hi i am trying to create a procedure for newton rhapson method, which finds roots of a function. the first procedure i made work but now i want it to show an error message for when the function diverges at x0 and when the derivative at x0 = 0. can someone pls advise me how to fix it? thank you:)
NM1 := proc(f, xold)
    local x1, x0, precision;
    x0 := xold;
    x1 := evalf(x0 - f(x0)/D(f)(x0));
    precision := 10^(-3);
        if limit(f,(x0)) = 0 then
            error("Newton's Method cannot do the calculation");
        if D(f)(x0) = 0 then
        while abs(x1-x0) > precision do
            x0 := x1;
            print(x0);
   return x1;
Dear users!
I hope everyone is fine here. I have the following expression:
r*y[0, 1]+y[0, 0]+(1/6)*r*(r-1)*(1+r)*y[-1, 3]+(1/2)*r*(r-1)*y[-1, 2]+(1/120)*r*(r-1)*(r-2)*(1+r)*(2+r)*y[-2, 5]+(1/24)*r*(r-1)*(r-2)*(1+r)*y[-2, 4]+(1/720)*r*(r-1)*(r-2)*(r-3)*(r-4)*(1+r)*y[-3, 8]+(1/360)*r*(r-1)^2*(r-2)*(r-3)*(1+r)*y[-3, 7]+(1/720)*r*(r-1)*(r-2)*(r-3)*(1+r)*(2+r)*y[-3, 6]:
What is the procedure to select some terms in the above expression for example for N=2 I just want the following terms:
y[0, 0]+r*y[0, 1]+(1/2)*r*(r-1)*y[-1, 2];
and for N=3 I just want the following terms:
y[0, 0]+r*y[0, 1]+(1/2)*r*(r-1)*y[-1, 2]+(1/6)*r*(r-1)*(1+r)*y[-1, 3];
and for N=4 I want:
(1/24)*r*(r-1)*(r-2)*(1+r)*y[-2, 4]+y[0, 0]+r*y[0, 1]+(1/2)*r*(r-1)*y[-1, 2]+(1/6)*r*(r-1)*(1+r)*y[-1, 3];
and so on,
in the descending order in first suffices and ascending order in second suffices (like term having y[0,0],  y[0,1], y[-1,2], y[-1,3], y[-2,4]). I am waiting for your response. Thanks.
1) the two cylinders are centered on the x and z axis respectively
2) any two intersecting cylinders
Hi everyone,
Please I need your help, if anyone has idea of using Perturbation Theory to Solve the following Logistic Fractional Equation and ploting with iteration. Thanks
Restart
u(t):=1/(m)(u(t)-(u^(2)(t))/(k));
uu(t):=(k*u_0)/((u_0+(u_0)*k)*(e)^(-t/(m)))
u(0) = u_0
I want to define the functions 10 and 11 and then put them in the eq equation, then simplify them and get the unknown values after the solve command, but there are error.
And value the function psi ?
with(student)
"U(xi[n]):=a[0]+sum(-a[i]*psi^(i)(xi[n]),i=1..1)+sum(-b[i]*psi^(-i)(xi[n]),i=1..1)+sum(-c[i]*((diff(psi,xi[n])^(i)))/(psi^(i)(xi[n])),i=1..1);"
Error, empty script base
Typesetting:-mambiguous(Typesetting:-mrow(Typesetting:-mi("U", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("ξ", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mi("n", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), open = "[", close = "]", font_style_name = "2D Input", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo("≔", accent = "false", fence = "false", largeop = "false", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mi("a", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mn("0", mathvariant = "normal"), open = "[", close = "]", mathvariant = "normal"), Typesetting:-mo("+", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.2222222em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mi("sum", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mo("&uminus0;", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.2222222em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mi("a", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mi("i", fontstyle = "italic", mathvariant = "italic"), open = "[", close = "]", mathvariant = "normal"), Typesetting:-mo("⋅", accent = "false", fence = "false", font_style_name = "2D Input", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-msup(Typesetting:-mi("ψ", font_style_name = "2D Input", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mi("i", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), superscriptshift = "0"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("ξ", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mi("n", fontstyle = "italic", mathvariant = "italic"), open = "[", close = "]", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(",", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.3333333em", separator = "true", stretchy = "false", symmetric = "false"), Typesetting:-mi("i", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mo("=", accent = "false", fence = "false", largeop = "false", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("1", mathvariant = "normal"), Typesetting:-mo(".", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mo(".", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("1", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo("+", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.2222222em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mi("sum", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mo("&uminus0;", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.2222222em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mi("b", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mi("i", fontstyle = "italic", mathvariant = "italic"), open = "[", close = "]", mathvariant = "normal"), Typesetting:-mo("⋅", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-msup(Typesetting:-mi("ψ", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mo("&uminus0;", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.2222222em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mi("i", fontstyle = "italic", mathvariant = "italic")), superscriptshift = "0"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("ξ", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mi("n", fontstyle = "italic", mathvariant = "italic"), open = "[", close = "]", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(",", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.3333333em", separator = "true", stretchy = "false", symmetric = "false"), Typesetting:-mi("i", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mo("=", accent = "false", fence = "false", largeop = "false", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("1", mathvariant = "normal"), Typesetting:-mo(".", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mo(".", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("1", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo("+", accent = "false", fence = "false", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.2222222em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mi("sum", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mo("&uminus0;", accent = "false", fence = "false", font_style_name = "2D Input", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.2222222em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mi("c", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mi("i", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), open = "[", close = "]", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("⋅", accent = "false", fence = "false", font_style_name = "2D Input", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mfrac(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("diff", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("ψ", font_style_name = "2D Input", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mo(",", accent = "false", fence = "false", font_style_name = "2D Input", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.3333333em", separator = "true", stretchy = "false", symmetric = "false"), Typesetting:-mi("ξ", font_style_name = "2D Input", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mi("n", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), open = "[", close = "]", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mambiguous(Typesetting:-msup(Typesetting:-merror("?"), Typesetting:-mi("i", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), superscriptshift = "0"), Typesetting:-merror("empty script base"))), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-msup(Typesetting:-mi("ψ", font_style_name = "2D Input", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mi("i", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), superscriptshift = "0"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("ξ", font_style_name = "2D Input", fontstyle = "normal", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mi("n", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), open = "[", close = "]", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal")), bevelled = "false", denomalign = "center", linethickness = "1", numalign = "center"), Typesetting:-mo(",", accent = "false", fence = "false", font_style_name = "2D Input", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.3333333em", separator = "true", stretchy = "false", symmetric = "false"), Typesetting:-mi("i", font_style_name = "2D Input", fontstyle = "italic", mathvariant = "italic"), Typesetting:-mo("=", accent = "false", fence = "false", font_style_name = "2D Input", largeop = "false", lspace = "0.2777778em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(".", accent = "false", fence = "false", font_style_name = "2D Input", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mo(".", accent = "false", fence = "false", font_style_name = "2D Input", largeop = "false", lspace = "0.2222222em", mathvariant = "normal", movablelimits = "false", rspace = "0.0em", separator = "false", stretchy = "false", symmetric = "false"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(";", accent = "false", fence = "false", largeop = "false", lspace = "0.0em", mathvariant = "normal", movablelimits = "false", rspace = "0.2777778em", separator = "true", stretchy = "false", symmetric = "false")))
U(xi[n+1]) := U(xi[n]+d)
U(xi[n]+d)
U(xi[n-1]) := U(xi[n]-d)
U(xi[n]-d)
eq := c*(diff(U, xi[n]))*(U(xi[n])+u(xi[n-1]))*(U(xi[n])+u(xi[n+1]))-(2*(u(xi[n-1])-u(xi[n+1])))*(U(xi[n])^2)(1-U(xi[n])^2)
-2*(u(xi[n-1])-u(xi[n+1]))*(U(xi[n]))(1-U(xi[n])^2)^2
Download abs.mw
What am I doing wrong, why cant I get the result correct?
proc(U::Matrix);
proc (U::(Matrix(i .. m, j .. m))) local m, i, j; m := LinearAlgebra:-Dimension(U); if modp(i+j, 2) = 0 then U[i, j] := 1 else U[i, j] := 0 end if end proc
Hello! I've made these procedures but it doesn't result give me the result i want. Can someone please tell me where it is I made a mistake?
I have programs below for the cases n=3 and n=4. If n is increasing by 1, then there is one loop more. As you can see, that additional loop has always the structure:
x[i+1] from ceil(((n-2)*24-d[i])/(n-i)) to x[i]
whereas d[i] is the sum of the values of x before.
Now I want to write "nequaln":=proc(k), which goes through all the values for n from 3 to k and produces a list [a_3,a_4,a_5,...,a_n].
I guess that I need to program a kind of dynamical loop, but I failed completely. May someone help me? That would be very kind.
nequal3:=proc()
    local u,v,a_3;
    a_3:=0;
    for u from ceil((3-2)*24/(3-0)) to (3-2)*24-3+1 do
        for v from ceil(((3-2)*24-u)/(3-1)) to u do
            if (3-2)*24-u-v>=1 then
                a_3:=a_3+1;
    print(a_3);
nequal4:=proc()
    local u,v,w,a_4;
    a_4:=0;
    for u from ceil((4-2)*24/(4-0)) to (4-2)*24-4+1 do
        for v from ceil(((4-2)*24-u)/(4-1)) to u do
            for w from ceil(((4-2)*24-u-v)/(4-2)) to v do
                if (4-2)*24-u-v-w>=1 then
                    a_4:=a_4+1;
    print(a_4);
The old question "Longest distance in a graph via Maple code" offers some general methods to find longest paths in a given graph, while for directed acyclic graphs, the longest paths can be found much more directly via built-in functions. However, it apprears that even for small dags, Maple cannot solve this in an acceptable time. In the following example, I'd like to count the number of nodes that on longest paths for certain source and target vertexes.
_seed := 1234
Warning, the use of _seed is deprecated.  Please consider using one of the alternatives listed on the _seed help page.
G := GraphTheory:-RandomGraphs:-RandomNetwork(200, .2, 'acyclic', 'weights' = 0. .. 2)
G__0 := applyop(`-`, -1, G)``
GRAPHLN(directed, weighted, [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200], Array(1..200, {(1) = {2, 3, 4}, (2) = {5}, (3) = {4, 5}, (4) = {5}, (5) = {6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18}, (6) = {11, 12, 13, 14, 15, 17, 18, 19, 21}, (7) = {9, 10, 11, 16, 17, 20, 22}, (8) = {12, 14, 16, 17, 19, 20, 21, 22, 23}, (9) = {11, 14, 21, 23}, (10) = {11, 13, 18, 19, 20, 21, 23}, (11) = {14, 15, 16, 17, 18, 21, 23}, (12) = {13, 15, 18, 19, 20, 22}, (13) = {14, 15, 16, 17, 21}, (14) = {19, 20, 22}, (15) = {19, 20, 22, 23}, (16) = {17, 18, 21}, (17) = {19, 20, 23}, (18) = {19, 20, 21}, (19) = {20, 24, 25}, (20) = {22, 23, 25}, (21) = {23, 24, 25}, (22) = {23, 24, 25}, (23) = {24, 25}, (24) = {26, 27, 29}, (25) = {27, 28, 29}, (26) = {28, 29, 30}, (27) = {28, 29, 31, 32, 33}, (28) = {32, 33}, (29) = {32, 33}, (30) = {34, 35, 38, 39}, (31) = {32, 37, 38, 39}, (32) = {33, 36, 37, 38}, (33) = {35, 36, 39}, (34) = {36, 38, 39}, (35) = {37, 39}, (36) = {37, 39}, (37) = {39, 40}, (38) = {39, 40}, (39) = {40}, (40) = {41, 42}, (41) = {43, 44, 47, 48, 49}, (42) = {44, 45, 46, 47, 48, 49}, (43) = {47, 49, 50, 55, 56, 57}, (44) = {45, 48, 50, 51, 52, 53, 54, 56}, (45) = {46, 47, 49, 50, 52, 56}, (46) = {47, 48, 49, 50, 51, 52, 53, 56, 57}, (47) = {49, 50, 51, 52, 54, 56, 57}, (48) = {49, 51, 52, 53, 54, 55, 56, 57}, (49) = {50, 52, 53, 54, 57}, (50) = {51, 57}, (51) = {53, 54, 57}, (52) = {53, 55, 57}, (53) = {54, 56}, (54) = {56, 58}, (55) = {58}, (56) = {58}, (57) = {58}, (58) = {59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75}, (59) = {60, 61, 66, 68, 70, 71, 74, 75, 76, 77}, (60) = {61, 63, 67, 68, 70, 72, 73, 77}, (61) = {62, 66, 69, 70, 71, 72, 73, 75, 76, 77}, (62) = {65, 68, 75, 76, 77}, (63) = {65, 66, 69, 70, 72, 73, 76, 77}, (64) = {65, 67, 68, 69, 70, 71, 73, 77}, (65) = {66, 70, 72, 73, 74, 76}, (66) = {68, 70, 71, 72, 73, 74, 75, 76, 77}, (67) = {69, 70, 71, 74, 76}, (68) = {73, 74}, (69) = {71, 76, 77}, (70) = {71, 73, 77}, (71) = {72, 76, 77}, (72) = {75}, (73) = {75, 76}, (74) = {76}, (75) = {76}, (76) = {77, 78, 79, 80, 81, 82, 83, 85, 86}, (77) = {79, 80, 82, 84, 85}, (78) = {79, 83, 85, 87}, (79) = {81, 82, 83, 85, 86, 87}, (80) = {83, 86}, (81) = {83, 84, 87}, (82) = {87}, (83) = {85, 86, 87}, (84) = {85, 87}, (85) = {87}, (86) = {87}, (87) = {88, 89}, (88) = {90, 91, 92, 93, 94}, (89) = {90, 91, 93, 94, 95}, (90) = {96, 97, 99, 101, 103, 104, 107, 108, 109, 110, 112, 115, 117, 118, 120}, (91) = {92, 94, 96, 97, 98, 100, 101, 102, 105, 106, 107, 110, 113, 116, 117, 118, 120}, (92) = {95, 97, 98, 99, 101, 103, 106, 107, 108, 111, 112, 113, 115, 117, 119, 120}, (93) = {95, 96, 98, 100, 104, 106, 109, 111, 112, 113, 116, 118, 119, 120}, (94) = {95, 99, 100, 102, 103, 104, 106, 108, 109, 110, 111, 112, 113, 114, 115, 117, 118, 119, 120}, (95) = {97, 98, 99, 100, 102, 103, 104, 105, 107, 108, 109, 111, 112, 113, 114, 115, 116, 117, 118, 120}, (96) = {98, 100, 102, 103, 104, 106, 107, 110, 111, 114, 119, 120, 121}, (97) = {99, 100, 102, 104, 106, 107, 108, 109, 111, 114, 118, 119}, (98) = {102, 103, 107, 110, 111, 112, 113, 114, 116, 117, 119, 120, 121}, (99) = {101, 102, 104, 106, 107, 112, 117, 120}, (100) = {101, 104, 105, 106, 109, 110, 116, 117, 119, 120, 121}, (101) = {102, 105, 109, 110, 111, 112, 113, 114, 115, 117, 118, 119, 120}, (102) = {103, 106, 107, 108, 110, 112, 113, 114, 117, 118, 119}, (103) = {104, 105, 107, 108, 109, 110, 111, 113, 115, 116, 119, 120, 121}, (104) = {105, 106, 109, 110, 114, 115, 116, 118, 119}, (105) = {106, 108, 109, 110, 113, 114, 116, 117}, (106) = {107, 108, 109, 112, 114, 117, 118, 119, 121}, (107) = {110, 114, 116, 119, 120}, (108) = {111, 112, 113, 114, 118, 119, 120, 121}, (109) = {113, 116, 117, 118, 121}, (110) = {111, 113, 117, 119, 120, 121}, (111) = {112, 113, 115, 118, 120}, (112) = {113, 114, 116, 117, 118, 119, 120}, (113) = {116, 117, 119, 121}, (114) = {115, 116, 117, 121}, (115) = {116, 120}, (116) = {119, 121}, (117) = {118, 119, 121}, (118) = {121}, (119) = {121}, (120) = {121}, (121) = {122, 123, 124, 125, 126}, (122) = {123, 124, 125, 126, 127}, (123) = {126}, (124) = {126, 127}, (125) = {127}, (126) = {127}, (127) = {128, 129}, (128) = {130}, (129) = {130}, (130) = {131, 132}, (131) = {132, 133, 135}, (132) = {134, 135}, (133) = {134, 136, 137, 138, 140, 141, 142}, (134) = {135, 136, 139, 140, 141}, (135) = {136, 137, 139, 140, 141, 142}, (136) = {145, 146, 147}, (137) = {139, 141, 143, 145, 147, 148}, (138) = {139, 140, 143, 144, 145, 148}, (139) = {141, 143, 145}, (140) = {143, 145, 146, 147, 148}, (141) = {142, 144, 145, 146, 147}, (142) = {143, 144, 146, 148}, (143) = {145, 146, 147, 148}, (144) = {146, 149}, (145) = {147}, (146) = {149}, (147) = {149}, (148) = {149}, (149) = {150, 151, 152, 153, 154, 155, 156, 157, 158}, (150) = {152, 153, 155, 157, 158}, (151) = {152, 153, 159}, (152) = {154, 158}, (153) = {154, 155, 156}, (154) = {156, 158, 159}, (155) = {158}, (156) = {157, 158, 159}, (157) = {158}, (158) = {159}, (159) = {160, 161, 162, 163}, (160) = {161, 163, 166, 167}, (161) = {165, 166, 167}, (162) = {163, 165}, (163) = {164, 166, 167}, (164) = {166}, (165) = {166, 168, 169}, (166) = {169}, (167) = {168}, (168) = {169, 170, 171, 172, 173, 174, 177, 178, 179, 180, 182}, (169) = {170, 171, 172, 173, 174, 175, 176, 177, 178, 180, 181, 182}, (170) = {172, 173, 174, 175, 176, 180, 182, 183, 185}, (171) = {172, 174, 176, 177, 181, 182, 185}, (172) = {175, 176, 177, 183, 185}, (173) = {175, 176, 178, 183, 185}, (174) = {175, 180, 181, 183, 184, 185}, (175) = {181, 182, 183, 185}, (176) = {177, 178, 179, 182}, (177) = {178, 179, 184, 185}, (178) = {179, 180, 182, 183, 184}, (179) = {180, 182, 185}, (180) = {181, 182}, (181) = {184}, (182) = {185}, (183) = {187, 188, 190}, (184) = {187, 188, 189}, (185) = {186, 188, 190}, (186) = {187, 188, 190, 191, 193, 194, 196}, (187) = {188, 190, 192, 193, 194, 195}, (188) = {189, 190, 191, 192, 194}, (189) = {190, 191, 196}, (190) = {191, 192, 195, 196}, (191) = {193, 196, 199}, (192) = {194, 196, 198, 199}, (193) = {197, 199}, (194) = {195, 196, 197}, (195) = {196, 198, 199}, (196) = {198, 199}, (197) = {198}, (198) = {199, 200}, (199) = {200}, (200) = {}}), `GRAPHLN/table/1`, )
t, s := combinat:-randcomb(GraphTheory:-Vertices(G__0), 5^2), combinat:-randcomb(GraphTheory:-Vertices(G__0), integermul2exp(5, 2))
[12, 13, 22, 23, 41, 65, 70, 80, 88, 97, 105, 119, 124, 127, 129, 132, 135, 138, 146, 150, 165, 170, 189, 193, 199], [6, 13, 28, 29, 31, 41, 42, 49, 55, 85, 98, 104, 136, 141, 162, 166, 167, 168, 192, 199]
"DataFrame((`M__1`:=CodeTools:-Usage(Matrix(numelems(s),numelems(t),(i,j)->numelems((GraphTheory:-BellmanFordAlgorithm(`G__0`,s[i],t[j]))[1]),datatype=integer[2]))),'columns'=t,'rows'=s)"
memory used=7.99GiB, alloc change=0 bytes, cpu time=5.74m, real time=5.63m, gc time=22.55s
module DataFrame () description "two-dimensional rich data container"; local columns, rows, data, binder; option object(BaseDataObject); end module
"DataFrame((`M__2`:=CodeTools:-Usage(Matrix(numelems(s),numelems(t),proc(i::posint,j::posint,` $`)::nonnegint;  uses ListTools,GraphTheory; local ts::list(posint):=TopologicSort(`G__0`,'output'='permutation'),q::posint:=Search(t[j],ts),p::posint:=Search(s[i],ts); if  p>q then 0 elif q=p then 1 else numelems(BellmanFordAlgorithm(`G__0`,s[i],t[j])[1]) fi end,datatype=integer))),':-columns'=t,':-rows'=s)"
memory used=4.34GiB, alloc change=32.00MiB, cpu time=3.26m, real time=3.19m, gc time=14.34s
EqualEntries(M__ || (1 .. 2))
Download longest_paths_in_a_DAG.mw
Unfortunately, I have to wait for almost four minutes in the above instance. Can this task be done in 0.4s?
In the Grading Quiz, it is possible for students to indicate whether the answer is correct or incorrect. In the context menu, it is also possible to add an icon instead of the text.
For some reason, I can't get this to work! If I assign an icon to the correct answer, the same icon is transferred to the incorrect answer.
Is there a way that I'm missing that can show two different icons rather than the same one?
How to force Maple to prove equality (2) under conditions cond.
# Given
#     0 < u < 1
#     0 < v < 1
#     theta > 1
# let F the function defined by:
F := (u, v) -> exp(-((-ln(u))^theta+(-ln(v))^theta)^(1/theta))
proc (u, v) options operator, arrow; exp(-((-ln(u))^theta+(-ln(v))^theta)^(1/theta)) end proc
# How to prove this equality for any n > 0?
'F(u^(1/n), v^(1/n))^n' = 'F(u, v)'
F(u^(1/n), v^(1/n))^n = F(u, v)
cond := u > 0, u < 1, v > 0, v < 1, theta > 1, n > 1:
simplify(F(u^(1/n), v^(1/n))^n - F(u, v)) assuming cond;
(exp(-(((-ln(u))^theta+(-ln(v))^theta)*n^(-theta))^(1/theta)))^n-exp(-((-ln(u))^theta+(-ln(v))^theta)^(1/theta))
Download Stable.mw
Thanks for your help.
Hi, I am using ArchLinux and used Maple's official installer to install it. Whenever I export my Maple files as PDF all my "-" symbols are converted to "K" for some reason. Has anyone else had this issue or have an idea on how to fix it?
Below is a screenshot of what I mean. "-" has been replaced with "K"
Hi! Do you know how can I plot revolution of this curve:
plot(1 + 1/4*sin(8*(1 + 1/8*sin(16*(1 + 1/16*sin(32*t))))), t = 0 .. 2*Pi, coords = polar)
to get a wrinkled torus like this:
Abelprijs 2015 voor John Nash en Louis Nirenberg - NEMO Kennislink
Do u have any idea? (I've tried to convert this polar curve to cartesian coords but I don't get it)
map won't work with left quotes
L:=[2,"foo",4]
First 225 226 227 228 229 230 231 Last Page 227 of 2472
