Hello, i have attached the file here.
Basically i have an eighth order equation in m. This will produce eight solutions of m. Then i need to substitute each solution of m into a matrix, say M. Thus generating a matrix for each m value. Can someone show me how to do this please...
Greetings Is there a nice way to obtain the jacobian of a system of ODEs ? For example with restart: ross_x:=diff(x(t),t)=-y(t)-z(t): ross_y:=diff(y(t),t)=x(t)+a*y(t): ross_z:=diff(z(t),t)=b+x(t)*z(t)-c*z(t): rossler_sys:=ross_x,ross_y,ross_z; I can't seem to find an easy way to do it, other than re-write the system altogether s_x:=-y-z: s_y:=x + a*y: s_z:=b+z*(x-c): J:=Matrix([[diff(s_x,x),diff(s_x,y),diff(s_x,z)],[diff(s_y,x),diff(s_y,y),diff(s_y,z)],[diff(s_z,x),diff(s_z,y),diff(s_z,z)]]); .....which seems horrible. Thanks LR
Hello! Why does Maple not compute the following residue? residue(((x^7+1)^4/x^30), x=0); Maybe the powers are too high? Are there any parameters I can set so that Maple produces a result? Thanks! Marco
How can I tell Maple to read all txt files in a specified folder ?
The names of each txt files are different ( I dont know the names )
Using maple help: wiht(plots): animate(plot, [Ax^2, x = -4 .. 4], A = -3 .. 3, trace = 5, frames = 50) the above command shows a plot with no animation... What's wrong?
*sigh* Mathematica,
how do I plot the bifurcation diagram with Maple of the function:
dx/dt = rx - sin(x) ?
My goal: given G(z,w), find the polynomial, P(n), in the partial derivatives of G(z,w) over the integer such that
d^n z/ dw^n = P(n) / Gz^(2n-1)    where Gz= partial derivative of G with respect to z.
Step 1. Differentiate G(z(w),w) w.r.t w n times. Formulae are known for doing that (Mishkov, Tsoy-Wo Ma),
question1:
with(Optimization)
Minimize((1-b^2)/a+(1-c^2)/b+(1-a^2)/c, {a^2+b^2+c^2 = 1}, assume = nonnegative)
the result is strange:
[3.46410161513774462, [a = .577350269189626620, b = .577350269189626620, c = .577350269189626620]]
make the datatype not the float form in the results. 3.4641... to 2 sqrt(3)
question2:how to do this.I use sqrt(1-a^2-b^2) to substitute for c.
Minimize((1-b^2)/a+(1-a^2)/sqrt(1-a^2-b^2)+(a^2+b^2)/b, assume = nonnegative)
question3:
Hello, everyone! I would like to find a the unique, reduced grobner basis of a particular ideal. I know that gsolve in the old with(grobner) package would return this, but I can't decipher the documentation of the new with(Groebner) package to figure out how to do it.
If I have a list of polynomials and a given monomial order, I know that I can call:
with(Groebner);
my_gb := Basis(my_I, my_ord)
I am solving numerically a non-linear Pde using the command  "pds:=pdsolve(....)"  and all are as they should be...[ pds := module ()...] but when i am trying to plot the outcome i receive: "Error, (in pdsolve/numeric/xprofile) unable to compute solution for t>.188000000000000000:Newton iteration is not converging "
Is there a way to overcome this problem (even if i must lose in accuracy..)???
My comp (AMD Athlon 64 Processor 3000+, 1.5 GB RAM) calculates the integral int(1/(x^4+3*x^2+1)^p,x=0..infinity) for p<=545 and the same comp with Maple 10 calculated this integral for p=3000. The answer is of the form k/n*Pi*sqrt(5), where k and m are natural numbers.
How to explain that?
Anyone know how to debug FOR loops in MAPLE? Thanks in advance.
Luciane.
Hi, guys, I want to compare the performance of procedures which are written by myself. But I have no idea how to get the runtime of a procedure. Thanks in advance.
Hello folks i was hoping for a spot of help.
I need to normalize three vectors. Each vector is 1 by 3 in size. Ive started by defining the vector then normalizing it by what i have defined it. The next stage is where im stuck, ive looked through various examples inclduing the one i this link: http://www.maplesoft.com/support/help/AddOns/view.aspx?path=LinearAlgebra%2fNormalize
Does anyone know where V:={1.55,1.56,1.53} comes from?
 I read to *.wav, copy them into two arrays with same size and I'm not able to write it anymore.
Anybody here who can help?
with(AudioTools);
with(ArrayTools);
readlib(FFT);
signalfile := cat("C:/Documents and Settings/848380/Desktop/", "klar.wav");
hfile := cat("C:/Documents and Settings/848380/Desktop/", "church.wav");
x := Read(signalfile);
y := Read(hfile);
Preview(x);
Preview(y);
First 2075 2076 2077 2078 2079 2080 2081 Last Page 2077 of 2459
