When implementing the Groebner Basis over Galois Field(2^m), I found an interesting thing: to represent and compute over GF, you have to map first.
 for example
generally the function having zero points or poles with non-integer order such as f(z) = (z-a)^(1.5+i0.3) must be dealt with on appropriate Riemann surface. In the following link I tried to extend the argument principle for such functions on a single sheet of Riemann surface and got a formula similar to that of ordinary argument principle. Using that formula the winding number of f(z) = (z-a)^(1.5+i0.3) around the origin is expressed as 1.5+i0.3.
I would like to find the date 6 months from a given date and also how many days are elapsed between two dates ? Are there any date functions defined in maple to perform above tasks ?
Kiran
I have a matrix;
                1   -4  1
A4:           0    7  5
                 0    0   0
After writing a code I was given an output from Maple in the following form: {n=1,x=4,lplp=6,lpsp=8}. I need to use these values separately. How to I get them out of the brackets? When I type n on the next line it just shows "n" not n=1. Any ideas?
I need to specify some boundary conditions and I am unsure how to write it. My conditions are
F[m,n](1)=1,F[m,n](-1)=-1 if m=n=0 else F[m,n](1)=F[m,n](-1)=0  and F'[m,n](1)=0 and F'[m,n](-1)=0 for all m and n
how do i specify this?
 (2x-a/x+a)-(x+3a/a-x)-(a^2/a^2-x^2)
hey
let me put it simple: in maple if I do
However,
if i do l := list(30); l[1] := 2; l[2] := 2; l[3] := 3; l[4] := 3; l[5] := 5; l[6] := 7
I have following program and get error
>f := (x,y) -> `if`(x>1, x+y, x-y);
>f(1.1,0.1);#function without int evaluated correctly
                                     1.2
>ff := (y) -> int(f(x,y), x=-2.0..2.0);
>evalf(ff(1.2));
Error, (in eval/if) cannot determine if this expression is true or false: 1 < x
I have the differential equation below
de1:=diff(F(eta,alpha,R),eta$4)+alpha*eta*diff(F(eta,alpha,R),eta$3)+2*alpha*diff(F(eta,alpha,R),eta$2)-R*(diff(F(eta,alpha,R),eta)*diff(F(eta,alpha,R),eta$2)-F(eta,alpha,R)*diff(F(eta,alpha,R),eta$3));
How do I evaluated it with a series representationtation of F like the one below
F(eta,R,alpha)=add(add(F[n,k](eta)*R^n*alpha^k,k=0..10),n=0..10);
i tried using the subs command to substitute it in but just got back what i started with
Dear OpenMaple users,
we try to tackle the following problem (unfortunately with limited success):
We would like to use OpenMaple (Maple 12) to call a maple procedure from C (C++ with only C features used). We have the void-function myfunction which gets two n x d arrays (d<=20, called inputmatrix and outputmatrix), a double parameter myparameter, a MKernelVector kv, and an ALGEB r.
Hello! My question is how I can decompose, for example, sin(x) to infinite product. Something like this: Pi*z*Product(1-z^2/n^2,n = 1 .. infinity) = sin(Pi*z) Thanks
hi I want to write a program that convert a polygon to triangle, that is if we have polygon with 6 edges, how we can get triangle from it using edges or vertices??
I am biginner,
It is well know that the quintic equation is not solved by radicals generally. Although the solution for quintic equation is expressed explicitly by using Jacobi theta functions, in the following site I tried to find a differential equation as a solution for inverse function of general quintic polynomial, and found it is expressed with the 5-th degree nonlinear differential equation.
http://hecoaustralia.fortunecity.com/stbruno/stbruno-s.htm
Would appreciate some guidance for this question:
If q = ax + by and r = bx - ay, determine the value of:
First 2202 2203 2204 2205 2206 2207 2208 Last Page 2204 of 2469
