I have 3 different arrays. is there any way that I can put these 3 arrays in one table with a proper heading above each column?
I am trying to create a pointplot animation for a list can anyone tell me what is wrong with the following code:
with(Statistics):
L:=[[1],[3, 2],[3.4, 6], [5,3,7], [3,7,9,1], [2,6,8,4,5]]:
animate(PointPlot, [L[t]], t=1..5);
I am trying to animate a graph to show the progress between each suset from t = 1 to n.  I belive the problem has something to do with t not being an integer in the animate setting.
I get this strange (to me) behavior:
interface(showassumed=0);
assume(theta,real);
assume(phi,real);
SourcePosition:=[phi,theta];
parameters:= [SourcePosition[1],SourcePosition[2]]:
 save parameters, "./parameter.txt";
wanted_par:=[convert(SourcePosition[1],string),convert(SourcePosition[2],string)]:
save wanted_par, "./wanted_par.txt";
I Wanted To Model a Ball Screw in MapleSim4, I should  Imply a force to the base of the ball screw while the nut is attached to a fix pint and I expect the shaft of the ball screw rotates. I would be so thankful If any one tell me an idea how to model it to use at Maplesim4 for as I could not find any component for ball screw on MapleSim.
Looking forward to hearing from you
I wanted to plot Laplace's spherical harmonics, which basicly worked. But now I wanted to add two sliders with which i want to vary m and l. This also works nearly. I can vary l and plot the new spherical harmonic. The variable m has to hold the restriction: -l<= m < = l.
So my question is, how can i synchronise the two sliders, so that when i edit silder l the range for slider m is changed?
Thanks for your help!
> restart;
> with(linalg);
> uvec := array(1 .. 2, [u_(x, y, t), v_(x, y, t)]):
> xvec := array(1 .. 2, [x, y]):
> equns := array(1 .. 3, []):
> for i to 2 do
   equns[i] := sum('uvec[j]*(diff(uvec[i], xvec[j]))', 'j' = 1 .. 2)
the result the maple 11 gives is:
I have created a Monte Carlo simulation using maple using the following do loop for each iteration:
for count from 1 to n do
end do
I would like to show through animation (pointplot) how the model develops with changing n.
Can anyone help me with this problem?
Thanks in Advance
I have created a Monte Carlo simulation using the following do loop for each iteration:
end do
I would like to show through animation how the model develops with changing n.
Thanks in Advance
I'm solving a non-linear system of equations (8 equations, 7 parameters) numerically using Fsolve.
Here's my problem: I run fsolve in a loop for different values of one specific parameter. What I would like to do however is have a matrix of parameter values and tell fsolve to pick a new row of that matrix each time as parameter values until it has run down all the rows.
I just need some general guidelines and the commands. Much appreciate the help...
I was wondering if there is a more elegant way of doing this:
SX := proc ()::set; local j, sx, SEqn; Digits := 30; SEqn := {evalf(subs(EV, Eqn(1)))}; for j from 2 to n do SEqn := `union`(SEqn, {evalf(subs(EV, Eqn(j)))}) end do; sx := SEqn end proc:
Charles
Please , can anybody tell me about the basical things to know about Maple that are not described in the internet . I mean about adding a new line with the sign > , joining or parting two parts , or insert a title and above all where i can find the list of the pakages wee need to perform a program .
hi
I have this PDE:
PDE := diff(f(x, y), x, x)+diff(f(x, y), y, y) = 0
With BCs
bc := {f(0, y) = 0, f(1, y) = 0, f(x, 0) = 0, f(x, 1) = sin(Pi*x)}
which has a relatively simple exact solution.
I'm trying pdsolve and getting nowhere, either numerically or symbolically.
Any advice most welcome
PL
Hello everyone, I wonder how to carry out the so-called total derivative over a certain function with retaining the differential symbol "d". For example y=r*sin(theta) then how to obtain the following result from maple dy=r*cos(theta)d(theta)+sin(theta)dr. Thank you.
Hello there I'm a newbie, both here and to Maple !
I am performing arithmetic operations with polynomials. Can I get a step by step solution with such operations?
how can i found the integer number after any divident using maple commands
like
(13/4)
First 2022 2023 2024 2025 2026 2027 2028 Last Page 2024 of 2463
