I have a question about Hilbert Series of the quotient of an algebra by a non-homogenous ideal.
In maple help: https://www.maplesoft.com/support/help/maple/view.aspx?path=Groebner%2FHilbertSeries, it is said that
The algorithms for HilbertSeries and HilbertPolynomial use the leading monomials of a total degree Groebner basis for J. Here J is an ideal.
I checked the following example. Let
J:= [(x[2]-x[1])*(x[2]-x[3]), (x[4]-x[1])*(-x[5]+x[4]), (x[4]-x[2])*(x[4]-x[6]), (-x[3]+x[5])*(x[5]-x[6]), x[1]^3-1, x[2]^3-1, x[3]^3-1, x[4]^3-1, x[5]^3-1, x[6]^3-1];
t1:=map(LeadingMonomial, l, grlex(x[1], x[2], x[3], x[4], x[5], x[6], x[7], x[8], x[9], x[10], x[11], x[12]));
Then t1 is the ideal generated by the following monomials.
t1 := [x[1]*x[2], x[1]*x[4], x[2]*x[4], x[3]*x[5], x[1]^3, x[2]^3, x[3]^3, x[4]^3, x[5]^3, x[6]^3]
Using the commands:
l2:={x[1],x[2],x[3],x[4],x[5],x[6],x[7],x[8],x[9],x[10],x[11],x[12]};
factor(HilbertSeries(J, l2, t));
factor(HilbertSeries(t1, l2, t));
We obtain Hilbert(J,t)=(t^2+t+1)*(5*t^4+11*t^3+11*t^2+5*t+1)
Hilbert(t1, t) = (t^2+t+1)*(3*t^2+3*t+1)*(2*t^2+2*t+1)
These two polynomials are not equal. How does maple compute Hilbert Series for the quotient of an algebra by a non-homogenous ideal? Thank you very much.
Is there any way to integrate this in maple?
lambda^2*t*(diff(theta(t), t, t)) = lambda^2*(diff(theta(t), t))-Pr*s*lambda*(diff(theta(t), t))+Pr*(diff(theta(t), t))-Pr*t*(diff(theta(t), t))
If I used factor, it didn't simplify to 0. As you may notice that this value should be 0.
I need help, because I can't find solution.
How can I export data from Bode Plot to Excel? Two below solutions don't work.
with(DynamicSystems);
T2 := TransferFunction((1.224867518*10^(-7)*s+2.259345677*10^(-6))/(s^2+11.83692270*s+238.3951363)):
BP2 := BodePlot(T2);
with(ExcelTools);
ExcelTools:-Export(op([1, 1], BP2));
Export(BP2, "Employees13.xls", "Payroll1", "B2");
File_1.mw
Never really used the writeto command but what's with all the typesetting gobbledygook in the text file?  It occurs with document and worksheet mode.  Perhaps it's only meant for classic or command line maple?
Is there a way to log the terminal output to a .txt file?
Trying to plot this expresion
f := epsilon-1.5+9.3*I = (a+I*b)*(26.+I*(-45.-1.0*Re(a+I*b)^2-1.0*Im(a+I*b)^2))
implicitplot (a^2+b^2) against epsilon
many thanks
I am trying to solve a linear system involving large number of equations with constant coefficients using Solve command from the LinearAlgebra package. The maple program is giving solutions for a smaller number of equations (T=10,Ne=20,Ng=15). But if I increase the number of equations to (T=20,Ne=30, Ng=25), then I got the error kernel connection has been lost. I need to increase the number of equations beyond this also. Any help to simplify the code or finding errors is appreciated.
solntosystem.mw
I would like to perform an implicit differentiation of the following:
eqn := 5*(x*y)^2+x/sqrt(y) = x^2+2*(3*x^3+y^2)^3
However implicitdiff(eqn, x, y); produces an output that expands the result.  Is there a way to not have it expand?
I tried something to the effect of...
eqn := 5*(x*y(x))^2+x/sqrt(y(x)) = x^2+2*(3*x^3+y(x)^2)^3;
diff(eqn, x);
but now what I need to to isolate d/dx y(x)...
Any suggestions are much appreciated.
 my question is
I am working on for loop and there are multi-line inside it and I only need to show a specific result, not all that occurs inside the loop . is there any commend to do that in maple?
with(Statistics):
LetList := [C, E, F, H, K, P, T, W, X, Y]; LetList[Sample()];
Error, invalid input: no implementation of Sample matches the arguments in call, 'Sample:-ModuleApply()'
Can any one help me with random sampling from LetList ?
Melvin
what is the code of the following equation:
 where h, and g are matrices with positive determenets.
How can we create the following upper triangular matrix?
where k and M are any integers,
 F and L are MxM Matrices  as follows
k:=2:
M:=3:
F:=Matrix(M,M):
for i from 1 to M do
  for j from 1 to M do
 F[1,1] := 2;
    F[i,j]:=0
  end do
F;
L:=Matrix(M,M):
L:=LinearAlgebra[BandMatrix]([
      [seq(-sqrt(2*i-1)/(2*i-1)*sqrt(2*i-3),i=2..M)], [1,seq(0*i,i=1..M-1)],[seq((sqrt(2*i-3))/((2*i-3)*sqrt(2*i-1)),i=2..M)]]);
Dear Users!
Hope you would be fine with everything. I want to evaluate the following expression for k = 3, j = 0, r = 1.
I am waiting for your positive reply. Thanks in advance
every time I input a formula I get:
Typesetting:-mparsed(x^2 +5 -2,x^2+3; "_noterminate")
I can't get rid of this error: this is very basic, what happened?
TIA, Roberto
First 789 790 791 792 793 794 795 Last Page 791 of 2464
