I have learned in Brownstone site how to create,
using latex, sketch questions for Maple TA.
I could create a question bank, formed by sketch mode questions,
and then uploaded it to Maple TA, but the applets just don't work.
There are no java error messages.
On the java console i get messages like:
SplinePlot.mousePressed():
Could not add node because of conflicting x-coordinate:
node with matching x-value already present in system
Please select another point.
Hi, I'm very new to Maple. I have a set of equations. 16 equations with 16 unknowns, so it is possible to solve for 16 unknowns. I can solve using matrix if all of these equations are linear using my calculator; however, 2 out of the 16 equations are non-linear (x^2...ect) equations. I would like to use a software to solve for it. Is there a way to solve these 16 equations using Maple? If there is, please show me how, the more details the better for me because I'm very new to Maple and not very familiar with using Maple user interface. Thanks
Hello there.... I recently purchased maple10-student edition. I am having trouble trying to use it effectively! I am trying to type in simple maths questions into Maple,but Maple does not seem to recognise it? Ive tried everything......im hoping ill be able to get some help with regards to my questions? My question- im tryind to find the fraction equivalent to the fraction ab/cx ? How do you type that in and get the answer? The same goes with this fraction that im trying to simplify a/b + b/a - c/d = How do i type that in ? And can maple give explanations towards its answers?
How do I make odeplot scale the Y axis from 0?
For reasons I do not understand it has started to scale from the minimum value.
My current expression is
odeplot(dsol,[sSX_(u),sSY_(u)],0..(0.9), title = "Postion",
legend=[position],axes=FRAME,scaling=constrained );
Thank you in advance
Hello, I am trying to call a matlab function from maple and get the following error msg: Error, (in OpenEngine) Maple/Matlab Link: Can't start Matlab engine I have tried the with(Maple) command and it shows shows a list of functions indicating that the two packages are linked. I would highly appreciate if someone could help me out with this. Thanks Saqib
Good morning.
I'd like to know if (and how) it is possible to use Dirac's bra-kets notation, so often used in Quantum Mechanics and Physics courses...
I searched in this site and with google, but I found no hints...
Probably that notation conflicts with the methods used to write a vector, e.g v:=; , but I wonder if it exists a workaround, an hack, a package, a library or something else to accomplish the task...
Have a nice day!
Gabriele Inghirami
I'm looking for a C library that does symbolic manipulation - particularly integration. Does anything like this exist?
Paul
We use maple to generate all of our computational bits, dump this out to header files, and include this in our code base. A lot of the code that is generated is redundant so it would be nice to have codegen[C] know, or at least be able to be told, to optimize the entire code being dumped to the same header file. Is this possible? Examples follow... " ..... DCb := array(1..3): lp:='lp':ip:='ip':m:='m':ap:='ap':jp:='jp':a:='a':l:='l':j:='j':i:='i':k:='k':kp:='kp': for ip from 1 to 3 do DCb[ip] := sum(sum(sum(sum(sum(gd[ip,jp]*gu[ap,lp]*jacu[m,lp]*jacu[a,ap]*dJ[jp,m,a],m=1..3),jp=1..3),lp=1..3),ap=1..3),a=1..3):
Ok I am new to Maple and can't seem to get anything right with it. I am taking trigonometry online (big mistake) is killing me. I need help with problems like this: Find all solutions of the equation 2 sin(2x)=sqrt(3) in the interval [0,2π]. Can any one help?
How do I animate a sinus function between 0 and PI along an axis to simulate a travelling wave? I would greatly appreciate any help.
Hi all, I'm sure this is very simple - but I simply can't figure out how to do it - and I can't find any information on it. I have an equation which has been integrated and that's all wondering. However, I would like the equation to be outputted on a single line so I can copy from one window and paste it into another. As it stands Maple displays the equation over several lines so I can't do this. I could of course retype it - but its rather complex and I'd rather have the equation that Maple outputs so I know there isn't a mistake I've introduced. For what I can tell this is Maple's 2d maths display, which is default. I can see how to change it in a gui version of Maple, however, I don't have access to a gui version - its command line on linux... Its Maple 10 as well if that helps at all.
Hi folks, I'm using the IntegralTools(Change) function to change the variables of integration in a double integral to lower the order of a polynomial under a radical prior to integration (praise to Axel!). The result contains exponents under the radical and in the limits of integration that seem to defy Maple's numerical integration routines. (Sorry for not using HTML! I tried to present in 2D math, but the preview post omitted the math entirely. Just paste it into a worksheet to convert this text mess into a mathematical one.) Int(70871722182849/100000000000000000*Int((20.6066600725-0.164853280580e-1*sqrt(1.562500*(RealDomain[`^`])(10, 6)+7.58249999999*(RealDomain[`^`])(10, 6)*(RealDomain[`^`])(xi[2], 99999999999999939/100000000000000000)-3.35631780000*(RealDomain[`^`])(10, 7)*(RealDomain[`^`])(xi[1], .10000000000000)*(RealDomain[`^`])(xi[2], 99999999999999939/100000000000000000)+9.19908900000*(RealDomain[`^`])(10, 6)*(RealDomain[`^`])(xi[1], .20000000000000)+9.19908899998*(RealDomain[`^`])(10, 6)*(RealDomain[`^`])(xi[2], 99999999999999939/50000000000000000)+7.58250000000*(RealDomain[`^`])(10, 6)*(RealDomain[`^`])(xi[1], .10000000000000))+50.0000000000*(RealDomain[`^`])(xi[1], .10000000000000)+50.0000000000*(RealDomain[`^`])(xi[2], 99999999999999939/100000000000000000))*(RealDomain[`^`])(xi[2], 0.70163004961021e-1), xi[1] = (RealDomain[`^`])(c, 1000) .. (RealDomain[`^`])(d, 1000))/(RealDomain[`^`])(xi[2], 99929128277817151/100000000000000000), xi[2] = (RealDomain[`^`])(a, 100000000000000000/70871722182849) .. (RealDomain[`^`])(b, 100000000000000000/70871722182849))
Our's is a large I.T training organisation we are looking for I.T Professionals who can create worksheets through Maple 10.Familiarity with the mathematics module will be an added advantage.
The requirement is quite urgent if anyone interested or knows anyone who is interested please contact ASAP.
I am trying to export the animated gif generated by this maple code: It exports the animated gif with a gray background. How can I get a white background? Thanks
Hello all, I have a question about numerical integration in Maple. I have an equation (a PDF) which I need a numerical answer from as Maple can't find a closed form solution (which isn't too surprising given the equation in question). Anyway, the equation has several parameters which are varied and the equation looped over. That's no problem, and generally Maple will find a numerical solution to the problem. However, towards the extreme value case I get error messages basically saying Maple hasn't found a numerical result. The equation giving the error is: -20.01782577 I exp(-490.0000000 - 50. x) (-0.1625801243 10^212 I + erf(0.2258769757 I (9801. + 980. x)^1/2 - 0.2258769757 I)) dx
First 2417 2418 2419 2420 2421 2422 2423 Last Page 2419 of 2462
