I was trying to solve this nonlinear ODE using dsolve:
ode:=(diff(f,x)*diff(g,y)=1): dsolve(ode);
but got: Error, (in ODEtools/info) R equired a specification of the indeterminate function
I'm not sure what Maple means by "indeterminate function" .. does that mean I need an explicit function for g(y)??
I would assume that Maple would be able to do this without knowing g(y) since one solution is (1/n)*f(x) + n*g(y).
I have a 6*6 matrix which is A:[1,1,1,1,1,1],[1,0,-1,1,0,-1],[2,1,0,2,1,0],[4,1,2,0,4,1],[1,-2,1,-6,0,1],[5,4,-1,-2,5,0]
How can I show the system Ax=b is consistent or inconsistent if
x= [x1          b= [1
     x2                 0
     x3                 1
Hi i was wondering if anyone could tell me what code i have to program the Bisection Method. I can't seem to get the while loop to work. it only gives me the first iteration and stops. Here is what i have done
f:=x ->x^3-x-8:
a:=2;
b:=3;
f(a);
f(b);
while sign(f(b)) <> sign(f(c)) do
if (f(b)*f(c)) > 0 then
b:=c:
a:=c;
c:=(a + b)/2
end if:
print(c);
2.5
I just can't get it to work.
I'm an upper-level undergraduate mathematics student, and I'm working on a project to create an algorithm to determine if any function is convex.  My Professor suggested that I post in this forum, to appeal for suggestions.
I hope to apply the algorithm to single or multivariable functions, which have polynomial, power, logarithmic, exponential, trigonometric, or any combination thereof.  The algorithm should work on any predefined domain.
Hi, all, I know there is a polynomial function from GF(2^m) to itself, but whether there is a mapping from GF(2^m) to GF(2^n)? thank you
I use Maple 9.5 on a Mac PowerPC G4.
Recently I have been unable to open a new worksheet. I have restarted my machine numerous times.
Do you have any suggestions for what to do--I am away from home and don't have the software to reload.
I think the problem first started because I opened some old files--running Maple 4 or 5.
Roger
Hello,everyone,
I have a problem with the symbolic equations,
would somebody help me to solve the follow equations, thank you very much!
Hi everybody,
I am doing the following:
http://hmco.tdlc.com/precalc/tdlc/www_precalc.htm#
If you could go to CH6 then Section 1 then Exercises. #30 is giving me trouble
:( plz&thx
I got an expression f:=R^3/(z^2+R^2)^(3/2); and would like to plot f as a function of (z/R), not z. Here R is a parameter. Could someone give me a hand?
It seems Maple's Sample command cannot handle self-defined distribution well. Check this:
I am in a college level physiology class, and have been assigned the task of deriving the Boltzman equation with Maple.  I have never used Maple before and find myself at a loss how to even start.  I've read through the tutorials and still am having difficulty using this program.  To define Boltzman equation, we are supposed to plot the Boltzman curve of force vs probability that channel is open.  Force is just equal to x, and probability that channel is open would be on the y axis and is defined as a/(a+b).  The second component of the equation involves t
given 4 points ex. (-3,4),(-1,3),(0,5),(1,6). how can I find two polynomial of degree5 passing throuh these 4 point. Is is also possible to fing more than two ? How do you know ?(what if you want to find polynomial of degree three thru these4 point, how you know how many there exist?) I just made up those point...
To enable page numbering, I am instructed to select Page Numbers fom the Format menu, however, there's no Page Number choice on the Format menu of my Maple 12 installation. What can I do?
Thanks, Paul
If I have a set of numbers,
1, 2, 3, 4, 5
for example, how do I compute their mean?
How do I compute their standard deviation?
I am trying to avoid explicitly recopying cutting and pasting
my data over and over again, such as
a:= (1 + 2 + 3 + 4 +5 )/ 5;
sdev: = sqrt( (a-1)^2 + (a-2)^2 etc.
My REAL question is: WHERE in Maple 11 Help is an example shown anywhere of an explicit finite data set of numbers, such as 1, 2, 3, 4,5, or a set of pairs of numbers (2,3), (4,5) etc
First 2187 2188 2189 2190 2191 2192 2193 Last Page 2189 of 2459
