Sorry, but I am novice at all. I could make the pkt list. But how can I plot the Function with the optimized parameters and the pkt-list into one diagram? Thanks a lot. Walter
Given Datas:
xd := Vector([0, 25, 50, 75, 100, 125, 150, 175, 200, 225, 250, 500, 750, 1000, 1250, 1500, 1750, 2000, 2500, 3600])
yd1 := Vector([0, 6.24, 11.26, 14.9, 17.58, 20.01, 22.0, 23.56, 24.85, 26.03, 27.36, 35.07, 39.4, 42.61, 44.36, 45.79, 46.62, 46.9, 47.79, 48.85])
Given function: (looks a little different in Maple, but copy and paste did not work)
<maple>F2 := proc (x) options operator, arrow; K2*(1-(T12-Tv2)*exp(-x/T12)/(T12-T22...
Maple seems to constrain pie charts to having only a name, or only a percentage or frequency. I want it all.  I don't want to choose between labels and numbers.
A pie chart like this one would be a good start: http://www.mmsonline.com/cdn/cms/Sandvik-pie-chart.jpg except I want to present frequency as well.
Notice in the example above that the large...
I need a contour plot of c with a and b values as x and y axis.
a := `<,>`(Vector(12, {(1) = .19375, (2) = .19494, (3) = .19581, (4) = .19632, (5) = .19646, (6) = .19624, (7) = .19565, (8) = .19472, (9) = .19349, (10) = .19198, (11) = .19024, (12) = .18833}))
b := `<,>`(Vector(12, {(1) = -0.1517e-1, (2) = -0.1515e-1, (3) = -0.1512e-1, (4) = -0.1509e-1, (5) = -0.1506e-1, (6) = -0.1503e-1, (7) = -0.15e-1, (8...
Below is a small tidbit of code that operates on the matrix vel and updates its values.  When I check the values of the indices in the matrix, every single element, barring vel(1,1), vel(1,2), and vel(1,3), is equal to 0.
vel := Matrix(3, 241, datatype = float[8]);
step := 0.1;
vel(1, 1) := 5; vel(2, 1) := 95; vel(3, 1) := 3;
UpdateAllVelocities := proc (i, vel::Matrix, accel::Matrix, step);
#I understand these calls are quite pointless......
With a lot of languages, the compiler will issue warnings when the user does something that could cause errors. I often find myself mistyping or misspelling words in Maple, and this often leads to runtime errors.  Is it possible to make the interpreter issues warnings when I implicitly declare a variable or do something similarly risky?
Here's my first attempt at posting some 2DMath on this site.
First, I will paste directly from 2D output in a running Standard GUI Maple session.
BesselJ(0, x)+GAMMA(Psi)-sqrt(abs(omega))
How can I build an increasing list using a loop?
Something like this
a[1]:= [...]
a[2]:= [...]
a[3]:= [...]
c[1]:=a[1]
c[2]:=[op(a[1]),op(a[2])]
c[3]:=[op(a[1]),op(a[2]),op(a[3])]
etc...
I thought about using a loop but then got stuck
for i from 1 to 3 do
  c[i]:= ???
Hi everyone.
I have been experiencing a problem trying to solve a coupled system of 4 differencial equations, 2 PDEs with 2 ODE.
My problem is that a got a message back as I try to solve the system:
"Error, (in pdsolve/numeric/process_IBCs) improper op or subscript selector"
My first question is: Am I defining the IBCs rightly?
If not, I don`t have a clue on how to solve this problem, I really apreciate some help out here.
Thanks for all the above input.
Now I have imported my text file using TOOLS->ASSISTANTS->IMPORT DATA .
Text file has 3 columns: x, y and z.
How can I get a contour plot 3d from this matrix i.e. plot z using x and y values as axes.
Thanks again.
Dear Colleagues, I need your cooperation.
How to make the following graphs to illustrate the SVD of a Matrix
How do I insert a hyperlink with this new site?  The link icon on the toolbar is grayed-out.
Just a simple histogram, but how do I select the values from the graph.
op(b) pulls out the data of the graph
POLYGONS([[1., 0], [2., 0], [2., 1], [1., 1]], [[2., 0], [3., 0], [3., 0], [2., 0]], [[3., 0], [4., 0], [4., 1], [3., 1]], [[4., 0], [5., 0], [5., 2], [4., 2]], [[5., 0], [6., 0], [6., 1], [5., 1]], [[6., 0], [7., 0], [7., 1], [6., 1]], [[7., 0], [8., 0], [8., 1], [7., 1]], [[8., 0], [9., 0], [9., 4], [8., 4]], COLOUR(HSV, .5476190475, 1.000000000, .7000000000))
Can anyone explain the below printscreen in simple terms ?
It is taken from http://www.lgt.com/export/sites/inta_lgtcom/fr/institutionelle_kunden/kompetenzen/traditionelle_anlagen/lgt_and_science/aktuelle-projekte/quantitative-finance/Projekt_EfeAksueyek_en.pdf
on pages 24. Why do we have such a ratio (second formula) ?
Hi friends,
here is a paper from a book, which partiell diff equation I would like to solve with MathCAD or Mathematica or Maple. WHo can help? Thanks  a lot spending your time.  here is the PDF File with the paper
First 2018 2019 2020 2021 2022 2023 2024 Last Page 2020 of 2463
