sys:={x+y=10,x^2-y^2+z^2=1};
{x+y = 10, x^2-y^2+z^2 = 1}
isolve(sys, n);
{x = -(1/20)*(1+20*n)^2+101/20, y = (1/20)*(1+20*n)^2+99/20, z = 1+20*n}
_SolutionsMayBeLost;  # It was set in Maple 10 or so!  E.g. x=5,y=5,z=-1 is not found.
_SolutionsMayBeLost
# Workaround
yz:=eliminate(sys,x);
[{x = -y+10}, {z^2-20*y+99}]
S:=isolve(yz[2], n);
{y = 20*n^2-38*n+23, z = 19-20*n}, {y = 20*n^2-22*n+11, z = 11-20*n}, {y = 20*n^2-18*n+9, z = 9-20*n}, {y = 20*n^2-2*n+5, z = 1-20*n}
map(u -> ( u union eval(yz[1],u) ), [S])[];  # The correct solution
{x = -20*n^2+38*n-13, y = 20*n^2-38*n+23, z = 19-20*n}, {x = -20*n^2+22*n-1, y = 20*n^2-22*n+11, z = 11-20*n}, {x = -20*n^2+18*n+1, y = 20*n^2-18*n+9, z = 9-20*n}, {x = -20*n^2+2*n+5, y = 20*n^2-2*n+5, z = 1-20*n}
This may seem a bit trivial, but I prefer f'(x) to writing diff(f(x),x) in 1D input. How to achieve?
differential.mw
15
"maple init loaded..."
In Document mode, this works fine.
f := proc (x) options operator, arrow; x^2 end proc
diff(f(x), x)
2*x
But I mainly use Worksheet (1D) mode, and I can't seem to acheve the same, without using diff(f(x),x)
f:x->x^2
f'(x)
Error, unexpected single forward quote
Download differential.mw
Simple question:
Why does
(exp(I*t))^q;
`assuming`([simplify(%)], [t > 0, t < 2*Pi, q > 0, q < 1])
not simplify to exp(I*t*q)
The Maplecloud and maplesoft web pages only have the latest version of the physics package.
Is there an archive of older physics packages?  ie. the latest versions to go with each of the older versions of Maple?
does anyone khow to force maple to automatically simplify expressions that look like this:
cc:=arctan(sin(phi)/cos(phi))-arccos(cos(phi))
simplify(cc) assuming phi::real; #should be zero
i've played with convert/expand/simplify and in certain cases of course i can force maple to do this... (kind of manually).. but was hoping this could be more automatic.
thanks!
The round(x) statement rounds x to the nearest integer but if x has unirs it appears not to work. Known bug?
RoundUnits.mw
a := 15; b := 5.3
c := (1/100)*a+b
5.450000000
c := round(c)
5
A := 15*Unit('cm'); B := 5.3*Unit('m')
C := A+B
15*Units:-Unit(cm)+5.3*Units:-Unit(m)
C := simplify(C)
5.450000000*Units:-Unit(m)
Cr := round(C)
round(5.450000000*Units:-Unit(m))
Download RoundUnits.mw
Hello, I am getting the following output from maple: (-ln(lambda)-gamma-ln(k+b))/(k+b) . I have all variables (lambda, k, b) but not gamma and I am not sure what actually it is. I believe it is some kind of Gamma function but I cannot find any expressions for that. Ussually for gamma function I get something like GAMMA(x). Does someone know what this lower case gamma is?
I wish to write a simple procedure to evaluate the Poisson quantile function, F, for many possible parameter values, lambda.
The Maple commands to evaluate F for individual lambda values works just fine, however, I have tried to write a simple procedure to evaluate F for prescribed lambda values (imported from Excel) but to no avail. I'm missing something quite basic, I'm sure.
Can anybody offer a suggestion please? Thanks.
Inverse_Poisson_Procedure.mw
i want to gain diff(p(t), t) and diff(q(t), t) and Jacobian matrix
 according to the attached pdf file.
please help me.
simplify.mw
k := diff(a(t), t) = -mu*a(t)-(1/4)*alpha6*a(t)*sin(gamma(t))
j := a(t)*(diff(gamma(t), t)) = 2*a(t)*sigma-(6*(1/8))*(alpha1-alpha2+(1/3)*alpha3)*a(t)^3-(1/2)*alpha6*a(t)*cos(gamma(t))
a(t)*(diff(gamma(t), t)) = 2*a(t)*sigma-(3/4)*(alpha1-alpha2+(1/3)*alpha3)*a(t)^3-(1/2)*alpha6*a(t)*cos(gamma(t))
"p(t):=a(t)*cos(gamma(t))"
proc (t) options operator, arrow, function_assign; a(t)*cos(gamma(t)) end proc
"q(t):=a(t)*sin(gamma(t))"
proc (t) options operator, arrow, function_assign; a(t)*sin(gamma(t)) end proc
diff(p(t), t)
(diff(a(t), t))*cos(gamma(t))-a(t)*(diff(gamma(t), t))*sin(gamma(t))
(-mu*a(t)-(1/4)*alpha6*a(t)*sin(gamma(t)))*cos(gamma(t))-a(t)*(2*sigma-(6*(1/8))*(alpha1-alpha2+(1/3)*alpha3)*a(t)^2-(1/2)*alpha6*cos(gamma(t)))*sin(gamma(t))
(-mu*a(t)-(1/4)*alpha6*a(t)*sin(gamma(t)))*cos(gamma(t))-a(t)*(2*sigma-(3/4)*(alpha1-alpha2+(1/3)*alpha3)*a(t)^2-(1/2)*alpha6*cos(gamma(t)))*sin(gamma(t))
diff(p(t), t)
2*t
subs.pdf
Download simplify.mw
I am having some trouble with a procedure. One of the procedures arguments is a mathematical function g(var). For simplification lets say I wish to make a procedure which calculates some values of the unknown function, g:
SomeProc:=proc(g,var:=x)
f(var):=g
return f(2)
end proc
This does not seem to work. No matter what value of var is inserted into f, the return is g(var).
Any help would be much appreciated:
How do I combine log10 terms. I can do it with natural logs but I have not been able do do it with log10.
Hello, I would like to make my polynomial equation simpler by replacing every coefficient of each degree in s by any constant.
For example, one of the variable solutions it is:
How can i re-write this equation in the form, lets say, C0+C1*s+C2*s^2+C3*s^3?
I draw a 3d graph and now i want the table of this graph. how can we get a table from the data of a plotted graph.
May grapg was obtained from the following commands
plot3d(1/2*(q^(2*n)-5.*q^n+(2.*q-1)^n+3), q = 2 .. 15, n = 2 .. 20);
How can one the last value of variable
when I have variables Like C1;C2,C3....., F1,F2,F32,....so on
always number would be at last of the variable.
Depending upon the number in the variable I need to call values from other list. It would be really helpful to know how one can get the number present in variable?
Hi, I am working on an assignment and have some doubts about my solution to plotting the position of an anharmonic oscilliator with the Runge-Kutta method.
My attempt on the problem:
Handin_2.mw
A picture of the problem is attached below. In addition to this, we are to repeat the problem with k = 0.1 (f = 0 still), and k = 0.1 and f = 0.5.
First 792 793 794 795 796 797 798 Last Page 794 of 2464
