I know this sort of simplify question has been asked many times, but I still don't seem to have 'got it'.  In a nutshell, there's a conservative real 2-D vector field (cartesian X,Y coordinates) with an extra non-positive parameter Z, and Maple 12 is able to compute the scalar potential.  But it presents it in a long (6 lines), perversely complicated form, involving the imaginary sqrt(-Y^2).  I tried to show it here using the Maple leaf Tag and pasting the expressions there, but all I got was indecipherable ascii.  The vector field X and Y components are
    I want to find a relation between tow sets of discrete points. So I must plot a curve with these dicrete point pairs. But  the two sets points don't have a explict relation (in fact, the relation just is that I want to find) How  to treat the discrete point pairs with maple? Thank you very much!
Best regards!
I was wondering if there was a way to have two background plots on an animation?  I would like 2 seperate parts of the animation to remain constant but I can't figure out how to do that without connecting the seperate parts.
hi, I m pretty new with maple,  could someone tell me how to calculat the area of parabola and x-axis,the equation of parabola is 3x^2-22x+7,
Hey so I've been given a set of data, I was told to make a scatter plot which i did now I have to:
Use the regression feature of Maple to find a linear model of the data.
I don't know how to do this. What I have right now is:
> data := [[2005, 2.85], [2006, 5.70], [2007, 10.0], [2008, 14.8], [2011, 25.0]];
> with(plots);
> pointplot(data);
What's the next step?
I'm looking to display some results in my for loop but not others.  This is my code:
for j from 0 to 10 do
    fileName := sprintf(`destination%d.txt`, j):
    datalist := readdata(fileName, integer, 3):
    pointplot3d(datalist, style = line, linestyle = solid, thickness = 5);
I'm sort of new with Maple and programming so I would like to ask a couple of questions related to Matrix polishing / changing numbers in Matrix. The example code is as follows:
Just like the "hold on" in matlab, I think it is a good function:)
Guys, I solved a huge set of non linear equations for a range of input values and the results printed out are of a great volume and it is too hard to read the value for a particular set of input values.Is there any way i cud get the results in a table form as we get it in matlab in the workspace window.So i cud easily copy paste in excel sheets.
Hi all, I need to solve these two nonlinear equations for unknowns b and u. I have used solve command and maple is evaluating for last 5 hours. Is there any faster way to solve these equations? Also, can I somehow check if maple is not stuck in an infinite loop? equation 1: 16*Pi^2*1.5)*10^6*sqrt(Pi/(2*b^3))*((1000/3*((2/3)*exp(b*(u-4300))+3/4))*(exp(b*(u-4300)))^(3/2)/(exp(b*(u-4300))+1)+500*sqrt(exp(b*(u-4300)))^ln(exp(-b*(u-4300))+1)) = 1, equation 2:
I used seq command to get a list of numbers......seq(2*x+8,x=1..10)...for example.
How can I take the output and convert it to a table? Thanks in advance.
I have some expression given as a "RootOf": i.e.
sol := RootOf(p(_Z));
How do I grab a hold of the polynomial inside?  This should be in the RootOf help file ... am I missing it?
I have an array called plotter[1..20]; each element in the array is a set of coordinates for a point plot in 3d.
ie:
print(plotter[1]);
output: ARRAY([1..105],[(1)=(3,3,4), (2)=(2,3,4)....etc   ]
I am able to plot them individually, but the different array elements are dependent on each other and I want to see how they change over time.
Ideally I would like to use animate3d but I don't feel like the parameters support what I'm trying to do. Is there any other function which would work for this process?
Is it possible to define a symbol for pointplot and pointplot3d (beyond the ones listed in the options help pages)?
Specifically, can I define a character from an installed font as the plot symbol?
who can tell me how to find distance of point p from line L by using maple
First 2155 2156 2157 2158 2159 2160 2161 Last Page 2157 of 2459
