmaTranslator. In the translator occurs an error message with the IF-Statement ...
I will be happy to have this in Maple. I am interested in the digitCount in the above Code.
Sequence is:
Thanks for help :)
Auto_regne_dokument.mw
My maple froze while it was running. I saved and closed it and now it gives me this message when i try to open it "There was a problem in the loading process, you worksheet may be incomplete.".
There is only one backup file and it is corrupted as well. I tried to see if i could work it out in the text file, but im not very good at doing this.
If anyone knows how to uncorrupt it pls help me
I have a boundary value problem,
How can I solve the problem using maple or maybe we can introduce serie expansion to solve it or something else.
BVP_frac.mw
I have problem to calculate the max value for 3d  phase potret for each period. Thank You
 deplot3d-animated_SIA.mw
How could one reduce this equation int(x^2*diff(y(x), x)/(x^2 - 1), x) = int(y(x)^(1/2), x)^(-2/3)down to a first order ordinary differential equation? Maple can solve this equation, namely, 9*(1/x^(5/3) - 1/x^(11/3))*x*(sqrt(y(x))*x)^(8/3)/(8*(x^2 - 1)) - 3*x*(4*x^2 - 1)*(1/x^(5/3) - 1/x^(11/3))/(8*(x - 1)*(x + 1)) + _C1 = 0 , however I could not understand how this equation was arrived at, leading me to go to 'odeadvisor', which responded with y = G(x,y'(x)) labelled as the 'patterns' method, which appears to require a first order ode - that is why I raised the reduction question.
Please pardon the poor format below.  I'm new to Maple and cannot figure out how to cut and paste worksheet code which includes  Maple prompts.
I would like to create a list of funtions in a set and then select one and plot its real or imaginary surface.  I'm able to do this with a single function below:
h := z -> z^(1/2);
    h := proc (z) options operator, arrow; z^(1/2) end proc
plot3d(Im(h(x + y*I)), x = -1 .. 1, y = -1 .. 1);
This plots the Imaginary surface of z^(1/2).  However I need to do this with a set of functions delimited with curly brackets such as:
functionList = {2 + z, z^2 - 3*z, -z^3 + 4};
                          /        2          3    \
          functionList = { 2 + z, z  - 3 z, -z  + 4 }
And if I now try and select the first function in functionList and attempt to plot it, the plot is blank.
v := z -> functionList[1];
v := proc (z) options operator, arrow; functionList[1] end proc
plot3d(Im(v(x + y*I)), x = -1 .. 1, y = -1 .. 1);
Warning, expecting only range variables [x, y] in expression Im(functionList[1]) to be plotted but found name functionList[1]
 Can someone help me with this problem and also explain to me how to format this post nice like the others?
Thanks for reading.
I wanted to solve a pde of two variables in spherical coordinates with a boundary condition at a specific radius. I am doing something wrong because the pdsolve just evaluates for several minutes and does not actually give anything.
Could someone have a look and let me know what I am doing wrong.
with(Physics[Vectors])
[mathematicalnotation = true]
eq3 := Laplacian(Phi_out(r, theta)) = 0
((r^2*(diff(diff(Phi_out(r, theta), r), r))+2*r*(diff(Phi_out(r, theta), r))+diff(diff(Phi_out(r, theta), theta), theta))*sin(theta)+(diff(Phi_out(r, theta), theta))*cos(theta))/(r^2*sin(theta)) = 0
bc1 := eval(Phi_out(r, theta)-Omega*mu*(-1+cos(2*theta))/(2*r), r = R) = 0
Phi_out(R, theta)-(1/2)*Omega*mu*(-1+cos(2*theta))/R = 0
pdsolve([eq3, bc1])
Download laplacian.mw
How to generate different letters? I've tried the 'exclude' option, which doesn't work in this context. Thank you.QuestionAlphabet.mw
I have data that I've binned in list. I'd like to plot in as a histogram.
dataplot sort of does it but doesn't give the x-axis that I used but just the bins.
Yes, I know about Histogram from Statistics. To plot 1000000 values I have to enter them all into a list which seems crazy when all I want is a 100 bin histogram. Doing the binning is trivial, but I can't figure out how to plot it with a sensible x-axis (show range used to define the 'histogram')
First 199 200 201 202 203 204 205 Last Page 201 of 2457
