I have the following command (credit to @Carl Love ), this command will do certain bit shifting with the next block, and the last block will shift with the first block.
B:= Matrix([[0,0,1,1,0,0,1], [0,0,1,1,1,0,0],[0,1,0,1,0,1,0], [1,0,0,1,1,1,0]]):
Bnew:= copy(B):
Bnew[[4,1,2,3], 3..5]:= B[.., 3..5]:
Bnew;
May i know any command can help to reverse the shifting position between the block?
for example,
original block  [0,0,1,1,0,0,1], [0,0,1,1,1,0,0],[0,1,0,1,0,1,0], [1,0,0,1,1,1,0]
i need to shift the 3..5 position of block 1 and change to the 5..3 position of block 2.
Example:
After shifting,
Bnew=[0,0,1,1,1,0,1],[0,0,0,1,0,0,0],[0,1,1,1,0,1,0],[1,0,0,1,1,1,0]
Any command can help to solve? thank you in advance.
May I know any command can help to random selected a position in a group of bit number then flip that number but with condition after convert to bytes the number cannot be more than 7?
For example,
I have integer 3, i convert to binary become 0000011
then i need a command to random select a position to flip and only one bit can be flipped.
After that the group of flipped number will convert back to decimal, but total value cannot more than 7? any command can solve?  Thank you.
Hi Maple Primes
I have this parabola -
y2:=6z^2 +z+244;
x2:=9z^2+3z+367;
I use the eliminate command to write without z;
c:=eliminate([y=y2,x=x2],z);
Then I have the expression
e2 = 4x^2-12xy+9y^2-7x+9y+369.
My questions is, what integer values for x and y are on the curve e2?
I think the answer may be exactly when z is an integer.
How could I determine this given only e2?
Matt
How can I get the minimum point of (sin(x+y))
plot3d(sin(x+y), x=-1..1, y=-1..1);
I would like to plot a cone where I can change the vertex angle directly. I would also to be able to change the size of the cone. I have tried:
cone([r*cos(phi)*sin(theta), r*sin(phi)*sin(theta), r*cos(theta)], phi = 0 .. 2*Pi, r = 0 .. 1, theta = (1/6)*Pi, coords = spherical)
but this gives me the following error:
Error, (in plot3d) unexpected options: [[r*cos(phi)*sin(theta), r*sin(phi)*sin(theta), r*cos(theta)], phi = 0 .. 2*Pi, r = 0 .. 1, theta = (1/6)*Pi]
I would like to know if it is possible to change the color for the result from blue to black or red. Maybe by editing the text that state the colors.
And the same goes for the color palette, can I make my own colors in the color palette text. It should work by default.
Heide
Hi everybody;
In the following attached file, I am trying to solve a system of nonlinear equations with one equality constraint. I have 9 equations and 9 unknowns. Attached file has composed of 3 main parts, first is input data, second is the 9 nonlinear equations from E_1 to E_9 and finally third part is constraint equation called C_1. My unknowns are "phi, theta, p, q, r, T, L, M and N". My question is that: Can Maple solve this problem?? Is there any solution to this problem or I have to change input data?? If Maple can solve this problem, how can I do that??
I appreciate your help in advance.
NL.mw
with(DEtools):
phaseportrait([secret], [a(t), b(t), c(t)], t = -2 .. 2, [[a(0) = 1, b(0) = 0, c(0) = 2]], stepsize = 0.5e-1, scene = [c(t), a(t)], linecolour = sin((1/2)*t*Pi), method = classical[foreuler]);
Error, (in DEtools/phaseportrait) the ODE system does not contain derivatives of the unknown function a
Hello guys, i have some problems.
i have system
\dot{x} = Ax + Bu
s=b*u =
now, we have X' = (A+S)X,  i need numeric/analytical solution and found Vector(X)
I have some problems with syntax maple.
Sorry for my bad english.
ricatti.mw
I am a student of an engineering career
The math teacher is going to ask us to solve some exercises Matlab
The teacher is very hard and explains nothing of Matlab in class
We must learn to use the program on our own viewing internet watching tutorials
I was wondering if somebody could help solve some exercises.
Are only three exercises which are imposible to me
I would appreciate it greatly.
My e-mail :
alessagosti1@gmail.com
I will try to be as specific as possible.
On my Ti nspire it is possible for me to calculate polar equations like on the buttom picture with the settings on the upper picture. But when I try this in Maple It is not possible. I have worked my way try for two days now and it does not work for me.
Does any body know how to get this solved?
Heide
I have two polynomials f(x,y,z) and g(x,y,z) and ask MAPLE to find conditions on the coefficients of f and g such that the Jacobian determinant in x and y is purely a polynomial in z. MAPLE finds 4 solutions, one of which is g=0, but does not find the solution f=0. I attach the relevant MAPLE worksheet.
How can I do to suppress all the complex components of a vector ? Is there a simple code to do this?
For example, I would like to replace the complex components with zero.
If the considered vector is a:= [2+I,2,5], i would like to obtain after modifications amod:= [0,2,5] ou amod  [Nothing,2,5]
VectorWithComplexComponents.mw
Nota :
The origin of my issue is to be able to plot points with the following syntax :
pointplot([tp,xp,symbol = solidcircle,color=black,symbolsize = 10): where xp is a vector with, sometimes, some complex components.
I would like to plot the points only for the real components of xp
Thanks a lot for your help
This question is related to the recent post
http://www.mapleprimes.com/questions/211460-Series-Of-Bessel-Functions
1. Consider the following fast convergent series:
f:=n->(-1)^(n+1)*1/(n+exp(n));
S1:=Sum(f(n),n=1..infinity);
evalf(S1);
S2:=Sum(f(2*n-1)+f(2*n),n=1..infinity);
evalf(S2);
As expected, the sum of the series is obtained very fast (with any precision), same results for S1 and S2.
2. Now change the series to a very slowly convergent one:
f:=n->(-1)^(n+1)/sqrt(n+sqrt(n));
evalf(S1) is computed also extremely fast, because the acceleration algorithm works here perfectly.
But evalf(S2) demonstrates a bug:
Error, (in evalf/Sum1) invalid input: `evalf/Sum/infinite` expects its 2nd argument, ix, to be of type name, but received ...
3. Let us take another series:
f:=n->(-1)^(n+1)/sqrt(n+sqrt(n)*sin(n));
Now evalf(S1) does not evaluate numerically and evalf(S2) ==> same error.
Note that I do not know whether this series is convergent or not, but the same thing happens for the obviously convergent series
f:=n->(-1)^(n+1)/sqrt(n^(11/5)+n^2*sin(n));
(because it converges slowly (but absolutely) and the acceleration fails).
I would be interested to know a method to approximate (in Maple) the sum of such series.
Edit. Now I know that the mentioned series
converges (but note that Leibniz' test cannot be used).
I am trying to have the output of DETOOLS as 3dpolarplot. As in the following example:
EF := {2*(diff(w[2](t), t)) = 10, diff(w[1](t), t) = sqrt(2/w[1](t)), diff(w[3](t), t) = 0}; with(DEtools); DEplot3d(EF, {w[1](t), w[2](t), w[3](t)}, t = 0 .. 100, [[w[1](0) = 1, w[2](0) = 0, w[3](0) = 0]], scene = [w[1](t), w[2](t), w[3](t)], stepsize = .1, orientation = [139, -106])
how can I get the output as a polarplot in 3d where, w[2] and w[3] have range 0..2*pi.
Please help in this respect asap.
First 1167 1168 1169 1170 1171 1172 1173 Last Page 1169 of 2463
