Hello people
i have a quetion
what is the perposes of these softwares,maple,matlab,mathmatica and latex.
for example i listened from somewhere that matlab is best for matrices, then what are the major task of these softwares which i listed above including matlab,
how we make comparison of these softwares.
I have a simple list:
xlist := [150, 250, 500, 800, 1300, 2500, 5000]:
ylist := [.3, .5, .8, 1.0, 1.2, 1.4, 1.6]:
where after i said x:=plot(xlist,ylist);
What I want to do is ask maple" At what x value does the graph intersect with 1.5 on the y axis" or "at what y value does the graph intersect with 3000 on the x axis".
The data points are just that, I've been looking for commands to ask these questions but have been without luck. You don't need to give me the answer if you can point me to somewhere where this information is written, that would be very helpful!
first_order_error.mw
hi.please see attached file and explain how i remove error
thanks alot
Where was this graphic of a mountain crater used in Maple?  The top left graphic from here http://www.maplesoft.com/products/maple/features/Visualization.aspx#
I haven't seen it used in any webinars nor have I seen it in the application center.  5 points to anyone who can find it :)
mid_point.mw
hi i a have a problem with program which attached..please help me
thanks alot
dsys3 := {(diff(w(x), x, x, x, x))/x^2 = .4/(x^3*(1-w(x))^3)+40*(1+.65*(1-w(x)))/(x*(1-w(x))^2), w(0) = 0, w(1) = 0, ((D@@1)(w))(0) = 0, ((D@@1)(w))(1) = 0}
dsol5 := dsolve(dsys3, numeric, output = array([.5]))
Error, (in dsolve/numeric/bvp) system is singular at left endpoint, use midpoint method instead
I am a Maple über noob.
I am strugeling to figure out how to do simple phase calculations
For example
Phase_angle.mw
It is mainly for 3-phase angle calculation
  restart: with(plots):
  H := a -> piecewise(a>=0,1):
  f1 := y->(H(y-1*Pi)-H(y-2*Pi))*sin(y)^2:
  g1:=(f1(y)/sqrt(4*Pi*t))*(sin((x-y)^2/4/t+Pi/4)-sin((x+y)^2/4/t+Pi/4)):
  g2:= int(g1, y= 0..100):
  g3:= diff(g2,t):
  g4:= diff(g2,x$2):
  g5:= (g3^2+g4^2)/2:
  E2:= unapply(Int(g5, x= 0..100, epsilon= 1e-4, digits= 7), t):
  CodeTools:-Usage( plot(E2, 0..20, numpoints= 50, labels= [t, E]));
The above mentioned code should give constant figure, but it takes a lot of time and not accurate.
If you can help me to improve these codes, I would be pleased.
dear all
(1-pi*x/2)y[b]-1/3=int(t^4/sqrt((t^2-y[b])^2+y[a]^2),t);
x^2*y[c](1-pi*x/2)-1/3=int(t^4/sqrt((t^2-x^2*y[c])^2+y[a]^2),t);
i want to plot y[a],y[b],y[c] vs x.
plz help me.
thank you
dear all
how Matrix(2, 2, [a,b,c,d]) change to:
a b
c d
without [] !
Elast2.mw
Dear guys
I have an integral. I want to solve it by maple, but I can't. I think it's result is a hypergeometric function. Could you please guide me?
Int((2*(1-f)*t^(-f)/(3*A*f*(1-a/(A*f*t^(f-1)))))^(1/2));
I want to solve this for "t".
a:=Matrix(10,10,0):
b:=Matrix(10,10,0):
a[1,5]:=1:
b[10,5]:=1:
animate(listdensityplot,[a*k+b*(1-k),smooth=true],k=0..1)
compared with the range option in animate
animate(listdensityplot,[a*k+b*(1-k),smooth=true,range=0..1],k=0..1)
My guess is there something happening with the default animation that causes the anomaly.
i recall having asked this question before and having received answers which unfortunately I cannot locate.
I wish to generate a sequence like
    a[1], b[1], a[2], b[2], a[3], b[3]
The following does not work for the obvious reason:
    seq(a[i], b[i], i=1..3);
What is the right way?
Let a piecewise-linear curve be defined by a listlist. For example,
LL := [[1.1, 2.04], [1.97, 4.04], [2.96, 2.97], [4.5, 6.4], [5.08, 7.21], [1.1, 4.04], [1.1, 2.04]]:
plot(LL);
How to find its natural parametrization in Maple? A procedure is desired. See Wiki for info.
Hi everyone.
I have been experiencing a problem trying to solve a coupled system of 3 differencial equations
My problem is that a got a message back as I try to solve the system:
"Error, (in pdsolve/numeric/process_IBCs) improper op or subscript selector"
by apply this point that ''all dependent variables must be functions of the same independent variables''
i again accost with another error ''
Error, (in pdsolve/numeric/process_IBCs) initial/boundary conditions can only contain derivatives which are normal to the boundary, got (D[1, 1](w))(x, -3/400000000)
please help me.....very very thanks
First 1275 1276 1277 1278 1279 1280 1281 Last Page 1277 of 2470
